Jam in output bin - duplex area Error message
Jam
in output bin
alternates
with
Open
door and clear jam Description
Paper
jam in duplex reversing area Action
Clear the jam.
Press the (SELECT) button on
the control panel.
If the problem continues,
contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came
in the printer box for additional contact information.
Jam in output bin - fuser area Error message
Jam
in output bin
alternates
with
Open
A
paper jam has occurred in the output bin near the fuser area. Action
Clear the jam.
the control panel.
if it gives you the paper jam error ..and it is not any that you should check the fuser cause it is the same error when the fuser is defected or not functional ..If you have the possibility just reset the fuser ..
Just try the steps
Jam in output bin - fuser areaError messageJam in output binalternates withOpen door and clear jam
DescriptionA paper jam has occurred in the output bin near the fuser area.
Action
Clear the jam.
Press the (SELECT) button on the control panel.
Jam in output bin - duplex areaError messageJam in output binalternates withOpen door and clear jam
DescriptionPaper jam in duplex reversing area
Action
Clear the jam.
Press the (SELECT) button on the control panel.Please Rate my response!!!Thanks, SF
As i can understand whenever you try to print with rear door closed printed page should come on top from top output roller however paper gets jammed.
Solution:
Try to print a page using rear door open and it should come out from the rear drop down tray it printed page comes out successfully with rear flap open than paper gets jammed at top due to faulty top output roller.
However if the paper gets jammed at fuser with rear door closed than it is issue with fuser in that case you need to get fuser replaced at the same time replace 20 tooth gear next to fuser.
Ok if the paper is half way coming out, Two things could be happening. 1.) Either your paper feed tires are Slipping and haven't reached the outpit bin sensor in time. 2.) second problem could be is that the fuser film is worn and is not fuser correctly and needs to be replaced.
