Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Just intalled CD for above printer with Windows XP. When attempting to scan document, it says "No scan options, refer to troubleshooting document." Any ideas?
  • 1 more comment
  • crickettalu Mar 29, 2008
    I am getting the same problem. I reinstalled the drivers, even rewrote the reg. All this to no avail...
  • Anonymous Apr 02, 2008
    Mine does the same thing. It used to work, now it doesn't.
  • Anonymous Jun 21, 2008
    I'm having the same problem.
    I've reinstalled but it still doesn't want to work.
Scotti444 ,
hi! try this solution for your problem.tnx
Follow these steps to correct the problem:
  1. Open the HP Director/Solution Center software.
  2. Click Settings , click Scan Settings and Preferences , and then click Scan To....Setup . The Button Settings window will appear.
  3. The Destination List tab should be visible. The software will scan the computer and determine what scan capable programs are installed on the computer. These will be listed on the left side.
  4. Select a program you wish to scan to and then click Add to move it to the right side. Programs listed on the right will be available as scanning destinations when pressing the Scan button.
    Figure 1: Destination tab of the Button Settings
5. On the Scan To Button tab, you may also specify what type of scan you wish to launch from the front panel and establish a default scan resolution and color depth setting.
6. Click OK to save the changes and exit the setting.
>This error message occurs if the Scan To settings have never been set.
hope this can help you resolved your problem
Posted on Apr 07, 2008
  • 3,587 Answers
Start with a new set of drivers, since CD might be out of date.
Posted on Mar 15, 2008
We have an HP Officejet Pro L7580, we never use the scanner or fax. Only used for making copies. When I attempt to make a copy, there is an alert sound, then it says scanner failure on both the computer...
u should be good even if ur not using the scanner or fax. in the printer settings check if ur actually mean printing it from the computer or scanning a document and printing it out through it. this needs to cleared out. btw check if ur using the correct driver. i prefer not to use the one that is automatically installed in windows. USE THE ONE THAT CAME WITH IT OR DOWNLOAD FROM HP.
May 05, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
I am trying to scan from a HP Officejet Pro L7580. I am a bit of a technophobe and the printer is telling me No Scan Options Refer to device documentation which I havn't got. PLEASE advise me on how to...
Hello Mr.Johnson !
You can start a scan from a computer or from the control panel.
To use the scan features, your device and computer must be connected and turned
on. The printer software must also be installed and running on your computer prior to
scanning. To verify that the printer software is running on a computer running
Windows, look for the device icon in the system tray at the lower-right side of the
screen, near the clock. To verify this on a computer using the Mac OS, open the HP
Device Manager, and click Scan Picture. If a scanner is available, it will launch the HP
ScanPro application. If it is not available, a message appears to let you know that a
scanner was not found
Here you will find a link that will take you to this printers service manual (device documentation) :
Hope this can help you
You can contact me directly on:
Good Luck
Jul 15, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
I had HP Officejet Pro L7580 set to ask me which
Looks like you have saved the method as 'default'. If you open HP Solution Center and go to "Settings" and then choose "Scan settings" you can figure out the details from there. At some point, you choose not to save this as default and ask it to prompt each time..
Jan 20, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
I have an HP Officejet pro L7580. I called tech support a couple of months ago and they had me reset the printer. I'm have similar problems and need to reset it again and can't remember how. It had...
My officejet L7580 is brand new but when i want to scan anything it tells me there are No scan options.  Refer to device document what does this mean
Jun 30, 2008 | Office Equipment & Supplies
Getting error when trying to fax or scan
The L7580 is not meant to be set up as a scanning device on a network. This unit can only function properly as a USB connected device to have all the features work. Also, for the software to install with out problems, all other All in One software fro previous HP printers need to be removed. Once we did that and did clean install using USB only then did it work.
Mar 03, 2008 | HP OfficeJet Pro L7580 Color All-in-One...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
270 people viewed this question
Ben Johnson
