Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Oven conversion We have a LG oven LRG30855 that HH Gregg sold us, and they wont convert it for us, The instructions are missing, but the conversion orifices are there, I am a Licensed heating Contractor, I have the orifices changed, and the Top conversion on the regulator, flipped, There is a long orifice, Where does it go/ and I djusted the nut down on the top oven burner is this correct? these are all blue and appear to be correct, (BUT) the lower oven burner, the flame reache's the top of the oven, and is yellow and sutes up, ??? can you help
    President:
  • GE Master
  • 2,651 Answers
The lower oven bake burner should also have an adjustable hood to turn down, 1/2 or 9/16 open end will do it, as long as flames look ok youre alright, but def find and turn down the bake adjusteryou might nned to remove the storage drawer to acess
Posted on Mar 16, 2008
LG gas oven
ahhh..so..let me get this accurately..most of the conversion works, but there's a extra part(oricie???)..that's hanging around? Got a picture of that, by chance?
sounds like the missing piece to the puzzle, amigo.
Mar 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
How do I convert a Rinnai Convector 417 flueless space heater from LG to NG?
with a conversion kit sold at the place that sells the heaters .
Apr 14, 2015 | Rinnai Heating & Cooling
I recently purchased a 39" Proscan TV from HH
If the remote is not programmable and DirecTV cannot supply codes you may have to use two remotes
Dec 06, 2012 | Televison & Video
I need to convert from gas to propane and I need a owners manual
Which model of range do you have? Maytag has owner's manuals for many of their appliances here: https://www.maytag.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10562&langId=-1&storeId=10212&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView . Enter the model number and click Search. Most ranges will have the serial number on a plaque below the display, on the frame of the oven (behind the oven door), on the frame of the storage drawer (visible when the drawer is open) or near the legs of the unit.
Often the conversion kit is sold with the range and is attached to the back of the range near the regulator. The instructions are in the kit. (Note this should be done by a professional. Your propane company may have a person available to do the conversion.) If the conversion kit is not supplied with the range, you should be able to order it from the manufacturer. (Some manufacturers will only ship the kit to the service person who will do the swap.)
Please add a comment with your model of range for additional information. (There are some manufacturers who do not supply conversion kits and you must order the correct range from the factory.)
The conversion is usually straight forward. Swap the regulator from NG to LP by turning over the part (it's labeled clearly) in the regulator. Using a small nut driver, swap the orifices for the cooktop. Do one at a time and check the labels. (My range conversion kit has a different set of letters on the NG orifices (A-G) and the LP orifices (L-R). Others use different colors for each orifice.) Then open the oven and swap the broiler orifice and the bake orifice. Rotate the air flow valve appropriately.
I hope this helps.
Sep 02, 2011 | Maytag Kitchen Ranges
I got a GE gas range (model JGBS22) from a co-worker. She had converted it from gas to propane. I just had a plumber hook it up to natural gas but, even with the conversion manual, he couldn't change the...
There should be a set of orifices for each burner as well as the oven and broiler. When the unit was converted to propane, these orifices should have been replaced and the ones for gas put in with the conversion kit installation information. The kit should have been reattached near the pressure regulator.
If the kit was missing the orifices, then, yes, you are missing pieces. Check with your coworker if the conversion kit was missing. If you have the kit, it can be easily done by any appliance installer (or repair person) licensed for handling NG. (At least on our range, the conversion kit installation was straight forward. Every orifice was clearly labeled with the labels different for each burner and for the gas/LP kits (ABCD (NG) vs MNOP (LP)) .) The regulator is the only part that switched for LP or NG without the kit.
As I recall, the only tools we needed for the top burners were a small wrench (10 mm) and a small flat blade screwdriver. Remove one orifice and put in the appropriate replacement. Then adjust the burners so that they didn't blow out when the oven was opened or quickly turned from high to low (for the simmer burner). The oven and broiler took a bit longer. Several screws had to be removed to get at the orifices. Then the air flow had to be adjusted for the incoming gas.
I hope this helps.
(the conversion installation manual was on the counter during installation; I read it while it was open.)
Jan 14, 2011 | GE JGBS22 Gas Kitchen Range
We purchased our LG Washer and Dryer from HH Gregg in 2006. For about the last year of normal operation our washer will not completely drain all of the water out at the end of the rinse and spin cycle. ...
Either pump is bad or something is blocking it. Did you pull filter at bottom left corner and clean it out? Look inside make sure nothing is in there.
Jan 04, 2011 | LG WM-2277HW Front Load Washer
79012 / 79014 / 79019 Gas Kitchen Range: The propane converson seems to be done right, howe...
It sounds like during the conversion process a step or two may have been missed.
The gas orifice for the main oven burner is most likely to large (was not converted to LP), or the air shutter on the burner was not adjusted. I would not use the oven with the flames that way.
There should be instructions with the installation instructions on how to convert the oven, basically on most oven burners the orifice is screwed down (tightened) until the flame is the right size, then the air shutter on the burner is adjusted for a blue flame.
Let me know if you have questions
May 05, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Haier fridge running but nothing cold
This is rare when you look at the total average of refrigerators being sold. Even the best refrigerators have defects every now and then.
Dec 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Converter
a conversion kit sold by your local appliance parts distributor. the detailed instructions are inside it.
Apr 04, 2008 | Dryers
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
151 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
