What could cause one of the signals to get stock? whenever i want to put my rigth signal it gets stock an the ligth wont turn off. and when i put my laft signal, both signals would turn on.
Interior/dashboard indicators get stuck...or the actual exterior blinking lights get stuck?Interior/dashboard indicators get stuck...or the actual exterior blinking lights get stuck?
You can't post conmments that contain an email address.
The problem could be in one fuse, bad ligth bulb, bad combination switch wich is the turn signal lever siwtch, or the combination of all this. Is the front left turn signal working, in order to find out if the turn signal switch is working check for power at the the cable in the corredpondent connector that way you eliminate the posibilty of the turn signal sitch if you have power at the connector also do the same at the stop ligth if there is no power you have problaby bad fuse, hope this help tou out.
pull out the bulb
there should be a little piece of metal that touches metal on the bulb when its plugd in
make sur that is making good contact
u mite try to bend it out a lil with a flat head but dont put to much pressure
that should work
your security system is activated. try turning the key on let set for 10 minutes turn it off then start. on some models it has to be done 3 times on off on off on off start. 10 minutes each time
Check the fuse in the fusebox inside for a blown fuse,the brake lights are working so check the plug going onto the back of the lamp for tightness,could be a loose connection.
