Question about Karcher 1750 psi Electric Pressure Washer
My Karcher 1750 psi electric pressure washer is making in/out loud noise when switch to On and idling not pressing washer trigger.
    President:
  • 2,030 Answers
Thats normal, it is reducing the built up pressure that is not needed until the trigger is pulled.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Apr 01, 2010
SOURCE:
What is this problem - Karcher 3.86 electric pressure washer: humming noise, plug gets very hot, then unit shuts down?
Your pressure washer is either not fitted with a run/stop device in which case like mine you have to switch off within a few seconds of closing the trigger. Check your model features?
The humming noise is the motor stalled out against the pump because there is nowhere for the water to go. The shutoff is caused by the safety overload switching off after overheat.
Or, it has a pressure operated run/stop which is not working. Because water and electricity don't mix, I would suggest getting more specific help. You can download Karcher manuals /spares lists online from Karcher specialists but remember electricity is the silent killer.
May 20, 2014 | Karcher Garden
I have Karcher 520m and when you press the trigger you can hear what sounds like a relay engaging but there is no water pressure, then it will fire up and work, but next time you press the trigger the...
The issue you are having is with the unloader valve in the pump. Now with the 520m it is a little bit harder to repair than with more gasoline powered pressure washers but it can still be done. It would be easier if I could just send you a email of the breakdown on the machine. Send me a email to justin@wmpcs.com with the discription of the problem you are having.
Oct 10, 2010 | Karcher 1750 Psi Elec Pressure Washer
Hunts on and off when trigger is not depressed, checked for leaks and screen, also discharge, still does it.
There could be a small bit of grit stopping the non return valve in the inlet pipe from sealing fully which would allow a pressure drop causing it to hunt. The valve may also be just plain faulty.and require replacement.
Aug 24, 2010 | Karcher 1750 psi Electric Pressure Washer
Karcher pressure washer hunts ~ off/on ~ when running. How do I fix?
HI Your machine wil start and stop if you have any external leaks when the machine is running at not pressing the trigger. Please start the machine and not pull the trigger and look form leaks. A common one is around the high pressure hose outlet and also the trigger.
Jun 11, 2010 | Karcher 1750 psi Electric Pressure Washer
Low pressure on the pressure washer
Most likely your "O" rings or seals have gotten hard and are leaking. Sorry I don't know your equipment well enough to tell you how to change them but you can most likely find the info at your manufactures web site.
May 26, 2010 | Karcher 1750 psi Electric Pressure Washer
I have a Karcher KB5050 it started to pulse when the trigger stopped
Is there water leaking from the bottom ? If so, then you have a leak in the pump. Bad seal or crack in the Pump.
If under 1 year old and have a receipt, Call Karcher for a warranty replacement.
May 14, 2010 | Karcher 1750 psi Electric Pressure Washer
The washer hunts when trigger released
hi, if you have the smallest of leaks on the outlet side of the machine then the machine will hunt.
if not that, then you have a non return in the outlet of the machine,the non return has got a little o.ring which is most probably worn.
Jul 04, 2009 | Karcher 1750 psi Electric Pressure Washer
Karcher K 3.68M Electric Pressure Washer. Wand trigger Locks Up.
Sounds like the pressure valve is broken thats why you cant depress the trigger , the valve is on the pump , i would suggest taking it to a repair shop as they are fiddly things to fix
Jun 04, 2009 | Karcher PSI Electric Pressure Washer
Losing pressure somewhere
Hi, I work in the italian factory of Karcher. In my opinion the problem is caused by the breaking of the collector. This is a black component of plastic where is inserted the detergent suction valve and the safety valve. To replace this component you have to go in a repair center Karcher.
Nov 24, 2008 | Karcher 1750 psi Electric Pressure Washer
Karcher K3.92 M 1750 PSI poweer Washer motor won't start. Followed Reset/Test/Reset sequence with cord plugged directly into outlet. Light on cord near Reset comes on when Reset pressed down but goes off...
They are sensitive to large extention cords. My father in laws pops reset when a small cord is used. If internally shorted- motor will continually pop the reset even plugged direct to outlet. Check voltage at outlet.
Jun 19, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 1750 psi Electric Pressure Washer Logo
938 people viewed this question
Top Karcher Garden Experts
John Trevino
JOHN LAPIER
Joseph Mueller
Joseph Mueller
Are you a Karcher Garden Expert? Answer questions, earn points and help others
