Question about Sony CDX-M8800 CD Player
Faceplate will not open
I just installed the sony cdx-m8800 in my car everything powers up fine, however the face plate will not come down when i hit the button. I can operate the headunit with remote but every time i try to bring the face down it attempts to bring it down but cannot.
any help.
  • 44 Answers
Perhaps something is not installed correctly physically. Sometimes if something is a little twisted the way the unit is installed it will keep it from opening properly. Try moving the unit slightly and see if that helps.
Posted on Mar 16, 2008
SOURCE:
Buttons on my sony CDX-GT540UI stopped working
Sony car radio cdxgt540ui buttons non responsive - remove four screws on reverse side of faceplate, pry open with fingernails starting at the top right or left corner of the face plate once opened remove board on the reverse side of the LCD there are small brackets holding the LCD use a needle nose to pry each bracket in straight position then remove LCD for ten seconds then place back on to board and been brackets back in place. After these steps the front buttons should work again this process worked for me.
Mar 16, 2012 | Car Audio & Video
Need the radio code for my Sony CDX-M8800 CD/Car radio to turn it on, I do not have the remote.
There is no code for this radio. Chances are it probably has a bad flexible cable that goes from the face to the main motherboard.
Apr 14, 2011 | Sony CDX-M8800 CD Player
Im trying to install my sony m8800 in the house with a pc power supply can you tell me which wire goes where many thanks
Hi:) If you want the install file for the CDX-M8800 send me a email and i will send it with return email.
[email protected]
Mar 09, 2011 | Sony CDX-M8800 CD Player
My face plate was stolen out of my truck. Thr operateing instructions say cdx-gt200 and cdx-gt20w. How do i determine the proper model without the face plate and can I order a replacement?
remove the stereo from your truck. underneath the head unit itself WILL have a model number along with serial number, wiring instructions, etc............. but be warned that Sony WILL charge top dollar for the faceplate, which in turn will have them sayin somethin like "We recommend buying a new unit as the faceplate will cost nearly the same price as a new unit". In saying that, ALL Sony car stereo wiring looms fit each other, so no need for reinstalling the wires. so if u can get a cheap one without loom, then you'll be fine
Jul 29, 2009 | Car Audio & Video
Sony CDX-M8800 face plate is non responsive
There is a ribbon cable that tells the face what to do. You will have to take it in to get serviced as it is very hard to change. There are alot of pieces / parts inside.
hope this helps
May 30, 2008 | Sony CDX-M8800 CD Player
Sony cdx -m8800
Remove the radio, disconnect the blue wire, and connect the blue/white wire in its place. This should fix your problem.
Sep 08, 2007 | Sony CDX-M8800 CD Player
Sony CDX M8800 Front Panel Problem
u need 2 replace the ribbon that goes to the panel to the unit.i had the same problem with mine then i went on to ebay and found the ribbon there (cdx-m8800 repair kit)hope this helps
Dec 17, 2006 | Sony CDX-M8800 CD Player
Sony CDX-M8800 CD Player Logo
153 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Mike Duncan
Mike Duncan
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
