Question about Brother MFC 420CN All-In-One InkJet Printer
Brother mfc 420 network
I have a network can't print from network or from local desktop printer still copies so ti works but can't find the exact name to call default i have unpluged abd restarted still no print?
  • digros Mar 07, 2009
    I tried to intstall the MFC 420 CN through my Qwest 2007HG-D and run the set up,disk on my XP based PC. The Qwest 2007HG-D sees the printer and gave it a IP address but is different then the IP address onnthe printer. So i changed the IP address on the printer to match the one on the 2007HG-D but still it does not work, On the network the printer stays invisible. I cannot ping it. The manual for the printer explains the network set up of the printer like settings and so, but I don't understand all the terms or what I actually need to do to get it working
  • 3 Answers
Have you tried resetting the lan setting to the factory default settings?
Posted on Mar 26, 2009
I don't have enough info to suggest a solution.
Here are my questions: Is it attached to a router? Did you install it on your PC as a TCP/IP printer? When you go into the printer properties, what port does it list?
Posted on Apr 06, 2008
How do I connect my printer to my wireless network
The other desktop if its not connected wirelessly they its easy. Just install the drivers for the printer on the desktop thats ethernet cabled to the router. Once installed go to start /settings then printers then on the printer in question right click it and go to sharing and share this printer on the network. But right click my computer/properties then computer name or the like and make sure all computers on the network share the same workgroup . By default MS windows uses the same name. But you can change it to any name you want to. All computers have to have the same workgroup name to share files and printers. Then on the other computer connected wirelessly go to start/settings printers and install new printer and it will ask if its a network printer or direct connect choose network printer and it wll install all thats needed. Still having Problem Then follow Us For Brother Printer Support .
Thank's
Jan 29, 2014 | Brother Compatible LC41 (3 Color Ink) -...
MFC-8870dw 30ppm Wireless Network Multifunction Laser Printer with Duplex Printing, Copying,...: How do I connect my Brother MFC-885CW printer to m...
Connect the printer with a USB cord to the computer. Switch off the printer and install the driver in to your computer , during installation the software will tell you to switch-on the . Do so and finish the installation .
This is the procedure to connect the printer with your computer.
May 17, 2010 | Brother MFC-8870dw Wireless Multifunction...
PRINTING, COPY PROPER, SCANNIG PROBLEM
u have ti install drivers again after uninstall old drivers from computer.
Apr 06, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 790CW does not print on Network
Please define several others that are close. If Brother doesn't list a Linux why would you expect it work?
Nov 06, 2017 | Brother MultiFunction Center MFC-440CN...
Networking
It isn't a network printer since it only has a USB interface (no LAN port)
http://www.brother-usa.com/VirData/Content/MFC/ModelBrochures/Brochure_MFC240C.pdf
but you may purchase a print server if you want to share the printing function on your network (only the printing function can be shared). But some multifunction printers do not work with print servers due to driver issues. There are some users on the net who were able to make this work with an IOGEAR multifunction print server.
There is one Brother multifunction network printer that you may want to check:
http://www.amazon.com/Brother-MFC-7840W-Multifunction-Wireless-Interfaces/dp/B0016ZQ566/ref=dp_cp_ob_e_title_1
Dec 11, 2008 | Brother MultiFunction Center MFC-440CN...
Error message on my mfc 420 mc
this has been written many times here in the forum.
plz search forum "unable to print"
Jun 22, 2008 | Brother MFC 420CN All-In-One InkJet...
Printing from XP to a Brother 7820N as a networked printer
We have multiple 7820s in our office. This would be a configuration problem with your windows XP computer. From the XP computer, open a command prompt and type "ping x.x.x.x" where x.x.x.x is the ip address of the 7820n. Make sure you get four successes. I would then uninstall the brother software and drivers and go to "printers and faxes" in the control panel and manually add the printer.
To manually add a network printer, with it's own print server, on Win XP:
1 Click "Add Printer"
2 Select "Local Printer Attached to this computer"
3 Deselect "Automatically detect and install my Plug and Play printer" then click "Next"
4. Click "Create a new port" and select "Standard TCP/IP" from the drop down. Click "Next". this will open TCP/IP Wizard
5. Type in Printer IP Address next to IP Address (Port name will autopopulate) and click "Next"
6. If wizard finds printer, it will show you "Finish" button. If you get a "Additional Port Information Required" window, something is wrong with your printer or windows xp network configuration.
7. When the TCP Wizard window closes, it will take you back to Add Printer Wizard. Select "Have Disk" and navigate to the \USA\WXP\Addprt directory on your Brother Drivers disc.
8. Select brxpadd.inf and click "Open" then click "OK"
9. Select "Brother MFC 7820 N Printer" from the list and click "Next"
10. Select name of printer, whether you want a default, print test page and DONE!
Jun 12, 2008 | Brother MFC-7820N Printer
MFC-440CN: Prints but does not scan
Go to system/computer control panel, select "scanners and cameras". you should see your brother system in there (if u were able to print to it but not scan). Right click on it, select properties, and select "Network Properties" Tab. Choose select "specify your machine by address" rather by "by name". Most home/home office users dont have a local domain server at home, so even though your printer was named, it cannot be located by tcp-ip using the name, but rather by ipaddress. This solves the issue.
Feb 02, 2008 | Brother MultiFunction Center MFC-440CN...
Printing is streaking
What exactly did you clean on this machine? Also, when you say it streaks, is it when you're printing or making a copy?
Jun 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
156 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
