Question about Ricoh Aficio 1035 Copier
Finisher keeps acumilating print jobs assuming they are not separte ones.
We have a RICOH MP1100 (110 ppm) with a fnisher and booklet maker set up. We are sending 8k+ print jobs to production. Print jobs have 2 - 12 pages each and they are stapled by printjob. All of a sudden a print job sits in the finisher as well as others coming behind it and they dont' move ahead.
Does the file it's self have something to do with this situation? (Do I have to look into the pdf... code? ) Is it a problem at hardware level, firmware (we updated all) it happned before we changed from RCPS to PCL and thought it was fixed; now it comes up again with no apparent reason.
Like to know if it's a hardware or software issue and how to proseed.
Thanks'
Ruben Cordero / [email protected]
It is possible that the hard drive in the copier is about to fail. Has it gotten worse??
Posted on May 27, 2008
SOURCE:
I have changed my toner, and keeps on sending misfeed of paper, and now it states SERVICE CALL SC650 ???
You need to call Rich, and tell them what service call you get. They will tell you exact, what to expect. If you can solve the problem yourself, they will tell you, but most likely they will tel you you need a service technician.
Oct 20, 2014 | RICOH CORPORATION Ricoh Aficio SP C242SF -...
How do I reload staples into my Xerox WorkCentre 7530?
You did not indicate finisher? Xerox MFPs' come with the most finishing options of any manufacturer.... I included instructions for all of them below. Enjoy!
Solution : Load Staples in the Professional Finisher With Booklet Maker The stapler in the booklet maker uses two Staple Cartridges labeled R2 and R3. Booklet stapling requires that both Staple Cartridges be free of jammed staples.
WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the printer has stopped copying or printing.
  2. Open the Finisher Front Door.
  3. Squeeze the orange R2 and R3 levers together and pull the Staple Cartridge unit out of the Finisher until it stops.
    NOTE: The Staple Cartridge unit does not detach from the Finisher.
  4. Grasp the orange tabs on both sides of the Staple Cartridge and lift the cartridge out of the Staple Cartridge Unit.
  5. Push the new cartridge into the Staple Cartridge Unit.
  6. If no jammed staples are found, repeat step 4 - 6 for the other Staple Cartridge.
  7. When finished, return the Staple Cartridge Unit to its original position.
  8. Close the Finisher Front Door.
Solution : Load Staples in the Main Stapler of the Professional Finisher NOTE: Using Staple Cartridges other than the recommended staples may impair quality and performance. Only use only Staple Cartridges recommended for this Finisher.
  1. Make sure the machine has stopped copying / printing.
  3. Grasp the orange R1 lever on the Staple Cartridge and push it to the right.
  4. Grasp the orange tabs and pull the cartridge out of the Finisher.
  5. Check inside the Finisher and remove any loose staples.
  6. Pinch both sides of the staple case and remove the staple case from the cartridge.
  7. Insert the front side of the new staple case into the Staple Cartridge, then push the rear side into the cartridge.
  8. Grasp the orange tabs on the cartridge, and then insert the cartridge into the Finisher until it click into position.
  9. Close the Finisher Front Door.
Solution : Load Staples in the Booklet Maker of the Optional Office Finisher LX NOTE: The Booklet Maker uses two staple cartridges. Booklet stapling requires that both staple cartridges contain staples.
  2. Open the Finisher Side Cover.
  3. If the Staple Cartridges are not visible, grasp the vertical panels to the left and right of the opening and slide them to the center.
  4. Hold the tabs on both sides of the cartridge and pull the cartridge out of the finisher.
  5. Hold the tabs on both sides of the new cartridge and insert it into the original position in the Finisher.
    NOTE: If you have trouble inserting the cartridge, make sure the staples are positioned correctly in the cartridge.
  6. Starting at step 3, repeat the procedure for the other cartridge.
  7. Close the Finisher Side Cover.
Solution : Load Staples in the Integrated Office Finisher WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the machine has stopped printing or copying, then open the Front Cover on the Integrated Office Finisher located under the Scanner Assembly.
  2. Remove the Staple Cartridge by grasping the cartridge by the orange handle and pulling it straight out of the Finisher.
  3. Remove any loose staples inside the Finisher.
  4. Pinch both sides of the staple case and remove the staple case from the cartridge.
  5. Remove the new staple case from its packaging and insert the front side of the case into the staple cartridge. Push the rear side into the cartridge. The cartridge will click into place when it is installed correctly.
  6. Grasp the cartridge by the orange handle and insert the cartridge back into the stapler until it clicks into position.
  7. Close the Front Cover.
    NOTE: If the Front Cover is not completely closed a message will be displayed. The machine will not operate if the cover is even slightly open
Nov 18, 2013 | Xerox WorkCentre M-24 Color Copier
How to use booklet maker
The HP booklet maker/finisher with output accessory bridge provides two 1,000-sheet stacker bins and a booklet bin with stapling, saddlestitching, and v-folding capabilities.
Sep 06, 2012 | HEWLETT-PACKARD Q6999A Finisher, Mailbox...
We have ricoh aficio mp c4000, when i make copies and select colate it goes to the the side tray and separates each one with but when i print and select colate it prints all the documents to the tray under...
You have to set it in the print driver.
When you make print go to properties and select colate. If you do that it should go to the finisher and separate the jobs.
See you!
May 09, 2011 | Ricoh 4506 Copier
Can't print color or use finisher on our network ricoh from Mac
Sounds like you may not have the correct driver installed and also not configured right for devices
Dec 29, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Good Morning, We have the Ricoh Pro 1106EX Copier. Is there any way to print more than 10 booklets at a time? Any way to increase the amount? Very time consuming to stand and remove booklets all day....
the problem is that the finisher youhave can only hold so many copies the sensor that indicates the tray is full is stopping the run. yu might be able to put the switch up and then tape it in place but you will still have to take the booklets out some time..
Jul 29, 2009 | Ricoh Office Equipment & Supplies
I am working with a Ricoh Aficio 3260 machine. I have been sent a 20-page Publisher document laid out in Landscape, each page is set up as 8.5 x 5.5. I want the Ricoh to produce a booklet stapled...
Well, I don't have a document in that format exactly to play with, but assuming you are using the PCL 5c driver, it should be a fairly simple task. If your using another driver (ie: RPCS) then it will be similar, just a little different looking dialog box.
Open your document, Select "Print", select "properties", you can change the "orientation", and "layout" (pages per sheet), 'duplex', and staple (assuming you have a booklet finisher installed and configured in your printer properties). There is an icon in the left corner that changes with the settings and should help you with the them. Obviously, you should only print 1 set, or even just a page or 2 to check the output. These types of things are always a bit of trial and error until you have done it a couple times. I hope this helps
Mar 06, 2009 | Ricoh Office Equipment & Supplies
Finisher Installation for Ricoh 2051
open the properties of the print driver and click on the accessories tab. from there you can check off the accessories you have. if you are not sure which finisher to check off, print a configuration page from the machine and the kind of finisher will be somewhere on the top of the page
Feb 16, 2009 | Ricoh Aficio SP-C210SF Printer
Printing a Booklet on a Ricoh Africio 3260C
first you need to use the RPCS printer driver supplied by ricoh. Second then go to printer properties box and then select the tab for finishing, you should then see the options for booklet printing, if the option are not there you have to add the finisher in the printer driver as an option
http://www.websitetoolbox.com/mb/copierquestions
Oct 01, 2008 | Ricoh Aficio CL7000 Laser Printer
Ricoh Aficio 1035 Copier Logo
57 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
