Question about GE Profile Spectra JGBP90 Gas Kitchen Range
LG gas oven
We have a oven LRG30855 that came with the house, (new home)
the people that sold the appliances will NOT convert them, to LP,
I am a heating contractor, I managed the dryer, But the Instructions were missing for the Oven, I got the burner orfices changed the regulator, conversion turned over and adjusted the Top oven burner nut down (i have done this before) I hope its still done this way, But there was a Long oricie, that was left over I didnt see where it goes,, and All works, (except) the lower oven burnwer? the flames that come from the bottom are all yellow and very high and it does sute up the oven,, What am I missing? please help,
  • 4 more comments
  • want2cook Mar 15, 2008
    the manual says to see the conversion instructions that were supposed to be with the orifices, on the back of the stove, the orifices are there but the Paperwork is missing
    no capabilty to send photo,, IOts just like the other orifices, except this one has an extension of some sorts,
    the orifices were attached to the back of the range, just like the manual said, but No paper work
    no literature, and I couldnt see were it might go,, any ideas, as to how to access the bottom burner? and also is the sute going to be able to get cleaned up?
    need help with converting a gas range to LP, I have the orfices that were attached to the back of the range but there is no paperwork,, IE: no Instructions
    kit was attached to the range,, and no connecting hardeware,,
    President:
  • 1,314 Answers
And you say you took the nut off the top of the regulator and flipped that piece over as to the burner tube you can get to it from the inside the oven remove the racks then should be a couple of screws there remove them then you will see a flame spreader there remove that and you will see a burner tube remove that and you will see the safety valve with the office and soap and water should clean up the soot
Posted on Mar 15, 2008
    Genius:
  • 1,665 Answers
Hi Have a nice day!
You can try also the link here (Insert your model number at search tab) It Helps to parts detect.
  • 1 more comment
  • Anonymous Mar 15, 2008
    Write " LRG30855 " in search space, and then select Part Type you need.
    Download also installation manual There is a lot of usefull information here.
    Post a new comment with results.
    i.e
    6. CHECK IGNITION OF SURFACE BURNERS
    Operation of all cooktop and oven burners
    should be checked after the range and gas
    supply lines have been carefully checked
    for leaks.
    ELECTRIC IGNITION
    Select a top burner knob and simultaneously
    push in and turn to LITE position. You will hear a
    clicking sound indicating proper operation of the
    spark module.
    Once the air has been purged from the supply
    lines, burner should light within 4 seconds.
    After burner lights, rotate knob out of the LITE
    position. Try each burner in succession until all
    burners have been checked.
    QUALITY OF FLAMES
    The combustion quality of burner flames needs
    to be determined visually.
    A Yellow flames
    —Call for
    service
    B Yellow tips on outer
    cones
    —Normal for LP gas
    C Soft blue flames
    —Normal
    for natural gas
    If burner flames look like A, call for service.
    Normal burner flames should look like B or C,
    depending on the type of gas you use.
    With LP gas, some yellow tipping on outer
    cones is normal.
  • 796 Answers
Here is the manual for your product
see whether you can figure it out here...
thankyou
    Guru:
  • 1,894 Answers
sir please go by the service manual sir...
    Genius:
  • 3,587 Answers
Ahhh..so..let me get this accurately..most of the conversion works, but there's a extra part(oricie???)..that's hanging around? Got a picture of that, by chance?
sounds like the missing piece to the puzzle, amigo.
  • 1 more comment
  • Patrick Michaels
    Patrick Michaels Mar 15, 2008
    ok..so, where did the conversion kit come from?
  • Patrick Michaels
    the long orifice is most likely going to the bottom burner. If it's NOT connected, then you'll find it's not going to work. What's the story with that orifice? No connecting hardware for it?
  • Patrick Michaels
    you mean the grease and grime at the bottom, or other places? Sounds like you have your hands full. Still need to know where you got the conversion kit, amigo..
6ya staff
SOURCE:
Tip
Changing your gas appliance from natural gas to LP or vice versa.
You have an LP gas stove which you really like and would like to take to a new home but the new home has a natural gas hookup. Since natural gas is already available it would be convenient to be able to use it. Can you convert your unit over to work on natural gas?
Yes it is possible to convert any LP gas appliance to natural gas or from natural gas to LP. The only difference is the size of the orifice used in the burner.
LP gas is composed of a much larger molecule than natural gas and requires a larger orifice to output the same amount of gas as a natural gas unit at the same setting. Therefore if you used an LP stove on natural gas it would produce too much heat and burn rather intensely. If you used a natural gas stove on LP it would not have much flame at all. You can see the problem. The solution is also obvious. You need the correct orifice.
Changing the orifice is easy. It is located in the middle of the burner and unscrews out of the unit. Install the new one the opposite way. Do not overtighten it.Usually the burners are made of soft metal and can strip easily.
The parts you would need are available at most good appliance stores but I would recommend the following site http://www.repairclinic.com . The parts will be cheaper at repairclinic. They have parts for almost any brand and a great search engine. They also have excellent videos showing how to make the repair.
Thanks for using FixYa and for the great rating.
hardrocko
on Dec 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Convert maxitrol regulator#rv47cl natural to propane gas
Some gas ranges cannot be converted. If your model can be converted it normally requires flipping over the regulator diaphragm and also changing orifices for all burners, surface and oven. Most modern new appliances come with the LP orifices located on a card attached to the regulator.
Nov 18, 2013 | Kenmore 72132 / 72134 Gas Kitchen Range
I have a duke e101-g oven and I want to convert it to propane what should I get?
Generally, when you wish to change the fuel for a gas appliance all you have to do is change the orifice. Most appliance dealers will be happy to order a LP orifice for your oven for you.
lp
Dec 30, 2010 | Duke E101-G Gas Single Oven
Convert to lp gas
You will need the owner's manual to follow their LP conversion instructions. You will need the make, model and serial # in order to buy the LP conversion kit (if needed) from a local appliance parts store or from the store where you bought the appliance. Typically, you will be either adjusting (turning down) or exchanging the main burner orifice(s), as well as adjusting the air shutter on the burner venturi tube, as needed for a bluer flame. The appliance regulator will need to be converted, which is usually done by flipping the cap. If you don't have your owner's manual, leave another comment for me with the model # and I'll see if I can find it online for you. I have not worked on this particular type of oven in my neck of the woods, but ovens are all pretty similar in design. Some also have a thermostat that needs to be converted by turning the Nat to LP selector behind the temp dial. Hope that helps. Douglas
Jul 20, 2010 | Imperial ICV-1-H Turbo-Flow Electric...
Need to adjust from L.P. to N.G.
Hello. no problem. to convert your appliance from liquid propane to natural gas you will need a set of appliance brand and model specific orifices that are for natural gas only. Contact your new natural gas provider and tell them your oven brand and model number. If they do not have the exact orifices you will need, they can order them for you and they may even come to your home, convert your oven and hook it up for you. Just ask.
Nov 24, 2009 | Cars & Trucks
How do i change from lp gas to natural gas on wall oven
First thing you will need to do is find out from the manufacturer of the oven if there is a conversion kit available and if the appliance is convertable. If there is then you can order the kit and follow the installation instructions. Also check the back of the oven for an envelope that may contain the gas orfice replacement heads to convert the appliance to natural gas. If you find the replacement orfice then you will need to remove the lp orfice from the burner and install the natural one. Then the appliance gas regulator will need to have the pressure adjusted lower for natural gas. There is usually a removable cap on top of the regulator on the oven. When you remove this cap there is usually a small metal ring that you can remove and flip over. It will say "nat" on one side and "lp" on the other. You will need to turn this ring over and re-insert so it displays "nat". This will change the gas pressure from 13 inches W.C. to 4 inches W.C. Some appliances only require the orfice change and no regulator adjustment but make sure that is the case with your oven because if you feed 13 inches W.C. pressure to a burner with a natural gas orfice...YOU WILL GET A HUGE BURNER FLAME AND MAY BURN/FLASH YOURSELF...So use extreme caution when converting a gas appliance. And if the oven has a pilot you will need to adjust the pilot pressure or change it's orfice if it has one. If it is electronic ignition no adjustment to that will be needed. Also unplug the electrical power the the unit while working on it.
Oct 11, 2009 | Ovens
CONVERT FROM NATURAL GAS TO PROPANE GAS
Pat, it is very important that all appliances that used natural are guaranteed to be LP Gas approved. Fact is natural gas uses about 1/4 oz. psi where Lp Gas uses 8lbs. to 13psi
This is critical that the person doing the work has experience in converting the two types to prevent fire or property damage. I hope I helped answer your question, let me know if this works out for you. Thanks, Sea Breeze
Feb 01, 2009 | Vulcan SG44D Gas Double Oven
Vermont Casting Radiance Gas Stove (RUVSOD) NG to Propane (LP)
Unfortunaletly, due to the delicate nature of vent-free appliances, you'll find that most are not field convertable. If the vent free appliance were to lose its efficiency, you would be subjected to high levels of CO, carbon monoxide, and could likely die. Therefore, field conversion is not recommended and in this case, not possible. Vermont Castings does not provide parts to convert and if they did you would be essentially replacing the entire unit short of the outer cast shell. I wish you luck.
Dec 22, 2008 | Heating & Cooling
Oven conversion
the lower oven bake burner should also have an adjustable hood to turn down, 1/2 or 9/16 open end will do it, as long as flames look ok youre alright, but def find and turn down the bake adjusteryou might nned to remove the storage drawer to acess
Mar 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
125 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kitchen Range Expert? Answer questions, earn points and help others
