Question about Microsoft Xbox 360 Console
1 red light on 360
My 360 had 1 red light on, lower right. did come up with error e68. but works ok when i remove the harddrive. any way to fix without replacing the drive. don't want to lose all my saves
hellllppp!!!!!
  • 85 Answers
Make sure that all of the pins for the harddrive are lined up properly, and make sure that they aren't bent at all. If that doesn't work, it may just be a faulty drive, in which case you will probably have to replace it(the hard drive).
Posted on Mar 15, 2008
SOURCE:
I was watching net flicks and my xbox rebooted and flashed a red ring (bottom right) and it said E68. i shut it off and started it up again and works<did that twice<the unit was alittle hot...
The e68 error on your Xbox 360 is caused by a hard drive/HDD problem. It can be caused by an internal connection error with the hard drive, a general failure of the hard drive, or overheating of the hard drive. Basically, there is quite a large range of things that can cause the Xbox 360 e68 problem, which can make troubleshooting the issue slightly difficult.
To fix the e68 code on your Xbox 360 is to remove the internal hard drive and try playing your console without it. If it then works, then you can be sure that you can permanently fix the problem. If not, then you will have more serious issues on your console that will need to be checked over by Microsoft, as the e68 is generally believed to be related only to your console's hard drive/HDD.
Hope this helps.
Mar 06, 2011 | Microsoft Xbox 360 Console
Red light at right bottom plus on screen it says e68
E68 is a harddrive error. Remove the harddrive and try it.
Jul 10, 2010 | Microsoft Xbox 360 Console
E68 error code
try removing the hard drive and see if the xbox plays without it.
error 68 could be internal fault or external but is a harddrive fault.
if it plays without the hard drive, you need a new hard drive.
if it still does not work with the hard drive removed, you may have an overheating problem.
this could be fixed by you by following many of the online guides or if you have a warranty maybe microsoft will fix it? the 3 red light fix will fix most red light errors. i would suggest upgrading the fans too if you plan on fixing it yourself.
May 27, 2010 | Microsoft Xbox 360 Console
Red light is flashing on the right lower quadrant. also, a system error note is seen on the screen.
is the error code e74 or e68,if its e68 take harddrive off and turn console on and should work,if its e74 your console needs fixing,if its still in the 3 year warranty microsoft will fix for free if over 3 years then buy an xclamp kit and go to youtube for videos how to do this repair,dont do towel trick,you will do more damage to console
Mar 21, 2010 | Microsoft Xbox 360 Console
The xbox has a flashing red light in the bottom right corner.the tv says E68
maybe try bringing it to the shop you bought it in and they ould tell you the problem or they will send it to the xbox company to get it fixed or if all else fails they will give you a new one!
Only if it is still in its guarentee and if you have the guarentee. if you don't have the guarentee or its too late for that you can look online for a solution! i mean like you can find anything on google!
hope i helped! bye!
Feb 27, 2010 | Microsoft Xbox 360 Console
X box360 flashing red light
Where is the flashing light? If it is at the 3rd position (bottom right) only, then the screen should say E68 error. If this is true, turn off the system, take off the harddrive, put the harddrive back on and turn the system back on. This happens to mine frequently. If its 3 of the lights, then you are out of luck my friend. Red Ring of Death...
Feb 19, 2010 | Microsoft Xbox 360 Console
System error E68 - red light on not able to play
E68 is a problem with your harddrive, try taking out the harddrive then trying the xbox, if it is still sealed phone up mircosoft
Jan 24, 2010 | Microsoft Xbox 360 Pro System Console
E68 XBOX 360 ERROR
call them back and tell them the three red lights are on and they will replace it with a refurb.
May 15, 2009 | Microsoft Xbox 360 Console
Error code E68
probably a corrupted file call 1-800-4myxbox they will give all the details on how to fix it :)
Jan 30, 2008 | Microsoft Xbox 360 Console
Xboxe 360 console arcade
you got the red lights of doom #1 suggestion make sure your harddrive is plugged in all the way #2 make sure all cables are pluuged in if thats not it go onto the web fin da video of how to get three red light instead of one nd send it into microsoft becuase your warranty cover three lights not 1 or 2
Jan 02, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
48 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
