Question about Hawking HWREG1 Repeater
Assign address manually
Even when i get the ip config off of cmd it is still not the correct one
  • giniasolino Mar 18, 2008
    yes i can see the ip address from my comuter i can go to cmd and put in ipconfig/all and put in the ip address manually
    it still dont work
Check to see if your windows machine is on the same subnet (255.255.255.0) as the extender. Had this problem with my mac, when I had the DHCP assign my ip address, it set the subnet to 255.255.0.0, and for some reason this setting would not allow me to connect.
Posted on Apr 12, 2008
All i know is when i ask my windows to automatically conect to hawking network it says my ip address does not match the devices. I try to reasign the ip address and it falls. I think the problem is i have windows vista and the device is not compatible with my windows. I tryed downloading a Ralink a ware up grade or something did not seem to help. I am ready to give up and just take the product back lol.
Posted on Mar 19, 2008
    Genius:
  • 3,587 Answers
Hmmm....so, how is the IP address NOT working for you? Can't see it from your computer? A bit more detail please..
Posted on Mar 15, 2008
SOURCE:
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
Connection using ip address for bizhub 350 from desktop
If you want to check the connection from desktop ten follow this.Click on start menu.In run, type cmd and press ENTER.Now in dos mode type ping>space>ip address of machine which you want to check. press enter.If it shows TTL=32 or ttl=64 then it means OK.Your machine is connected with desktop.
Now if you want to put your machine on network and want to assign IP to machine then do these steps1-Connect the network cable to machine.2-Assign an IP to machine.3-To assign the IP, Simply press "Utility/counter" button.4-press "check details" button on LCD panel.5-Now press Admin management.6-Enter password. 123456787-select ADMIN 28-select Network settings.9-Select DHCP.set it to manual instead of auto obtain.10-Now assign the IP in IP address option and after entering correct free ip restart the machine.
Jan 17, 2012 | Minolta bizhub 350 Black and White Copier
Hi there, Mine is a wifi problem.. at home or at a couple of other places I've tried, my Aspire One connects no probs. At work, it constantly tries 'Acquiring Network Address', and on going...
Plug LAN cables or turn ON Wifi.
Enter Run command or type cmd.
on the command prompt screen ( black it is ) type:
ipconfig /release
enter
next type:
ipconfig /renew
enter
type exit
NOTE: if the problems still remains,which means the router use a STATIC ip eg.192.168.1.5
( CONFIG INTERNET PROTOCOL TCP/IP = ip address : 192.168.1.5 subnet mask :255.255.255.0 default gateway : 192.168.0.8 )
[email protected]
Aug 16, 2011 | Acer Aspire One Netbook 8.9" Notebook
Error code 52100
Hi there! There are a couple options you could try to solve this problem!
To solve this error :
I would first check Nintendo's special notes router infomation page located here.
  • If you can't locate your router on Nintendo's special notes router information page, log into your router and change the basic rate to 1-2 and the transmission rate to 2. Try to connect again.
  • You can try to manually assign an IP address to the Nintendo DS as another device may be sharing the same IP address of the Nintendo DS.
  • To manually assign an IP address to the Nintendo DS, on a PC click Start > Run > type CMD and press Enter > type IPCONFIG/ALL and press Enter. On Windows Vista, click Start > type CMD in the Start Search box > click on CMD icon > type IPCONFIG/ALL and press Enter. The IP address for the Nintendo DS must be 10 digits higher than your PC, for example 192.168.1.200 becomes 192.168.1.210. Also make sure that the correct DNS is the entered under the DS manual settings.
Hopefully one of these options is your answer and you can easily fix your problem! Good luck! If you need any further assistance I would suggest calling Nintendo at 1-800-255-3700.
Jun 03, 2011 | Nintendo DS Lite
We currently have benkin wireless in th home but for some reason can't get it to hook up on two other computers in the house. What should we do
Before you do the steps below make sure your Networking Interface Card (NIC) is working. You can find out this by typing 127.0.0.1 in command prompt (to bring command prompt type cmd in the RUN command)
Step 01: type ncpa.cpl on the Run command
Step 02: Right click the network connection and navigate to the properties.
Step 03: Under Networking Tab select the Internet Protocol IP v 4 click property button right underneath it.
Step 04: Under General make sure to click the Obtain IP automatically and Obtain DNS automatically. This allows your belkin wireless router to assign IP address dynamically.
Step 05: Open your web browser and type 192.168.1.1 (usually this address is your default gateway if not 0.1 or 2.1 on the address) and access the belkin router.
LAN settings: IP address should be your default gateway address and subnet mask will assign automatically if not type 255.255.255.0 on the subnet mask section.
Make sure DHCP (Dynamic Host Config Protocol) is on and assign IP pool from next address to starting address and ending usually 254 or 100)
Start 192.168.2.2 End 192.168.2.100
Lease Make sure DNS are assign automatically.
ignore above steps if they are already assigned.
once you finished reboot your computer (you dont have to do this)
Now open browser enjoy.
If you still dont get internet you must check your cabling with ur router to pc. or different port
Thank you Visit www.somdtech.co.uk
Sep 12, 2010 | Computers & Internet
How to open NAT on router
To open NAT
On the Windows Desktop, click Start.
2 Select Run. The Run window is displayed.
3 Type cmd /or/ command and click OK.
4 On Command prompt window (black screen) type ipconfig
5 Check the Default Gateway (192.168.?.?)
6 Open IE - on the address bar type http://192.168.?.? enter
It will open the router page
Gateway > LAN — nat config Page
Check Page No 47 on the Manual
Check the Manual
SBG1000 Wireless Cable Modem Gateway User Guide
Enable NAT If enabled, the single HFC IP Address (public IP address) assigned by the cable service
provider is mapped to many private IP addresses on the SBG LAN.
Jan 04, 2010 | Arris SBG1000 Wireless Cable Modem Gateway...
How to know the MAC address of my infoprint . In the config menu I got one but contains only 5 groups
If the printer is configured and has got a TCP/IP address, you can get the MAC mapping from any Windows PC in the same network like this:
Start -> Run Command -> enter "CMD" and press Enter -> type the command, PING ip.addr.of.printer (enter) and then ARP -a ip.addr.of.printer (enter).
If your network's IP addresses are centrally managed, ask your system administrator if it's possible to temporarily assign a fixed IP address for diagnostic purposes, then assign that address to the printer and do as described above.
Oct 30, 2009 | IBM Infoprint 1622 Laser Printer
Netowrking
DHCP (Dynamic Host Config Protocol) is a protocol that will automatically assign an i/p address (TCP/IP) for network connectivity. The other type is Static I/P which would have a "static" i/p address assigned. If you go to Start/run, type in cmd and then ipconfig /all to see if you are connected via DHCP or Static I/P. Some apps need a static i/p, and this can be accomplished if you edit the hosts file on c:\windows\system32\drivers\etc but you would need expert help with it.
Jul 26, 2008 | Computers & Internet
I cant log into my router even though I am using the 192.168.1.1 subnet mask
Go to run type in cmd a dos prompt will appear.
type in ipconfig /all and check your ip address. Chances are your ip address is 169.x.x.x which is an internal ipaddress. You will need to manually assign an ip address To do this go to my network click on view connections right mouse click the lan icon then go to the tcp/ip config and manually assign your ip address.
It needs to be the same subnet as your router so use 192.168.1.xx anything but 1 then you should be fine.
good luck
Jan 13, 2008 | NetGear WGR614 Wireless Router
Hawking HWREG1 Repeater Logo
248 people viewed this question
Top Hawking Computers & Internet Experts
WTF Chuck.....
WTF Chuck.....
Marvin
Marvin
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
