Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Samsung blinking lamp light - nothng else
The color wheel in my Samsung 56” DLP crashed a few months ago. Yesterday I finally got the replacement and installed it, following pictorial instructions I luckily found on the web. I was very careful and made sure all of the connections were replaced as I re-assembled the TV. On the first startup I got audio, but no picture, just a blinking lamp light on the front power button. After unplugging and re-starting, I get nothing at all except for the blinking lamp button; not even any sound from the fan, so nothing is starting up. The projection lamp was working fine when the color wheel died (it is about four or five years old though). Before I spend several hundred bucks on a replacement lamp, I want to know if there may be some linkage between the re-installation of that color wheel and the failure of the TV to startup. I can’t get to any kind of service menu because there’s no video at all. Any ideas about what might be going on? Thanks
  • clayc Mar 16, 2008
    Hey luckster5,
    Thank you sooooo much! Reversing that little ribbon cable brought the picture back. However, the video came up with a full-screen message saying something like "The system has been shut down because of overheating. Check the vents in the rear of the set" etc. Do you or anyone else out there have an idea of what might be causing that? Thanks ahead of time for anymore sage advice. I love this site.
    Clay
  • 29 Answers
Check the ribbon cable coming from the color wheel, if you plug it in backwards it will do this.
Posted on Mar 15, 2008
Replaced the lamp bulb on my samsung HLP5663. It went on right away. Though the problem was fixed. Turned the tv on a little while ago and the picture is gone. The timer light is blinking. Any ideas what's...
Now tv turn on.Hear alots of clicking or squiling,loud motor noises turn on?Alot of clicking,the Ballast board it dead,this board help ignite the projection lamp.Tv also have a colors wheels.The colors wheel is dead,if hear squiling noises,loud motor noises.
Jul 14, 2010 | Samsung DLP HL-P5663W 56" TV
I have a samsung dlp when i plug it in i see the fan go on and also here a hum is that the fan or color wheel? andy way the lamp goes on and no picture. the lamp light is on in front. how do i know if it...
Check this link it may help - also if your lamp is trying to light you should see some light and hear a sparking noise from the board (ballast board with spark gap lighting)the lamp is plugged into (internally).
Samsung Color Wheel
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Nov 06, 2009 | Samsung DLP HL-P5663W 56" TV
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV has lot picture. Makes a Humming sound
That sounds most like the color wheel,
to change that you need to have some skill in electronics, I would recommend to take it to a shop
Apr 25, 2009 | Samsung DLP HL-P5663W 56" TV
TV won't stay on
Hello Fonzell!
Regarding the tv turning, my question is, do you hear a clicking sound? if so, it's most probable tio be your ballast, that might not have enough voltage to keep on with your lamp, and that's why it shuts off.
You could try replacing it and seeing if it resolves your issue, I believe they're running around 70 dlls..
have a great one ! :)
Apr 21, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HLM-617W/XAA
with lamp out (door closed) the ballast should "strike" or give an arc sound, trying to fire the lamp. If it does not do that maybe the color wheel is not spinning up - has to do that first.........then the set will try to fire the lamp
Jul 18, 2008 | Samsung DLP HL-P5663W 56" TV
Won't turn on
Make sure that you have the orange flat cable turned the right way when you plugged it in. I accidentally turned one the wrong way and that was the response I got. Hope this is all it was if this does not fix it I would measure the ballast and make sure the 200 or so volts is coming across.
Feb 07, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
396 people viewed this question
Jerry Greenberg
Jerry Greenberg
