Question about Motorola Mobility HS820 Consumer Headset
NOT PAIRING ANYMORE
I WAS USING THE HEADSET(motorola hs820 ) WITH MY PALM 680 FOR A WHILE AND NOW IT WONT PICK IT UP ANYMORE ive tried many times
  • 679 Answers
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select HS820 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Posted on Jan 22, 2009
When i try to pair it the bluetooth and my phone wont pair!!!The Bluetooth device is the HS820
Follow these steps to pair your phone with the bluetooth device.
Pairing
With the headset and phone close together:
1 With the headset off, hold the Multifunction Button until the LED remains on (about 5 seconds).
2 Perform a device discovery from the phone. For details on device discovery for your phone, refer to the phone’s user’s guide.
When the scan is complete, the phone displays the devices found.
3 Select the Motorola HS820 from the discovered devices list and confirm following the on screen prompts.
Action
4 When prompted by the phone, enter the passkey 0000 and confirm to pair the headset with the phone.
The device ID is now stored in the phone’s memory.
Pairing is successful when the headset indicator flashes rapidly.
If helpful, please rate this solution.
Thanks
Apr 12, 2010 | Samsung SGH-e315
Passcode
The Motorola H700 has Bluetooth v1.2 which is backward compatible with v1.1. The headset works with both Hands-free and Headset profiles and is easy to pair with devices running various operating systems and software. We tested the headset with the Motorola SLVR, Palm Treo 650, the Nokia 9500, the Cingular 8125 and the Cingular 2125, and the headset paired with all devices with ease. To pair the Motorola, turn off the headset first then hold the Call button until the LED ring turns purple, quickly open the boom so that the LED stays solid purple, the headset is now in pairing mode. Use your mobile phone to discover and pair with the headset using “0000” as the default pass code. Call handling between the phone and the headset transferred smoothly and the headset will play notification or a ring tone when a call comes in. When working with the Treo 650, the H700 has an uncomfortably long delay in notifying an incoming call. It starts to ring after the Treo 650 has already ringed 2-3 times. The connection between the phone and the headset is solid. When we paired the Treo 650 to both the Motorola H700 and the Parrot 322 car kit, we can pick up calls on either one and the Motorola H700 worked reliably in this set up.
Hope I helped Dr Reed
Apr 06, 2010 | Motorola Mobility H700 Wireless Headset
After charging my HS820, the light stays on, no matter what I do, and it is supposed to be in sync mode, but it won't sync with my Samsung, but my other Motorola headsets do!
You need to disconnect it from the charger and keep the button pressed to put it in pairing mode, then associate with the phone with the PIN 0000.
Jan 29, 2010 | Motorola Mobility HS820 Consumer Headset
Pairing Motorola HS820 with Blackberry 8310
there is really no fail safe method to pairing a bluetooth device.
The main thing is recognition. i,d suggest trying to press the different buttons on the transmitting bluetooth device, whilst attempting to pair. i.e volume up/down or on/off et,c. to enable the device-blackberry to find and sync. i,d think the device that needs to be configured or setup correctly is the blackberry rather than the bluetooth device.
try changing the phone settings. to accept all incoming signals on bluetooth, or disable encryption.
hope this helps.
Mike @ Compurepair.
Oct 06, 2008 | Motorola Mobility HS820 Consumer Headset
Wont hook up to PS3
Alll it says in the manul under Pairing: Charge for 2 hours before use
Step1: When the headset is off, press and hold the mutlifunction button until the headset indicator turns on permantly
Step2: Perfrom device scan from the PS3 in this case.
Step3: Confirm Motorola HS820 in the list discovered by ps3 and confirm.
Step4: When requested to enter Passkey enter:0000
Jan 06, 2008 | Motorola Mobility HS820 Consumer Headset
Motorola hs820
you have to press and hold the button for a few seconds, it will then flash 3 times and then stay solid blue, this is now in pairing mode, get your phone to find the headset and then pair usually with the numbers 0000, then thelight will flash then it is paired.
Sep 30, 2007 | Motorola Mobility HS820 Consumer Headset
Motorola HS820
the always on light mens that it is in pairing mode and wont go out until it has paired with a phone, if you wish to turn it off, press and hold for 3 seconds, it will then flash 3 times and then go off. Try pairing again by pressing and holding the button until the light stays on.
Jul 10, 2007 | Motorola Mobility HS820 Consumer Headset
Samsung e900 pairing
if you press the power button and hold until the blue light stays on the set is then in find mode, at this point use your phone to search for new devices and when it finds it it will see the HS820 and probably ask for a pin number this is 0000, when they are paired the blue light will flash and then flash intermitently from then on.
May 26, 2007 | Motorola Mobility HS820 Consumer Headset
Motorola Mobility HS820 Consumer Headset Logo
128 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
