Question about Sony Ericsson K510i Cellular Phone
Gaming problem Phone is get hanged when few game is exited & it doesn't get switched off. When battery is opened and set it again & afterthat pressing the power button is get switched on.
    Problem Solver:
  • 5 Answers
Try using the handset without the memory card if still the same perform reset settings in settings.
Posted on May 18, 2008
SOURCE:
My game in pokemon ruby always hang up during save
Well, there Could be about a few Occurences....But the Main thing is that the Internal battery ( Which Runs the internal Clock) Has Ran Dead, and Needs to be replaced.
Apr 06, 2012 | Pokemon Ruby for Game Boy Advance (GBA)
It's doesn't reset and it doesn't open
It is possible that the hang up because there are error in the software.So to reset,remove the battery and the memory card from the phone.Using your PC, scan the memory card for any corrupt files or media files.It is possible when they are downloaded from unsafe sites.After that remove or format the card.Copy only valid files to the card and do scan before it is replaced.Now replaced the card and the battery and switch on the phone.If the phone hangs up or is to slow when it i switch on then it is confirmed that the software ha error and will need a re- installation.
Sep 25, 2011 | Nokia 3110 Cellular Phone
My nokia 5130 c2 is dead,software programming doesn't work
try to re install the s/w id it doesn't work .It must be a hardware failure .
Jun 14, 2011 | Nokia 5130 Cellular Phone
The game is not loading..after i choose a game and select it, it hang up
Does this happen to all of your games or to few of the games you just had? If this is the first time that you encountered this problem, and you have opened the same games before, try turning off (long pressing the switch) your PSP. After turning it off, remove the Memory Stick slowly, after few seconds, put it back and switch on the PSP. try your games if it worked again. If it doesn't, consider firmware update. If it's CFW, consider re-installing the same CFW or upgrading it to a newer one. Be careful with CFW though, or you may brick your PSP.
Jun 07, 2011 | Sony PSP (Piano Black)
Bought nintendo wii last xmas and had played quite frequently. then after a break in play of a few mths the remote controls dont seem to be being picked up by the sensor. i chenged the batteries and still...
Hello there
Hold the Wii Remote upside-down with the buttons facing downward.
Tap the remote firmly against the palm of your hand three times to remove any dust sitting between the buttons and the electronic circuit board inside the remote.
Turn the remote upright and press one of the buttons. If the problem continues, Open your Wii Remote's battery door
Check that your Wii Remote contains two new "AA" batteries or a charged battery pack. Check that no corrosion is present on the battery's metal elements/connectors.
Use a cotton swab to clean the remote's battery element/connectors if corrosion is present.
Check that the Sensor Bar cable is inserted firmly into the back of your Wii gaming system. The Sensor Bar needs to be centered above or below your television so the Wii Remote can transmit signals to the gaming system.
Stand three feet away from the Wii gaming system/Sensor Bar.
Aim the remote and press any button to test the device.
If the remote is not working, stand five to 10 feet away from the gaming system and try the device. The Wii Remote works best three to 10 feet away from the gaming system/Sensor Bar.
Move any objects blocking the signal from the remote to the gaming system/Sensor bar--candles, other remote controls (TV/cable box) and wireless computer devices/cellular phones.
Also, if any sunlight is coming in through a window, close the curtains or blinds to keep the light from interfering with the remote's signal.
Turn off and unplug your Wii gaming system. Leave the unit unplugged for one minute. Plug the gaming system back in.
If the remote still aint working;
Turn the Wii system on. Press and hold the red "SYNC" button for 15 seconds when the "Health and Safety" screen appears on your television. The "SYNC" button is behind the small door on the front of your Wii unit.
Release the "SYNC" button. Remove the battery cover and batteries/battery pack from the back of your Wii Remote.
Press and release the red button located under the battery compartment. The blue lights on the front of the remote will blink
Press and release the "SYNC" button on the front of your Wii gaming system. The "Player" light on the gaming system stops blinking and stays on, the resetting process is complete
Oct 01, 2010 | Nintendo Wii Console
REFORMATING
To do a reformat on this phone you press *#7370#. However you should back up all data on your phone since it will erase everything. As for the incoming calls, you have to assign a picture to each Phone contact one by one.
You might also want to do a software upgrade to get the latest firmware which has the least amount of bugs.
Also try CLOSING the programs that you are using instead of just pressing the END/RED button. Everytime you have a program open and don't need it anymore, just press OPTION, scroll up and select EXIT.
Mar 15, 2009 | Nokia N95 Cellular Phone
Camera not functioning
try opening your AGENT V game application and then hang it on by pressing the joystick to the left as fast as you can 'til the loading timer hangs.
exit from the said application and then check your cam if it is working. if not, repeat the process...be patient...
Nov 12, 2008 | Nokia 3230
Hoe to format nokia N70 mobile
Switch of your phone
Press and hold these 3 keys together-
-green dial key-
-the star key(*)
-the number 3 key(very hard to do)
Press the on off switch to the phone
DO NOT let go of the keys until you see a formatting screen
After a few minutes the format will be complete,your phone will be back to factory settings
Aug 13, 2008 | Acer TravelMate 2300 Notebook
Does'nt open
When you download games from internet ,it might be possible that it contains virus and may cause your mobile behave unexpactedly .so now it seems that you are unable to open your menu.........
Soluton :
Try flasing the mobile or format the mobile so that you can get the factory settings
WARNING: This will ERASE EVERYTHING on your phone
If you have any files that are important to you, make backups.
1. Make sure you phone is fully charged.
2. Backup your contacts list and personal files to MMC memory card (if possible).
3. Switch-off your 6600 phone.
4. Press and hold these three keys together
-Green dial key,
-Star key (*)
-Three key (3)
then press the power on/off to swtich on the 6600 phone.
DO NOT let go the three keys until you see the “formatting” screen displayed
5. After a few minutes, the format will be complete. Your 6600 will now be at its original factory settings.Disclaimer: I will not be held responsible for anything that happens to your phone as a result of following my guide. Use this guide at your own discretion and risk.
OR YOU CAN USE
*#7370# FOR MASTER RESET
GOOD LUCK !
May 29, 2008 | Nokia 6600
Sony Ericsson K510i Cellular Phone Logo
22 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
