Question about Dryers
Need a hotpoint manual schematic
Need a hotpoint schematic wiring diagram for model number DTL32 Tumble dryer
SOURCE: Need schematic for Sears Kenmore Dryer model number 11063032102
Thanks, I will try that.
Posted on Mar 28, 2008
SOURCE: Replacing the Drive Belt
I am not an expert but I do have a Hotpoint 9334 Tumble Dryer which I guess is similar to the 9314.
To replace belt or heater element you must remove the front panel complete with door.
Screws are different sizes in different places so note where they belong as you remove them.
1. Remove 2 screws at rear top which go through the brackets holding the top panel, slide back the top panel a little and lift it off.
2. Pull off the rotary timer knob and remove 2 screws beneath.
3. This is the tricky bit! Remove the the plastic panel which covers the switches etc.. This panel has 5 plastic fingers which secure it to the metal plate behind, locate the ends of the fingers where they pass through the metal plate. Using a metal rod or punch and a hammer, tap the ends of the fingers to push them back through the holes easing each in turn a little at a time to avoid distorting the plastic unduly. (This is a bit scary as you have to hit them quite hard and the fingers look fragile)
4. Open the door and remove the 4 screws then remove 3 screws at the top and 3 screws at the bottom of the front panel. Lift and ease forward the front panel, unhook the door catch release wire, pull off the electrical connectors and put the front panel aside.
5. Lay the machine on its back and remove 1 screw holding the element housing to the top plate and pull off the electrical connectors.
6. Fit the belt around the drum, through the idler pulleys and over the motor spindle.
7. Put it all back together.
Posted on Feb 03, 2008
  • 55 Answers
SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Posted on Mar 10, 2008
SyxPak
SOURCE: wiring diagrame for hotpoint gas dryer
E-Mail me and I will send you a copy of my Schematic. It's 2 pics, but they are pretty clear and should help you. I came to the site wher I saw your post looking for a pic of an exploded view of our dryer. Trying to open it to fix the glide bushing. Started makin metal to metal noises lately, so I am assuming it's like a nylon glider for the drum?
SyxPakk@Yahoo.Com
Mike.
Posted on Apr 01, 2008
SOURCE: dryer
Most wiring diagrams are located inside the control panel area
Posted on Jul 11, 2008
Hi I need a wiring diagram for a hotpoint tumble dryer model no tvfm70 as some of the wires on the control panel have come off.
There should be a schematic attached to the dryer. Usually they are near the control panel.
Oct 12, 2016 | Hotpoint Dryers
Hotpoint tcym 750c tumble dryer serial number tcym750c6p. The wires attached to the timer control and start button have disconnected does anyone know how they go back on?
images for Hotpoint tcym 750c tumble dryer wiring
Hotpoint TCYM 750C Style - YouTube
? 3:07
https://www.youtube.com/watch?v=RjQMN6U4PdE
Oct 8, 2012 - Uploaded by Missing Sleep
Hotpoint TCYM 750C Style. Missing Sleep ... How to replacetumble dryer belt Hotpoint, Indesit, Ariston, Creda, Proline etc - Duration: 9:36. by ...
Hotpoint tcym 750c tumble dryer serial number tcym750c6p ...
www.fixya.com/.../t25992053-hotpoint_tcym_750c_tumble_dryer_seria...
48 mins ago - SOURCE: Reconnect wiring on a Hotpoint VTD00 tumble dryer. most electric dryers have a wiring schematic on the back or inside on the back ...
Dec 03, 2015 | Hotpoint Dryers
Wiring diagram for Hotpoint 31331r tumble dryer door catch
theres a schematic in each appliance. look there, & if your not sure get a service tech so you dont do more damage
Jan 08, 2015 | Hotpoint Dryers
Wiring diagram Hotpoint 31331 tumble dryer Door lock
I need a wiring diagram for a hotpoint TVF770 tumble dryer. I've replaced the heater element and want to confirm where I plug in the wiring loom. Thank you for your help.
I am sure if you go on line and ask for
diagram or manual you will get it. Or go to
Hotpoint and it will be on site once you have
chosen the tumble drier you have.
Next time you do a job like that always make
a diagram of what you are doing.It pays every time.
LUCK
Sep 25, 2014 | Dryers
most electric dryers have a wiring schematic on the back or inside on the back pannel of the unit it self . try too look for one there and it might help you out
Oct 30, 2009 | Hotpoint Dryers
Cant remember where wires go in tumble dryer
Most all washer/dryer manufacturers put a wiring diagram and electrical schematic somewhere on the unit. Sometimes it's in the "head", others it's on the inside of the removeable panel used to access underneath the gut's of the unit, from the back. And then sometimes it's just on the back of the unit.
I tried to find a wiring diagram for you, put the Model number does not come up.
Jan 17, 2009 | Hotpoint TDL14 Electric Dryer
Hot point tumble dryer TL61
need the whole model number to get you the wiring diagram
Jan 21, 2008 | Hotpoint TDL14 Electric Dryer
Dryers Logo
767 people viewed this question
Top Dryers Experts
