Question about Thermos Stainless Steel Gas Grill
I am not getting gas to the grill burners
I own a four year old Thermos stainless grill model#461262006. Recently it has not been able to deliver the propane from the tank to the burners when I have disconnected the line from the tank propane escapes to the air. I am wondering where to look for an obstruction or is this a part that failure? I would like some ideas if anyone has any.
TIA,
John
  • Thermos Master
  • 2,814 Answers
Check out the reg could not be passing gas
Posted on Jul 05, 2017
SOURCE: Sideburner for Thermos Stainless Steel Gas Grill (Mod # 461262006)
I have a Thermos Grill Gas #461262006 and I need I(Item No 80005703 4 Burners) and Item 80003332 Flame Regulator
Posted on Nov 18, 2009
bulldogchief
  • 388 Answers
SOURCE: converting Thermos Stainless Grill to natural gas
You have to install a conversion kit for it to work the way you want. The reason is because the orifice in either the valves or the main "jet" that feeds the burner tube has to be changed. Natural gas is really not as efficient as lp gas (propane) because it takes more natural gas to create the same btu output as propane.
In short, your grill will not work if you do not do the conversion. I am including a link that lists the conversion kit for your grill, you can order it there and you can download the assembly manual as well.
Here is the link: http://www.charbroil.com/Consumer/product_detail_e.aspx?ProductID=1723&CategoryID=25
Posted on Nov 20, 2009
  • 332 Answers
SOURCE: I have full propane, yet a low flame?
he new style OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
Posted on Mar 29, 2010
jyackle5
  • 8197 Answers
SOURCE: dual fuel thermos m#461262006 swicth back to propane
You can get the manual on the link below. Make sure you have the right regulator for the propane and not one for Natural Gas.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0807110.pdf
Posted on Apr 28, 2010
  • 2814 Answers
check the burners are not blocked and the orffice , check the reg on the tank giving full pressure
Posted on May 17, 2010
I am smelling propane at the cooking surface when I turn the burner knob to the ignite position. I have been unable to determine the source of the leak. We've had the grill for a couple of years and have...
When the knob is in the ignite position, the gas should be coming out of the burners at a rate sufficient enough to light. It's normal to smell it before the igniter (either electric or push-button) ignites the gas.
If you recently moved the grill with the internal parts still inside it, it's quite possible the burner tubes have become loose in the holders. They are quite easy to remove because they are a commonly replaced component. Remove the grates and flavorizer bars according to your manual, and you should be able to reach in and check the position and snugness of the burner tubes.
Make sure you close the propane valve and disconnect the tank before doing this. Also, don't smoke when working on your grill. :)
Feb 28, 2011 | Thermos Stainless Steel Gas Grill
I WANT TO SWITCH TO NATURAL GAS BUT THE MODEL NUMBER IS WARN OFF
You can search the web until you find a picture of your grill, that will get you close. If the serial number is still visible, that should also be helpful.
Jul 07, 2010 | Thermos Stainless Steel Gas Grill
May 15, 2010 | Thermos Stainless Steel Gas Grill
Dual fuel thermos m#461262006 swicth back to propane
Apr 28, 2010 | Thermos Stainless Steel Gas Grill
Cracked primary burners
yes call Flame Grill Services at 770-521-2050
Mar 18, 2010 | Thermos Stainless Steel Gas Grill
A burner knob somehow melted off and now when I try to light the grill it barely keeps a low flame. Is it a regulator problem? I have a Thermos gas grill with three burners-about 3 years old.
You may have a blockage in the tubes connected to your gas valve. It could be a spider web.
The burners may not be connected to the valve properly.
It could be an overfilled propane tank, and the overfill protection kicked in.
It could be a bad regulator.
Mar 07, 2010 | Thermos Grilling
Converting Thermos Stainless Grill to natural gas
Nov 20, 2009 | Thermos Stainless Steel Gas Grill
Thermos Gas Grill
This is caused by a bad regulator. This is the silver device that usually attaches directly to your tank. Most hardware stores carry these regulators you will need the numbers off it to match up a new regulator for size.
Jun 21, 2008 | Thermos Stainless Steel Gas Grill
It sounds like the orifice is bad. An orifice is a small metal part that has a small hole in it. This regulates the gas coming out to the burner. It is at the tip of the pipe that brings gas to the burners, before the flame. I don't know what the hell the garggley noise is. Unless the bottle is upside down, and you are getting liquid, I don't know.
Mar 02, 2008 | Thermos Stainless Steel Gas Grill
Gas leaking behind the handles along perforated pipe
Spiders get into the gas line and spin their webs causing the gas flow to be interrupted. Take the burner off and carefully remove the web. Replace the burner and it will work just fine.
Nov 25, 2007 | Thermos Stainless Steel Gas Grill
Thermos Stainless Steel Gas Grill Logo
296 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
