Question about Gateway FPD2275W LCD Monitor
Moniter Messing up
Ok my monitor started messing up around 2 monhs ago.. Once in a while the screen will just give out and I mean it will turn it self off and when I try to turn it on it turns on for like 3 seconds and shuts it sellf off again so my question is, is their a setting that makes my monitor do this because my dad goes on this computer some times and hes completly computer illertireate and does stupid things so is their a setting that makes it d this.?
    Scholar:
  • 49 Answers
Is youyr monitor a "flat screen" i.e. LCD or is it a CRT. (Flat screens are about 2 - 3 inches thick (or deep), and CRT monitors are about 12 - 18" deep (front to back).
If it's a CRT chances are that there's plroblem with it, and it's shutting off BECAUSE of the problem. EITHER way there wouldn't be a setting to make the monitor shut off after 3 seconds... what would be the point?
Get back to me, but I think your monitor is the problem.
Posted on Mar 15, 2008
  • laurelton Mar 15, 2008
    Flatscreens will "turn off," afer a VERY short time is they don't signals from the computer. Have you checked to see that the connections are tight? Usually there a wire that plugs into the back of the flatscreen, goes to the computer and as plugged in to the computer. Either end of this cable needs to be fully and squarely plugged in.
    Again there would NOT be a setting on the flat screen that would cause this behavior, HOWEVER - and you could check THIS out: some flatscreens have MANY inputs and a button that will bring you to a sreen (or a buttoin that you repeatedly push) which will allow you to CHOOSE which input your useing.
    If your monitor is not set to "computer," as far as the flat screen is "concerned," it's not connected to ANYTHING, and probably will turn itself off.
    If the monitor DOES display computer info for the short time you mention, the flat screen probably has an internal problem and need to be repaired or replaced.
When i install my 22'lg en43s i gan not get any red color .how should i proceed
If the monitor is OK on another laptop, check the VGA socket/lead.
Dec 29, 2014 | Acer Computers & Internet
Hi we have a compaq 7550 screen that when turned on has a red sheen over the whole screen. Any solutions or is it ready to throw away. thanks
You may try messing with the settings on the monitor. The menu buttons are usually on the front. Try to find something that deals with the color tones of the monitor. If messing with these settings doesn't fix your problem, then unfortunately, it is probably time to throw it out.
Aug 27, 2011 | HP Compaq FS 7550 17" CRT Monitor
I have a dell dimesion 3000 with a moniter that came with it from dell. a little while ago my nephew was messing with the moniter and made it really blurry. is there any way i can fix this?
There should be a menu button, and once in the menu, I believe there should be a Factory Reset Setting that you can choose and it should clear it up. If that does not work, the monitor could possibly be damaged and the blurry screen is the result. Good luck. Thanks. -Sa_Les_Ski
Feb 26, 2011 | Dell Dimension 3000 PC Desktop
My moniter says out of range.
Video Card has a resolution setting higher than the monitor supports. The below works with XP, may work for Vista as well
Start the PC
Start hitting the F8 key repeatedly until you see a menu
Choose Safe Mode (make sure not to pick safe mode command prompt)
Once you see the desktop, right click on an empty area on the desktop, then choose properties
Find the resolution property in this program and bring it down. 1024 x 768 should be ok
Click on OK til the window disappears
Reboot
Mar 19, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Monitor Display
see ur moniter is nearly dead...
dont try to on?off it again and again
take it to service center
it happened to me too
its nothing just a small thing which they will change it.
its a bit costy but not more then ur moniter
Jan 07, 2009 | Mag Innovision lt456s 14" Flat Panel LCD...
Monitor blinks no image
first you need to isolate the problem to either the computer or the moniter. I would sugust that you hook a know good moniter to the compter and go from there. If the other moniter works then you have a moniter issue aif not chek the video card in the computer. good luck
budman630
May 01, 2008 | E-Machines eMachines Monitor E15T4
My Acer LCD AL1711 went off after seconds of turning on.
This monitor has "back lights" that are essentially like flourescent lights. These are high voltage lights and can easily fail. since you are getting some light initially, I would suspect a defective part that heats up a bit right away and then fails. I would try to replace the entire backlight board. This is the small board on the side (usually).
Dan
Mar 27, 2008 | Acer AL1711BM (Black) 17" LCD Monitor
My Monitor flickers when computer starts
If "messing" around with the CRT connection on the back of the monitor causes it to work then I suspect there is some physical damage to. Specifically what connection/connector did you mess with? I can give you more advice if you give me more to go on.
Jul 15, 2007 | Gateway FPD1765 17" Flat Panel LCD Monitor
Gateway FPD2275W LCD Monitor Logo
51 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
