LOT OF WATER IN CLOTHS AFTER THE FINAL RINSE. DOESN'T SEEM TO BE SPINNING RIGHT
  • Ron Coons
    Ron Coons May 11, 2010
    make and model ??
  • 105 Answers
Probably main bowl bearing needs to be replaced
if the bearing is dry this will grab on the gearbox and not allow the gearbox to spin freely
Posted on Mar 16, 2008
SOURCE:
Our whirlpool wfs1285aw doesn't seem to be spinning and drying out clothes enough when Finished. The clothes are still drenched. Any ideas how to rectify this? Is there a filter that needs cleaning?
the rinse section spins slow while the rinsing is in process as this does 2 things
spreads the water through the clothes for a proper rinse
spins slow to equalize the cloths around the bowl
when the rinse cycle is finished and the tap is shut off it goes into a high speed spin
Your problem sounds like the program is not going to the high speed spin cycle and that would indicate a problem board
call a technician for a proper diagnosis and quote
Sep 15, 2016 | Whirlpool Washing Machines
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
Why is my maytag Neptune Model no# MAH5500AWW spinning very slow and not draining water out?
Complete drain must occur before spin. A no drain situation would be an actual full pool of water seen in the bottom of the machine if all the cloths were removed, sounds like you are experiencing a spin enable switch failure, which mainly prevents final high speed spin leaving the cloths dripping wet. The spin enable switch contacts become tarnished/corroded over time resulting in poor connection. If the door lock light comes on than your door lock wax motor is working. The spin enable switch is the last switch to the right in the door lock unit where the light bulb is. Part# is 22002162. If there is an actual pool of water in the bottom of the machine as if you simply removed the cloths from the unit but left the wash water, than you should look first look to your drain pump for failure, or obstruction of foreign objects, or excess lint in the pump. Pleazer Appliance...
74bd738b-53cb-465a-99c1-ba55e2189ba2.jpg 5e1e4646-e2e3-4e7c-afc7-7a0e188e6cf0.jpg
Apr 15, 2014 | Washing Machines
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Cloths are cold after final rinse cycle ...they use to be hot
The clothes should be cold after rinses, if they were hot before, then something was wrong.
Most washers do at least 3 cold water rinses, so they should be cold, this prevents creasing.
Hope this helps.
Jan 18, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Does not seem like the dishwasher is drying like it used to. After it has gone through its entire cycle the is steam condensation on all the dishes and the inner door. Previously, at the end of cycle...
Have you run out of Rinse Aid ?
This has a large effect on drying as well as how clean the dishes come out. Rinse aid [breaks up] the water dispersion, so at the end of the final rinse, the water just falls off the dishes, takes the sediment with it. So with the heat of the final rinse, & less water left on the dishes, they dry better.
Dec 12, 2009 | Kenmore Dishwashers
We have a Hoover select 1500 washing machine. It still washes and rinses ok, but doesn't then move onto the spin cycle. But I can manually set the dial to spin and restart it. It then spins fine. I assume...
Could be but also could be rinse water valve not operating due to faulty solonoid. it does a final rinse / softner before spinning if valve faulty then no spin advance....
Nov 11, 2009 | Washing Machines
Not spinning properly , the final spinning is not working and all cloths are lying in water even after full rotation of timer.and another problem is some times water is not stopping and coming...
SOUNDS LIKE A CLOGGED DRAIN. REMOVE THE FRONT BOTTOM COVER AND THE DRAIN PUMP WILL BE EXPOSED. HAVE TOWELS READY!!UNSCREW THE FILTER AND REMOVE THE JUNK FROM YOUR PUMP
Oct 28, 2009 | Whirlpool AWZ410 Front Load Washer/Dryer
Motor running, basket not spinning during rinse cycle
with this issue i would look the the notor coupler
its a small plastic clutch between the motor and transmiossion
Oct 09, 2009 | Kenmore 24032\24036 Top Load Washer
Soapy cloths after wash
first make sure the drain is at the right height(the exit should be about the same height as the main part of the washer) are the clothes spinning? could be a gearcase problem, also your pump might be clogged good luck!!
Feb 08, 2007 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
