Question about Yamaha RX-V2400 Receiver
Yamaha receiver RXV-1400 turning off after 3 seconds.
I was wondering if you can tell me why the receiver turns off after 2-3 seconds, just at the time that the volume is expected to come on.
Thanks for your help. any solutions?
  • Anonymous Jan 26, 2009
    My reciever will shut off at varying intervals. Sometimes it is several hours and at other time within a few seconds or minutes.
    I shut off all other devices such as TV, Cable box, etc. to see what happened: It did not shut off for over 10 hours.
  • AllenAllen Mar 04, 2009
    Alfon, what happens if you turn the volume to less than 2, then turn it on? My RX V480 works find, then shuts off if you turn the volume to above 1/4 of the way.
    Problem Solver:
  • 12 Answers
Hi
there are several reasons, but the most common is because a high power trasistor is shorted, most yamaha receivers use the same names for the failure signals, such as PRD, PRI, PRY
The PRI is the signal that "tells" to the microprocessor that something is wrong with the power amplifier stage. so my recommendation is that look with the ohmeter a power transistor shorted usually if one if damaged, the next one or complimentary is too, there is a small transistor between the two big ones, usually is the number is D1915, if this is damaged, USE the SAME, also look for resistors damaged, specially the low value like the big white this resistor is 2 in 1 and some times just one resistor opens.
I hope this helps
Miguel
Posted on Apr 25, 2008
SOURCE:
Tip
Reset factory default settings for yamaha HTR-5650 AV receiver
How to reset yamaha HTR-5650 AV receiver (maybe others) to factory default settings:
1. turn power off.
2. press the 6ch input and stereo button simultaneously for 4 seconds. Then while holding down these 2 buttons, turn the power on.
3. press preset tuning to the right until option #9 is selected.
4. Then, press program button until the *RV option is selected.
5. turn power off, wait 10 seconds.
6. turn power on, settings are reset.
on Feb 10, 2009 | Yamaha HTR-5650 Receiver
Yamaha home theatre system RXV 350 amplifier
Check it without speaker connection. If the set does not go to protection mode, check all the speakers by connecting one by one at a time and switch the set ON; to find the faulty speaker. If the set goes to protection mode even no speaker connected, check and replace damaged components at its audio output section circuit. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 07, 2014 | Yamaha RXV-350 Receiver
Rxv-571 wont power on, no click sound either
Good for you. You are a real techie.
Jul 04, 2014 | Yamaha RXV571
Yamaha RXV 1400 RDS and subwoofer stopped working
If it is new, just send it back for warranty repair.
Jan 13, 2014 | Audio Players & Recorders
YAMAHA RXV 350 Right Speaker not Working
The amplifier for this channel is NOT working.
Feb 09, 2012 | Yamaha RXV-350 Receiver
Just bought a used yamaha receiver model RXv793 do not know how to hook it up.
First do not panic by seeing all sockets in the back side of the receiver.You can connect 5 speakers and one subwoofer on the speaker A switch and maybe a second pair of stereo speakers on the B switch.All the speaker sockets have red and black terminals, so do all speakers. Just get decent cables ( You can buy a whole connection Kit if you want ) and connect the corresponding outlets to you speakers.If you have a powered subwoofer connect the subwoofer input to a socket labeled Subwoofer pre out on the RXV. You will need a RCA to RCA cable for that Next you will need a coaxial or Optic fiber cable to connect a DVD player digitally. The back of the DVD player will have a socket marked coaxial out, and so does the RXV's backside. Just link them .
Turn on the system everything should work. If you are not getting DVD sound there is small button on the RXV front panel called Digital input -- set it to auto ( keep pressing the button and it will scroll through various modes). Also remember to switch on speaker A on the front panel.
Mar 09, 2011 | Yamaha RX-V793
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
Yamaha rxv 595 receiver shuts down when volume is increased
THE SPEAKER WIRES ARE REVERSED.... On the receiver the red side is always positive and black is always negative.
change + to - or
change - to + on one or more speakers.
positive side--------------------negative side
red --------------------------------black wire
gold wirew/silver--------------silver wirew/gold
white lined----------------------non-white lined
Oct 30, 2008 | Yamaha HTR-5730 Receiver
Yamaha RX-V2400 Receiver Logo
614 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
