Question about Epson RX620 All-In-One InkJet Photo Printer
Epson RX620 Would you happen to know the procedure for bypassing the ink pads in the printer. It looks like the "waste ink well" that you can buy from ebay is nothing more than a hose and a coupler running into a gladware container. Now I just need the directions. thanks
  • rudyannall Jun 09, 2008
    How do you know when the waste pad is getting close to full?
    I downloaded the SSC which shows a waste pad use/fill number but it doesn't show what the limit of that number is.
  • Epson Master
  • 419 Answers
@fransser: All the information you need is provided from this forum thread
It's pretty simple stuff if you have the necessary parts (tubing, container, etc..) to hand but if you want something a little more refined there are kits out there :-)
@rudyannall: The SSC utility won't give you that information unfortunately... If you can locate a copy of the official service engineers Adjustment utility then that can sometimes provide a capacity reading which can help but overall the best way to tell is when the "Service Required" message pops up.
Posted on May 06, 2009
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
Service required. Parts inside your printer are at the end of their service life.... Can I temporarily bypass this? It is locked.
You can bypass this termporarily by resetting the waste ink counter as described here:
http://www.continuousink.info/forum/viewtopic.php?t=4141
That link also provides information on how to resolve the more long term issue of further waste ink build up. In short you will need to think about redirecting waste ink flow to an external tank or get the printer serviced to replace the pads.
Hope that helps.
Martin
Jun 24, 2009 | Epson RX620 All-In-One InkJet Photo...
Need to replace ink pads for epson stylus rx620.printer. Where to buy and how to replace?
You don't need to buy the pad. Just wash with hot water. Is there a message to replace waste ink pad?. You need to reset waste ink counter. Use SSC utility to reset it. Extend outlet pipe to outside. You don't need clean pad again. If you wish to wash or replace pad, you must open case and diasemble all mechanics. Find SSC at indoreset.blogspot.com. And printer diagram at printersiam.com
Jun 21, 2009 | Epson Stylus C86 InkJet Printer
Re.ink pad
Waste Ink Pads. They need to be cleaned/replaced and the counter reset. Look at the Ink Waste Container kits here. Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Jun 16, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Stylus Photo 1400 Ink Pad Replacement
Hi, if you change wast ink pads it will cost too much.
The best way to resolve this matter is Do it by your self.
You can purcahse wast ink bottle from us then use EPSON reset software to reset wastink pads.
After this done your printer will back to normal.
If you require more information related this issue you can email us free of charge
service@rextras.com
Kind Regards
May 15, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Possible to soak up excess ink on the 'pads'?
Hi Macddcam...
You have to remember that the pads are designed to be ultra absorbent so it's going to be very difficult to get them to give up their ink unless you have something even more absorbent.
Trying to mop up or syringe out pads is really a bit of a losing proposition in terms of time, effort and ink mess so really the smarter option is to redirect the waste flow (ie: install an external tank) and allow the ink base (ie: water in the RX620) to slowly evaporate off over the course of the printers life..
If you need information on the process for the RX620 then you can find it here
Mar 28, 2009 | Epson RX620 All-In-One InkJet Photo...
Service required parts inside your printer are at the end of there service life.seer your printers documentation for details
Hi, I had the same problem with my RX500.
All you need to do is perform a reset, by pressing and holding the "Stop", "B&W", and "Power" buttons all at the same time and holding them down for at least 10-15secs. It may take a few goes as there's a bit of a nack in getting the buttons pushed at the same time.
Let me know how you get on.
Jan 29, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Epson rx620-waste ink pad replacement Instructions
No Problems M8!
Here is the manual for your printer
http://files.support.epson.com/pdf/rx620_/rx620_qr.pdf
Good luck to you
If you find my answer helpfull, dont forget to vote!
Dec 18, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
Waste Ink Pads
ink waste is replaced br cleaning it through alcohols
Oct 26, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
RX620 Error Message
This message comes up after about 40000 registers on a use counter. I posted what I did on the Epson RX620 forum. Look it up. Basically I bought a repair manual on the net for about $10.00 I used this to take the RX620 apart down to the waste ink catch pads which I removed cleaned dried and replaced. It was a long job the first time and you need the manual in order to figure out how to do it. My pads were only about 1/3 used but I live in a dry climate. So punch those override buttons and keep going. You might put a plastic sheet or pan under the printer to catch the waste ink when it actually does leak out.
Jul 30, 2007 | Epson RX620 All-In-One InkJet Photo...
Epson RX620 All-In-One InkJet Photo Printer Logo
77 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
