BEKO WML 15040 KL DRY BUTTON
HI
I HAVE BOUGHT BEKO WASHING MACHINE AND PLEASE COULD YOU TELL ME HOW CAN I DRY THE CLOTHES. DO I NEED TO PUSH SOME BUTTON? I CAN NOT SEE IT IN THE PANEL
THANK YOU
4 Suggested Answers
SOURCE:
jgwhomeequip
  • 1902 Answers
SOURCE: touch panel buttons do not work
This sounds like a bad touch screen. You can get a replacement online at repairclinic.com. They will have instructions on how to remove the old and put on the new
Posted on May 22, 2009
  • 57 Answers
SOURCE: Hi can you tell me how to change the brushes on my
If the motor in queston is a C.E.Set or Sole, you can do it by tilting the machine back against the wall. Otherwise, you'll have to take the back off and remove the motor by opening the bolts. Easy to change the brushes after that
Posted on Dec 08, 2009
  • 714 Answers
SOURCE: My washing machine does not spin dry the clothes
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve
Posted on Jan 17, 2010
I want to stop a programmed cycle and start a new one at beko wml 15062 yl
I alsi have that machine. To stop on program and start another, I've pressed the play/pause button for a few seconds, then waited for the key light to come on. Then I switched to the program I wanted and pressed play/pause again
Jan 26, 2014 | Washing Machines
How to reset beko wm5120w washing machine
You need to get the dial to 90 degree program then push the start and on button together. Keep hold the start button then a light will flash. Then move the dial to spin/drain option and press start to start the reset test mode. Hope this helps.
Aug 17, 2012 | Beko Wm & Wma Models Washing Machine Motor...
Beko washing machine not draining
If the drain hose is stretched too much to reach the standpipe, the hose can pitch.
May 21, 2012 | Beko WM5140W
I can hear the water going into the machine but after after a short while the machine stops, the start pause button and the wash button flash and the machine stops. I have held down the start pause button...
Not an answer to your problem but i am having the same problem with me 20 month old beko machine - a different machine to yours. I have had an engineer out twice already paid for by myself to rectify the problem and now it has happended a third time. The engineer seems to think it is poor quality wire used. Good luck let me know how you get on.
Sep 29, 2010 | Washing Machines
Beko WMA 1715s - won't respond
door lock switch could be your problem..
Aug 30, 2008 | Whirlpool LCR5232H Top Load Washer
Washing Machines Logo
696 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
