Help my RCA 35 inch is stuck on channel 4.I can not get it to change to any other channel.
    Scholar:
  • 133 Answers
Go into the menu and do the setup feature as if you just purchased the set . It will ask you all kinds of questions and may start the autoprograming all over again . This is a common problem with these sets but this is all you should have to do . Sometimes the set just locks up . Good luck and let me know . If this does not work give me the model number .
Posted on Mar 15, 2008
6ya staff
SOURCE:
My 27 inch rca truflat is stuck on channel 13 on the cable setting and 41-1 on the ant setting wont change to any other channel, can someone help me
try to preset the channels bec,it is not on the tv button memory but only on remote.go to channel settings and preset cable channels
May 23, 2016 | RCA TruFlat 27F520T 27" TV
RCA LCD TV gets stuck on one channel
sounds like you have an intermittent defective main board. ebay rca model for replacement board.
Jan 11, 2015 | RCA Televison & Video
I have the Eurolive B212A speaker,and the Xenyx 1202fx.I want to play my Ipod using this set up.Please help with connection
The Ipod is stereo and your speaker is not, so don't expect stereo.
Find a 1/8 inch stereo cable that splits the two channels into individual cables and enter those into two channels of the 1202 mixer. You might find a cable that goes from the 1/8 inch stereo and splits to two RCA type jacks which you have to either find RCA inpouts on your mixer or get two RCA to 1/4 inch adapters.
Crank the pan controls clear to the left on those two channels. Run a cable from the 1202 left main out to your speaker input.
Adjust the controls as needed.
Jan 03, 2010 | Behringer Music
Tv stuck on channel 2, need channel 3 for converter. remote nor buttons on front will change channel
Unplug the tv. Before you do a channel search make sure that you have the converter box plug in and turn on.
Nov 27, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
My husband and I just purchased tascam 2488 portastudio, we are truly novice and need help with figuring out what cords are needed to connect the mics we have to the tascam. We would also like to know is...
If your mics are XLR (a hole on the bottom of the mic with three pins visible in it) you will need one of these for each mic, plugged into one of the four channels on the tascam that has an XLR connection (which will be the female version of the connection on the bottom of your mic). If your mics have a 1/4-inch connection, you can use the 1/4-inch connection on any channel on the tascam. For the stereo connection, you will need one of these of sufficient length to convert the RCA output from your stereo to the 1/4-inch input on your Tascam. Find "Tape Out" or "AUX Out" on your stereo and plug in the RCA side of the cable there (note which color you use for R and L). Use the 1/4" end of the cable to connect to two available channels on your mixer. Use the Pan knob to pan the left channel to the left and the right channel to the right, and voila! Hope this helps, and good luck!
Nov 13, 2009 | Tascam 2488 Portastudio Multitrack...
I purchased a RCA DRC-8335 DVD/VCR RECORDER COMBO
For anyone who has an RCA DRC 8335 with dvd Recorder, here is a suggestion.
If your tapes have been recorded in SLP Mode, om another player, I can tell you they will NOT play on this thing!!
So, merely take another VCR, and a blank tape, Place the blank tape into the RCA DRC 8335 VCR side, and then, go to its Set-Up Menu, and go to OUTPUT. On the "ACTION BAR"Change the the RCA's output to "FRONT" and then, play the VCRr you stuck on top of the RCA!!
When the inage on the "Source tape is shown,
Record onto the RCA, in SLP Mode, Now, it will play, just fine.
Hope this helps. Jon (Found BY Accident!!)
Jul 31, 2009 | Televison & Video
After a power outage my rca 36 inch pip changes channels
the manual buttons on ur tv set seems to be stuck, take a look for any damage or corrosion or for anything
May 10, 2009 | Televison & Video
Where is reset button on 35 inch rca tv,I can only view 49
there is no reset button. Ypu need to give more detail about what i sgoing on with your set. Also what is the model and ctc numbers thfey can be found on the back of set. Unplug set for around 30 minnets then plug back in see if it wil work then.
Feb 28, 2009 | RCA 20" TV
Doesn't rcognize DVD players
You aren't trying to use channel 3 or 4 are you? That's for RF connections only.
There are probably AV input channels on the set that aren't accessible from the channel up/down buttons. On my set there is another button to switch between inputs and channel select.
Mar 23, 2008 | RCA 35V432T 35" TV
RCA TruFlat 30-something inch
what chassis is in your set.look on rear panel ./st
Dec 09, 2007 | RCA 32F530T 32" TV
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
