Question about Samsung Televison & Video
Samsung TXN2668WH HDTV Power problem
I have a Samsung TXN2668WH HDTV. It has been acting up. While watching the set will turn off and back on after a few seconds. 1st occurrence is about 20-30 seconds, and then it gets quicker and finally it will just stay off. Can someone point me to the right direction on how to have this fixed? Thanks....
    New Friend:
HI
did you ever get this fixed? if so what did you do to repair it and how much did it cost?
i'm having the same problem.
Thanks
drew
Posted on Feb 09, 2010
SOURCE:
Samsung 46" HDTV power keeps turning off after a period of time
Panal damage is a possibility however, you may also try to have a tech replace your mainboard since you have sound.
May 22, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
TV acts like it is turning on then shuts off then repeat, repeat
When my lamp died the bulb literally exploded. That may be what you heard. Have you check the lamp? If the lamp is ok, the lamp's ballast or power supply might have blown.
May 22, 2009 | Toshiba 62HM95 62" DLP HDTV
Tv won't turn on
That unfortunately is the first most detrimental thing for the Lamp. The can lamp can be accessed through a cover in the rear of the set. Take it out and look at it, most likely is shattered. If it is try DLP Lamp Express for a replacement. If not, let me know.
Apr 30, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
TV won't turn off
Problem solved. I opened the configuration menu, went to Setup, More, Light Effect, changed setting from "Always" to "In Watching TV".
Dec 09, 2008 | Samsung LN-T4071F 40 in. LCD HDTV
Power circuit board needs to be replaced
Samsung parts
http://www.partstore.com/Part/Samsung/Samsung/
Jan 29, 2008 | Samsung HCN4226W 42" Rear Projection...
Not turning on again
try cleaning The air filter in your set. It may be a thermal problem due to a clogged air filter.
Jan 19, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
Tv problem
have the power supply checked out it may be weak
Oct 04, 2007 | Samsung PCH521R 52" Rear Projection...
Samsung HDTV Oval rainbow of colors covering entire screen
I HAVE PANASONIC MODEL TH50PE700U WATCHING IT AND THE COLOR WENT YO B/W
Oct 04, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
Open Questions:
Televison & Video Logo
96 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
