Question about Maytag SkyBox MBV1976A Beverage Dispenser
Dispenser will not cool on the highest setting
The dispenser won't dispense. The only light that works is the light that lights up the door display. The other problem concerns the cooling. It doesn't cool like it used to. The thermostat is set on high as it can go, but it doesn't keep the beverages cool enough.
  • cliffnada Mar 23, 2008
    have the setting on coolest position but still doesn t do the job what can we do to fix this/
    THANX CLIFF
  • 770 Answers
I have a service manual on the sky box post your email and i will send it to you
Posted on Mar 15, 2008
Inside lights of KitchenAid KSF26C4XYY not illuminate
I bet your fridge was put into Sabbath Mode.
Sabbath Mode is designed for those whose religious observances
require turning off the lights and dispensers.
In Sabbath Mode, the temperature set points remain unchanged,
but the interior and dispenser lights turn off, all sounds and alarms
are disabled, the dispenser display screen backlight turns off, and
the dispenser levers are disabled
To turn on Sabbath Mode, press and hold LIGHT and
OPTIONS at the same time for 3 seconds. When the feature
turns on, "Sabbath Mode" will appear on the dispenser
display.
To turn off Sabbath Mode, press and hold LIGHT and
OPTIONS at the same time for 3 seconds again.
Apr 15, 2014 | KitchenAid KSF26C4XYY 26.0 cu. ft. Side by...
The dispenser light won't turn off and ice and water not working after filter change..
I'm not really sure of this one but here's a couple ideas. If the refrigerator ice and water dispenser is not working the dispenser control board might be defective. The control board governs most of the functions of the dispenser system. If only one item of the dispenser system is not working, troubleshoot further to see if the problem is with one of the components in the system. The board is more likely to be the cause of the problem when the entire dispensing system fails. It may also be the door switch If the refrigerator ice and water dispenser is not working. When the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice maker dispenser. If the door switch fails the dispenser will not turn on. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.Before either of these try shutting it off (or place it in demo mode) and return is to active state.It may just need a reset
Mar 30, 2014 | Maytag MSD2732GR Side by Side Refrigerator
LG REFRIGERATOR DISPENSER NOT WORKING
x1 sonny ericcson widows mobile 6.1 version i want to change my language to english
Jan 05, 2014 | LG LSC26905TT Side by Side Refrigerator
GE Profile PFSS6PKWBSS control panel display does not light up
more than likely the mainboard in the rear of the unit is defective,as the dispenser board gets its power from the mainboard and the dispenser bpoards normally dont go bad
Feb 01, 2013 | Refrigerators
WATER DRIPPING IN DISPENSER TRAY DUE TO ICE MELTING AT FRONT OF DISPENSER
Hi Don,
Typically this occurs when the dispenser door does not close all the way.
The dispenser door is located in the freezer door in the chute that the ice dispenses down.
With the freezer door open shine a light up from the outside and look down into the door from the inside. If you see light around the door flapper, you will need to replace the dispenser door, if there is a large gap between the dispenser door and the chute you will need to replace the mechanism that controls the door.
Apr 18, 2010 | Electrolux Refrigerators
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Door light, on/off switch, water and ice dispenser not working
First of all if your water dispenser is working then we know that the control panel is getting power. If not open the door and manually press the door switch to see of the switch is working properly. The switch will cut power to the dispenser to prevent operation while the door is open. Second you need to check the wiring at the hinge to see if there is a break in it.
if you are still having trouble please respond with a model number
Apr 15, 2009 | Refrigerators
Maytag skybox-2 problems
maybe bad fans and a dispenser motor post your email and iwill send you the svc manul so we can look into it deeper
Mar 03, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
138 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
