Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos HDTV LC52D62U Caption Not Readable
The closed caption has been working great until a few days ago. It is now not readable such as the letters are jumbled up. We have Direct TV and the closed caption works fine on the other televisions we have but we have been unable to determine how to make it readable on the Aquos HD model (LC52D62U). This model was not in your drop down product listing so I had to select the 46 in. in order to submit this question.
    Sniper:
  • 53 Answers
Try doing the Factory Initialization (WARNING: THIS GIVES YOU ACCESS TO THE SERVICE MENU. DO NOT ADJUST ANYTHING IN THE SERVICE MENU OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS. IF YOU DECIDED TO ADJUST ANYTHING OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS, I WILL NOT BE RESPONSIBLE IF ANYTHING WRONG HAPPENS TO YOUR TV.)
  1. unplug tv
  2. press and hold at the same time “Vol –“ and “input” button on the TV set.
  3. while holding those buttons, plug the tv back in
  4. the tv should turn on by itself, keep holding the buttons until the letter “K” appears. Then let go
  5. then at the same time press “Vol –“ and “Ch. Down”, you should see the service menu appear (if it does not appear, try pressing the two buttons again, it needs to be exactly at the same time)
  6. Then use the “Ch. Down” button to navigate down the service menu until you see “Industry Init” (NOT Industry Init +cause)
  7. Then press “Vol +” to toggle it to “ON”
  8. Then “/////////////////” should appear.
  9. when the screen turns GREEN, unplug the TV. Wait about 30 seconds, then plug the TV back in.
  10. Then continue on with the initial setup again.
This puts the TV back into the “fresh out of the box” settings. See if this helps with your CC problem.
Posted on Mar 16, 2008
Black box with letters appears in middle of screen, how do I get it off?
Use the closed caption button(CC) on the remote and disable the closed caption feature or go through the menu and turn it off.
May 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Mar 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How can I active the subtitle and caption for tv programs
My Sharp TV manual says there should be a "CC" button near the upper right corner of your remote control. Keep pressing the button to go through the different options.
Not every TV program has closed caption, so it may not every time.
I hope I answered your question. Please rate me. :)
Mar 01, 2009 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
I am not able turn on CC (Caption)
Press the yellow button.
Down arrow to "closed Caption"
Press select.
This works for me on my AQUOS 46D62U
Jan 08, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp 37'LCD missing Close Caption in Component and HDMI input
I HAVE A SHARP SHARP LC19SB25U - 19" Class HDTV LCD TV. I can turn it on but I have no pictue and cannot use the remote that came with it. For some reason, when I press buttons on television or the remote, it won't respond. Can you help me.
Jul 31, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Closed Caption TV
Check your remote for a button marked SAP or CC.
Jul 08, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Turn off closed caption on input(component) on Sharp Aquos 42"
I have a Sharp Aquos 46" and go a Comcast HD receiver as well, and had the same problem turning off the Closed Captioning. I order to turn it off you need to go into the box user setting by (starting w/ the cable box and tv on) pressing the power button for the cable box then the menu button for the cable box. This will open up the user settings menu. Just toggle CLOSED CAPTION to DISABLED.
Jan 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
This is what just worked for me. If I can figure this out, anyone can :) We have comcast cable hddvr box, motorola 3416, and a new Samsung HD Plasma, but try this no matter what you have...
turn your cable box off, and THEN press menu on the box. A white screen popped up and this is where I had to scroll down to and disable the captions. I couldn't believe this worked since I thought the cables were enabled on my TV since my captions were covering my cable menus, but it was the cable. I hope this helps.
Oct 23, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
371 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
