Question about Maytag 7.0 Cu. Ft. Electric Dryer
Dryer making a loud clunking noise each rotation, sounds like a tennis shoe in it, without the tennis shoe
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Apr 01, 2010
SOURCE:
F&p gas dryer thumping noise when turned on. sounds like tennis shoes in the dryer.
Please check the roof first.
Then,
You have a part of the dryer has broken and is slapping the inside of the machine.
Please do not use the dryer again until it is repaired.
I say this because of the danger of fire, from the gas flames that dry the clothes.
God bless your efforts.
Apr 03, 2018 | Dryers
What is making mywhirlpool/admiral electric dryer sound loud and thumping noise
You dryer belt may be shot and a piece of rubber is missing making it jump while working. Needs replacing before it completely quits. It will eventually just break apart.
Apr 13, 2015 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Kenmore dryer making a thumping noise
Your dryer has rolls on the drum and they are going bad and need to be replaced
Mar 22, 2014 | LG DLG3788W Gas Dryer
My maytag Neptune dryer makes a loud 'cracking' noise on every rotation. It could also be described as if there is a tennis shoe in it. Is it worth fixing? Not sure how old it is, I know we bought...
UNPLUG FROM POWER OUTLET AND UNSCREW THE REAR PANEL . CHECK THE BELT PULLEY VERY CAREFULLY - IT SOUNDS LIKE THE PULLEY IS CRACKED ON A SUPPORT LEG . IF THIS IS THE CASE TRY AND REMOVE PULLEY AND PRICE UP A NEW ONE . YOUR C HOICE WHETHER YOU THROW AWAY OR FIX .SOME DRYERS LAST A VERY LONG TIME .PS ( I`M TALKING ABOUT THE LARGE PULLEY BEHIND DRUM).
Jul 26, 2011 | Dryers
My dryer (maytag atlantis) has started making a loud clunking noise with each revolution. its still drying fine but sounds terrible. any thoughts?
A loose belt will allow the drum to slip when clothes hit the paddles in the drum. It sometimes sounds like a pair of tennis shoes are in the dryer when it slips and is usually rythymic.
These machines also use drum rollers that can make a racket when they go bad.
http://www.repairclinic.com/Maytag-Dryer-Parts
Good luck.
Mar 02, 2011 | Maytag Dryers
My gas dryer is making a clunking sound on each drum rotation. It sounds like theres a shoe in it.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Nov 08, 2010 | Frigidaire FEF336BC Electric Kitchen Range
This started recently, my dryer makes a loud noise while it's drying. It sounds like tennis shoes are in there drying.
There are usually 3 rollers that the drum rides on as it spins. Sounds like one or more of the rollers has worn out
Apr 03, 2010 | Dryers
Dryer drum stopped rotating, dryer blower continues to work.
The belt probably broke, and coincidentally happened while drying the shoes. The belt is easy to replace. Open the back and you'll probably see the belt laying on the bottom
Nov 10, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Clunking noise, like a tennis shoe, top right rear of dryer
HI sounds to me like your drum support is worn, it would make a thumping sound. You have 2 you should replace them both.
If you are needing a part - call this toll free number 1 877-489-5610, I have used them many times, they are the best. Best of all overnight shipping!
Sep 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
TD 4112W Dryer does not auto reverse
my new dryer makes athumping sound when in use and it sounds like a pair tennis shoes are being dried
Feb 16, 2009 | Zanussi TD4112W Electric Dryer
Maytag 7.0 Cu. Ft. Electric Dryer Logo
9,422 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
