Question about Sony DHR-1000 DVHS VCR
DHR 1000 problems
Hi
Can you offer some advice ? My DHR 1000 suddenly started fast forwarding in the play mode. I couldn`t stop it.
Any button I push on the machine resulted in fast forward ! UGH.
However, when using my editing program on my attached PC, I am able to control all functions, except eject tape.
Any suggestions ? I`d greatly appreciate your help.
Thanks,
Mike Comeau
Portsmouth, NH
  • videoman49 Mar 17, 2008
    Thank you very much for your reply, but .. "electrolytic caps" ?
    What are these ? and how do I check them ?
    Thank you.
    Mike
    Champion:
  • 221 Answers
Sounds like a keyboard problem, but check all the electrolytic caps -- bad caps sometimes produce strange symptoms.
Posted on Mar 17, 2008
  • Don Roth Mar 18, 2008
    Capacitors are electronic components that are used to isolate DC voltages while passing signals to other circuitry, or to filter any ripple on DC power supplies. Their internal construction uses a liquid electrolytic, and as they age, it dries out and their function is reduced. You may need to take the deck to a local repair shop to have the caps properly tested and replaced if needed.
I would like some advice on how to fix my sony tc161sd cassette recorder that does not play or fast forward
The unit needs belts and lubrication as well as other things that are seen in the repair of this older mechanism.
Oct 12, 2016 | Sony Audio Players & Recorders
Denon DRM 740 tape does not play
hmmm...sounds like the transport motor/foot are stuck..open it up, and inspect around those items(where the tape actually clamps down) and see if you can see anything in there. Might even be a bug, no fooling..
as to repairs..you are most likely talking some major money, and a long time in the repair depot, which I believe is in Rio..I'll check that for you while you do this part.
Mar 16, 2008 | Denon DRM-740 Single Dual Cassette Deck
Why will the Pioneer RT 707 not work in playback mode?
No it is the same motor for both functions. Just check does the record/play switch operate or move when you operate the record function? I have a hunch that is the problem it may also be that the switch contacts are dirty or worn.Try to play a recording you made on another machine if it does sound and play on the other machine then the problem can only be this switch. Some more upstairs decks do have separate amplifiers for play and record .Nakamichi. Studer Revox Tandberg Uher and the such comes to mind These are those machines offering "Off tape" recording monitor. Then it will sport three heads and not only two I hope this gives clues where to start looking for problems
Sep 01, 2014 | Audio Players & Recorders
I Press Play Button, And Tape Goes Into Fast Forward Mode
Pinch Roller linkage is stuck. Clean and regrease and it will work right again- I have done hundreds of them
May 01, 2012 | Teac Audio Players & Recorders
Suddenly my Sony M-2000 Microcassette Transcriber will not PLAY. The tape will Rewind and Fast Forward fine, but when you push PLAY, it just beeps and won't move. Any ideas?
Just talked to Exec. Communication Systems. He said that the play motor is not turning (the rewind and fast forward uses a separate motor) and the problem is either the belt or the motor. They can repair them at $82.00 plus parts and shipping.
May 18, 2009 | Sony M-2020 Desktop Cassette Transcriber /...
Forward fasts on its own
you may want to try fast forwarding at 2x (that is, press the FF key twice), although the speed will be faster, it may actually stop for you, when you press play, rather than going to the end.
Feb 05, 2009 | Arris DCT6200 DTV Receiver
DHR- 1000
Recently repaired one of these with what appeared to be a power supply problem; found several defective capacitors on the drive board. The symptoms were similar to what you are seeing.
Aug 20, 2007 | Sony DHR-1000 DVHS VCR
Panasonic Mini DV Camcorder
Take the tape out to keep it safe, then remove the battery for 24 hours.
Apr 16, 2017 | Panasonic Palmcorder PV-GS15 Mini DV...
Sony DHR-1000 DVHS VCR Logo
284 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
