Question about Dryers
A lot of lint is getting by the in unit filter screen and is cloging the outside vent bird screen The dryer is about one year old and is a model DHDVH52
    Scholar:
  • 178 Answers
Check the seal for the dryer vent coming from the drum itself. It may just be a simple lint filter replacement that is realitively cheap and can be bought from www.marcone.com. If it is a top removable lint filter, the seals get worn out quite easily. Also, be sure to clean the lint filter after EACH load to help prevent it.
Posted on Mar 15, 2008
Dryer gets hot, turns but does not dry. I have cleaned the filter inside (big round one) and the small one on the front behind the door. No airflow coming out rear of unit.
Your outlet vent line is probably clogged with lint, etc. Usually it gets clogged either right at the dryer's outlet or at the outside port. First remove the flexible vent hose from the back of the dryer and clean away any lint or debris buildup, then check the rest of the line and outside port. Birds sometime like to build nests at the outside ports that are configured up high enough and the outside ports that are low will sometimes get toads/frogs in them. You can simply use a vacuum hose on anything you can't reach by hand.
Aug 17, 2011 | Kitchen Appliances - Others
It takes 2 or 3 cycles to dry clthes, has been going on for some time
That's typically an indication that air is not moving through the dryer. Check the dryer screen, make certain that it's clean. You may need to remove the back and clean out any dryer lint. If the dryer vent is long, it may have filled up with lint, restricting air flow. You may need someone to clean that for you.
Feb 06, 2011 | Dryers
I took out the lint filter to clean and it will now NOT slide back into the slot. It just stops about 1/4 of the way up the screen. This is the first time this has happended in the 2 years that i have owen...
you need to clean out the dryer or have someone come in to do it.unplug the dryer,remove the lint filter and then you have to remove the duct that the filter slides into and clean that but you have to take the dryer apart to do this,next you have to vac out the cabinet where the motor is and clean out the vent line,if it's a long run i use a leaf blower to do this,remove the vent line from the back of the dryer,go outside and make sure the vent is clear then go back inside stick the leaf blower into the vent line and blow all the lint outside.you have lint stuck in the tracks that the lint filter slides into,get a skinny long screw driver and poke out the lint,if you have an electric dryer you should do this once every two years if it's gas once a year so you don't have a fire,next time send the model number and the name of the machine you need help with so i can help you better,if you don't know how to take apart the dryer send the model number and i can help you but there is lint stuck in the tracks that the filter slides down into and if that's like that then you need to clean out the dryer
Dec 23, 2010 | Dryers
Why would the lint in my dryer lint tray be wet?
Could likley be a cloged or restricted dryer exhaust system test by starting dryer and go outside to the exhaust vent for unit and check airflow,you should have good warm airflow coming out of the vent.You need good air circulation thru the dryer to remove the moisture from the clothing ,with a cloged or restricted vent (exhaust )system it takes much much longer to remove the moisture from the system Hope this helps your concern
Aug 14, 2010 | Dryers
Will dryer still run and heat if one of the thermostats (cycling[internal bias], high limit, and/or thermal cut-off) is faulty? Would it simply 'blow' the thermal fuse (that i just replaced) again?
if the thermal fuse keeps blowing it's because the dryer needs a cleanout.you need to clean out the duct that the lint filter slides into vac out the inside of dryer where the motor is and if you have a shop vac put it on blow and blow off the motor,there's alot of lint stuck inside it that the vac can't get out,you can blow the lint from the back of dryer to the front so you don't have to pull the drum to clean it.if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to clean out the line,i've blown out bird nests and big balls of wet lint after people told me the vent line was clear also make sure the outside vent is clear no screens or cages if there is remove them all they do is catch lint.do this once a year so you don't have a fire and you won't have to replace parts from overheating,thermal fuse is a safety that will pop if the dryer runs to hot mostly from a clogged dryer
Apr 17, 2010 | Kenmore 62882 Electric Dryer
The lint from my dryer is not collecting in the dryer filter, instead it is blowing through the flexhose and into outside vent and clogging up
Here are a few ideas:
1) check the filter screen for holes,
2) check the screen for shape
3) check the screen for tight fit (it should fall/snap into a snug fit)
4) check the drum for a loose fit (there is a felt kit you can buy for this)
5) unplug the dryer and get old lint out of the duct in the unit and between the unit and the outside
and
TRY it again!
Dec 24, 2009 | Dryers
Vent was cloged with a birds nest now it wont heat
IF POSSIBLE REMOVE THE DRYER VENT FROM THE REAR OF THE DRYER AND VACUME OUT AS MUCH LINT FROM THE DRYER ITSELF SOME LINT MAY HAVE GOTTEN BACK INTO THE BLOWER
Sep 02, 2009 | Whirlpool GEW9200L Electric Dryer
Kenmore 70 Series - 2 years old. Won't dry clothes, but there is definitely heat. Had a similar problem a year ago and ended up being a bird nest in the vent piping. I took off the vent piping nearest the...
Check for lint build up in the flex pipe connecting the dryer to the vent pipe..
While it's disconnected clean the duct on the back of the dryer..
A great lint cleaner is a "webster duster" on a pole...you can get alot of lint out with one of these..
k
Jun 18, 2009 | Kenmore 63942 Dryer
Kenmore dryer 10+ years old model 86376100 63761
Make sure that the lint vent is attached properly to both the outside wall and the dryer. Also make sure that it did not get a hole punctured in it either
Feb 13, 2009 | Electric eBay offers you smart deals and...
Dryers Logo
141 people viewed this question
Top Dryers Experts
Marvin
Marvin
