Question about Hitachi DZ-MV550 DVD Camcorder
DVD Finalization I have a Hitachi DVD Camcorder. It uses the mini discs. I recently took some video and when I went to finalize the disc so I could play it on my TV-DVD the camera said "Finalizing" and never completed the process. After about 15 mins, it simply timed out. What could the problem be? I am using Sony DVD discs. This is the first time it did this. Thanks for any help. Terry
    Sergeant:
    Champion:
  • 306 Answers
Could be that the disk had a scrach, finger print, dust etc. try a new disk, if problem persist, clean lazer lens and try again. if still not work refer to manufacturer for replacment
Posted on Mar 15, 2008
    Brigadier General:
  • 6,966 Answers
To my understanding, the AC adapter of the Hitachi DZ-MV550 DVD Camcorder must be plug in for a successful "finalizing", pls post back if it was.
Pls post back as requested and will work from thereon.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Mar 15, 2008
    Hi again,
    With the indulgence of johnychel...
    Re-reading your post shows that this is the first time that this has happened. For the moment, I will assume that there is nothing wrong with the unit, you have followed the steps as outline in the manual and you are using the same type/specifications of discs (if not the same brand and model) as you have used before.
    Possibilities are:
    1. for some unknown reason, the AC adapter had a momentary glitch. This could be attributed to an unnoticed/too-fast power interruption. This could also be caused by jarring of the adapter from the wall outlet or power strip;
    2. the initially blank disc is somehow defective;
    3. it is probable that the movie length (time) exceeds the disc capacity;
    4. there was a bit of dirt/smudge on the failed disc. Alternately, it could be on the laser lens also;
    5. in some instances, it could be brought about by ambient temperature changes which could possibly cause condensation in the unit.
    Things you can try are:
    a. finalize again using another disc;
    b. let it sit for a while before finalizing;
    c. verify that the adapter would not loosen itself nor in a position that it could be jarred easily;
    d. verify that the disc has the capacity to hold the movie to be burned in terms of length of time;
    e. use a mini disc cleaner if at all available/possible.
    Hope this be of further help/idea. Pls post back how things turned up or should you need additional information.
  • Louie  Role
    Louie Role Mar 20, 2008
    Hi again,
    Any developments with your concern?
  • 796 Answers
Im guessing your talking about a new disc here , before you can do anything with the disc ,you will either have to format it or erase it, once you have donr that you can then use the disc and edit its contents. im assuming you are using the correct type of disc for your machine, eg dvd+rw or dvd-rw check the manual to make sure your machine can record onto a dvd+rw disc. hope this is of some help to you.
How can i get mini dvd to play on dvd player
Make sure that MiniDVD has been finalized in camcorder then it can be playback in any other DVD Player.
Finalize option would be available in camcorder dvd setup menu, select it to finalize recorded mini dvd disc, please note UnFinalized mini dvd disc will only playback in camcorder because of its raw data and Finalization will validate this raw data so other dvd players will recognize this mini dvd disc for playback.
Hope these info will help you.
Thanks.
Dec 17, 2010 | Hitachi Video Cameras
Can not get video files from a mini dis dcr dvd 108 handycam when I try to import to my pc it says does not support this dis i was using usb cable to pc with sony's software thanks jim
First make sure to finalize recorded disc in camcorder, finalization option is available in camcorder menu and will be enable by powering camcorder with AC charger/ adapter.
Now you can transfer movie files in computer or put recorded disc in computer dvd rom and copy files.
Jul 31, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
How do you finish a disc in a Panasonic DVD 3CCD DVD video recorder? I can't find the drat instructions
Finalization menu will come if camcorder is powered by its AC adaptor.
Plug AC Adaptor in your camcorder to get Finalization Menu to finish disc recording.
Thanks.
Dec 19, 2009 | Panasonic VDR-M53 DVD Camcorder
Viewing pictutes
Please finalize mini dvd disc if its full or when recording is finished.
Without finalization dvd will not be playback anywhere except camera.
DVD Finalize option is available in camcorder Menu.
May 11, 2009 | Sony Handycam DCR-DVD92 DVD Camcorder
HOW TO FINALIZE A DISC
I replied you in premium post as well. here is with details...
Be sure to use the AC adapter to power the DVD Video Camera when
finalizing a DVD-R disc. Finalization cannot be executed using a battery pack. Now you will see finalize option in menu and can select it to finalize disc.
Good luck.
Dec 24, 2008 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Mini-DVD playback
two things:
1) connect the camcorder to your computer using a USB cable and play it through that, by the way, what computer is it?
2) you can finalize without the ac adapter - its a built in safeguard to ensure that there is enough power to allow finalization to complete
Jul 18, 2008 | Panasonic VDR-D100 DVD Camcorder
Can not finalize
Hi, Initially I had the same problem with the finalization process. But then i took off the battery pack and connected to the mains and immediately when i switched on the camcorder again, the ' Finalize ' button was highlighted i.e enabled. I continued with the finalization process and everything was fine. Was able to playback the mini dvd on a very cheap dvd player and also on a computer.
Also be sure to put the camcorder on play mode by sliding down the switch button to mode. You immediately notice that a little green button near play will light up
Jul 15, 2008 | Canon DC210 DVD Camcorder
Power disconnected during finalization
There's no way you can continue the finalization of the disc, the disc has been marked as finalized already, even a single power fluctuation when you are using ac power adaptor can affect the disc finalizing process, so it is better to use battery when disc finalizing
Aug 30, 2007 | Sony DCR-DVD301 DVD Camcorder
Do I have to use the AC adapter/charger when finalizing a DVD-R disc?
I got a hitachi camcorder at a flee market and it did not come with an instruction book. Everything is fine up to the part where I have to finalize the disc in order to play it back on my DVD player or whatever. I have all the cords but don't know where the outlet on the camcorder is, in order to plug into the ac charger.. In other words: Where do I plug the cords. I can't find anything on the camcorder that will ssupport the cords,, Is there a hidden slot somewhere on the camcorder???? Please help, Email me at...... jackmoby2000@yahoo.com
Thanks Mel
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Hitachi DZ-MV550 DVD Camcorder Logo
156 people viewed this question
Top Hitachi Video Cameras Experts
Mohamed Ismail
Mohamed Ismail
Marvin
Marvin
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
