Brother Correctronic 40
No, after setting all night I still get no characters. The wheel moves, but the strike (whatever you called it) does not make contact with the rubber things. Yes, you are right, the thing is old, and if I can find another free/cheap one, I will replace it, but with 4 teenagers and 1 income, well...anyway yard sale day is today, maybe....
  • 398 Answers
Gently push the hammer up to the print wheel, does the notch in the hammer line up with the dimple on the back of the printwheel characters? You will have to look real close.
Posted on Mar 30, 2008
Brother correctronic GX-7750 daisy wheel electronuc typewriter. How do I make the letters smaller?
You change the print size by installing installing a print wheel wite a smaller type face.
DickyO
Dec 22, 2014 | Office Equipment & Supplies
How to install correctronic ribbon
Open top cover, small correction tape orange or yellow lift off is kind of tricky, left side goes on small spool holder feeding off the top and going around front of print wheel. by the way relaase the printwheel so it pivots back toward you, eaiser to see, correct tape goes in front of wheel and pivots very similar to left side. Correction tape has good side and bad side good side a matte finish should face away from you, this is the correction. Regular riboon just lifts up reom the front and snaps back in place. two little plastic tabs on back of ribbon case fits in two little holes in carrier. Hop this helps real hard to describe.just works...
Sep 29, 2013 | Brother Gx-8250 Correctronic Electronic...
How to you set a Brother GX-6750 typewriter to double strike each character?
It's called BOLD on that machine.
Press and hold down ALT key and Press RELOC/BS ½ (if you look it says BOLD above the key) You will hear 2 beeps
To cancel bold type [ALT] + [BOLD] again
Nov 30, 2010 | Brother GX-6750 Typewriter
Typed characters are too light
Most Brother portables have a coded feature to change impression. Look for the word imp printed on one of the keytops, usually the I key<Hold down the code key and then depress the imp key to cjange the setting.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jun 19, 2009 | Brother ML-500 Typewriter
Brother CE-70 typewriter. Was typing perfectly well. Over about 15 characters the impact on the print head reduced to nil. Although printhead appears to strike the daisy wheel the character does not strike...
Make sure that the ribbon is moving. If characters are piling up in the same spot on the ribbon you will get this problem. Easiest fix is to replace the ribbon. Many brand new ribbons can have a problem. If this dosent solve the problem it may be a mechanical problem with the mechanism that drives the ribbon, requiring a technician to repair.
Oct 22, 2008 | IBM Wheelwriter 30 Typewriter
No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Jul 09, 2008 | Brother EM-630 Typewriter
Brother GX-6750 correctronic
Check the print wheel to see if any spokes are bent or missing, be sure that you have the proper correction tape (tack free) and that you are not in proportional space or have an international print wheel.
DickyO
Mar 16, 2008 | Brother GX-6750 Typewriter
Brother Correctronic 40 Not striking
You’re right Brother authorized service centers are hard to come by and now that the one that I was working for went bankrupt I can’t buy parts any longer.
Let me see if I understand the problem. When you start typing it’s ok and as you continue typing it get’s lighter then it finally stops printing? If you let the machine sit like overnight it starts all over? If so what you need is a .20¢ rubber bumper used to lessen the hammer noise.
What happens is the rubber get’s sticky with the heat generated from use. I have tried to find a substitute (for the Brother part) and nothing I have found lasts very long. If you just remove the bumper the hammer makes a terrible racket (too noisy for more people), and I suspect if it were used without the bumper the hammer mechanism would rattle apart after a short time.
I know this can be repaired easily but not cheaply. The machine is old, it’s time to consider a replacement. Sorry!
Mar 14, 2008 | Office Equipment & Supplies
Brother GX6750 typewriter correcting on wrong line
It sound like either the operator is turning the roller (platen) to see where you should correct..or the linespace mechanism is turning the roller from the line of type.Perhaps the detent (by the line space selector lever is set to 0 instead of 1, 1 1/2 or 2
The line of type is important that is stays and not drifts. Tighten the platen knob if the screw in..right to tighten left to loosen.
Hope this helps
Jan 31, 2008 | Brother GX-6750 Typewriter
80 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
