Question about Microsoft Basic Keyboard 1.0A PS/2 KEMIBA
Worked when I powered down my pc now it does not - happened before
I have tried multiple restarts, tried different usb ports. Last time I accidently dropped the keyboard (really) and then it worked. Im using Vista
  • 148 Answers
A bad chip in the keyboard usually causes this problem. Replacing your keyboard with a new one is the thing to do
Posted on Mar 17, 2008
SOURCE:
Connect usb port
Check all computer connections and cords. Is the powerstrip for surge protector light indicator bar (usually inside the off/on switch itself) on?
All it takes is a pet to walk over it or a foot to bump a cord and break the power connection. Mine do it all the time. Check the power on/off button on the printer to see if it accidently got powered down.
Sep 19, 2013 | HP Officejet Pro K5400 All-In-One InkJet...
My powered USB port on my Dell Latitude D410 shorted out. Can this be repaired/replaced?
The USB plug will need to be removed from the computer, if luck is with you the computer will work, if no part is available, use a none powered USB hub on a spare port if available to run your applications.
Jun 23, 2012 | Dell Latitude D410 Notebook
Usb port on presario F500 quit working, they are seen by device manager but will not reconize a flashdrive when incerted, a mouse or any thing else. Using win 7,64 bit t3500 cpu.
This should be pretty easy to fix. I have seen this many times before. Here's what to do:
Go into device manager and expand 'universal serial bus controllers'.
Start at the very bottom, and start deleting the usb root hubs one by one. You will lose your touchpad control at some point, as the touchpad is actually a usb device. One of thwo things will happen.
1. The usb hubs will automatically be re-detected and re-installed.
2. You will just lose touchpad control after deleting one of the root hubs. If this happens, then shut down using the power button, and restart. Th usb hubs will be reinstalled once you log back into windows. Please let me know if this doesn't fix it.
Joe
Apr 07, 2012 | Compaq Computers & Internet
Valid input signal not detected
1 unplug Dazzle from USB. turn off pc, restart with out dazzle plugged in. shut down PC, restart then plug dazzle in after PC has restarted fully. if that don't work then go to step 2. ( sometimes using a different USB port works too)
2. uninstall it and reinstall it should work fine. i had the same problem and had to many things in the USB ports at the same time.
Dec 29, 2010 | Pinnacle Dazzle DVD Recorder
Wireless Logitech mouse with NO connect button on it. Only buttons on it are Power and Reset (and one to open battery case). Cannot figure out how to connect to receiver. Was previously connected, but I...
Ok, try this in the steps ordered
1 remove the receiver from the USB port
2 remove the battery from the mouse
3 turn on the pc
4 after everything is loaded on the pc, plug the mouse receiver into the USB port
5 put the battery back in to the mouse and let it "find" the receiver.
If these steps don't work, try doing the steps and use a different USB port. If that doesn't work try a different battery in the mouse.
If none of this works and the receiver hasn't been bent (happens allot in laptops), then it sounds like your mouse took a dump.
Mar 18, 2010 | Logitech Cordless Mouse
After accessing drive its shuts down and restarts pc
You may have already tried one or more of these things, but in case you haven't...
Plug the drive into other USB ports on the computer and see if it shuts down. If not, you have a bad USB port, so just don't use it.
If it shuts down, continue to second test.
The second thing would be to eliminate the disk drive as a problem. Try plugging it in to another available computer and see if you get the same problem. If it's okay, it would be a safe assmption to eliminate the drive as being responsible.
Next, eliminate any USB hubs you may have plugged in. Plug the drive directly into the USB port on the computer and see what happens. If it works without problem, the hub is most likely the problem. If you still have the problem, follow next.
Next, I would try using one or more other USB peripherals and plug them in and try using them. If that causes the same issue, you probably have a power supply issue (even if everything is powered fine) as one of the power leads may not be putting out the required voltage. Last possibility could be a problem with your motherboard.
Oct 18, 2009 | IBM USB Portable Diskette Drive (05K9276)...
Printer to computer connection failure
I assume you're using a USB connection. What you fail to mention is whether you're connecting the printer directly to the PC or through a USB hub. If the latter is the case, because we now have so many USB devices, it is necessary that this hub be powered by its own power supply.
It's very common for these hubs not to work unplugged when devices draw a lot of current which they cannot generate from a simple connection to your PC.
Other than this possibility, I'm also stumped.
Try looking in your user's manual for a built in printer TEST function, usually pressing down some button while you turn power on to the printer. If there's anything wrong with the printer, these diagnostics will tell you what it is.
If all is well, try connecting the printer to a different USB port on your PC. Try testing each USB port with a different device, like a USB pen, to determine that it is not the port.
Aug 26, 2009 | Epson Stylus NX400 InkJet Printer
Power Surge on USB Port
I'm assuming you're not using a hub but plugging directly into one of the USB ports on your laptop?
First, have you installed all current patches for your PC? I think this was a common error message that was hotfixed some time ago, so be sure your OS is up-to-date. If so, you could try to uninstall all USB ports in device manager, then restart. When your system is up, go to the first USB device and right-click, then turn off warning messages. This is just for the error message, you may have a problem with your Zen as well so try it on a different PC if possible but I'd do that when it's fully charged. You may need to do a hard reset (instructions in your manual) to get it to work but that may delete all of the Zen's contents, so that's a last resort.
Aug 05, 2009 | Creative Labs Zen MicroPhoto MP3 Player
Problem with the USB port
Don't worry about the toner -it's gonna be more costly to replace your PC if you keep using this printer. i don't know the cause , but obviously if it has happened on multiple computers, there is some sort of short or something going on. Besides, a new printer these days (get your self an HP) is only about the price of a toner cartridge anyway - $100 +/-
Mar 25, 2009 | Brother HL 2140 Laser Printer
2 of 4 USB Ports Not Functioning
Most likely a motherboard problem, though you can try and re-do windows, best bet on getting it all to work is Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Though this might really get on your nerves having to do this multiple times, id get a new motherboard.
Dec 26, 2008 | Gateway 4540GZ Notebook
Open Questions:
See all Microsoft Basic Keyboard 1.0A PS/2 KEMIBA Questions
Computers & Internet Logo
66 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
