Problem with washing machine
The washing machine will begin a wash cycle but then stops and displays an open door light, but the door is firmly shut
  • 1 more comment
  • jill310 Oct 31, 2008
    "door closed?" alert keeps coming up, even though there is nothing blocking the door and door is shut frimly.
  • lambhuna Dec 05, 2008
    When I close the washer door and change the dial to start a new cycle the door open light illuminates, eventhough the door is closed properley.
    I have also replace the door locking mechanism with a brand new replacement, but the problem persists!
    Please Help!
  • lambhuna May 11, 2010
    I spoke with an electrician who advised the 3 things that need to be checked are as follows:
    1. Door locking mechanism
    2. Wire connecting the locking unit to computer
    3. The computer itself
    As I have already replaced the door locker with no resoloution I'm unsure it makes financial sense to buy the other parts. Does anybody else have any advice for this problem?
    Thanks Lambhuna
    President:
  • 1,314 Answers
Id check the door switch it may not be able to tell the control the door is closed
Posted on Mar 15, 2008
I dont have a stop buttom
You're start/pause button should pause the cycle, cancell should completely cancell. After pressing the Start/Pause within a cycle, the door lock may require time to unlock as indicated by the lock light on the panel.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Can't get machine to start a cycle. When press the start/pause button, the door open light begins to flash. After a few seconds, it stops flashing and the start/pause button begins flashing. I have checked...
It is hard to tell if there is no model number. Normally, WP machine has error code appeared on the display. I guess your unit does not have display, so the combination flashing is a signal to tell you what wrong with the system. You can check the service manual normally taps inside the unit.
Oct 22, 2013 | Whirlpool Washing Machines
Stop halfway hygiene wash 90degree
Do you have power to the unit? Does the display light up?
Nov 28, 2012 | Washing Machines
My washing machine is starting and stopping and the door light keeps flashing
your door is not shut properly or your door interlock has gone open ciruit try pushing the door firmly and let me know if that worked if not i can advise you moor
Nov 11, 2011 | Washing Machines
Door wont unlock once a wash cycle has begun
that is correct ,. pump water out then the door will open.
May 20, 2011 | Kenmore Elite 45986 Front Load Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Zanussi IZ 12 Washing Machine Front Load
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Aug 28, 2008 | Zanussi FJS1225W Front Load Washer
Washing machine prob
You need to replace the door interlock. Try giving the handle a firm push and see if the machine will start.
Oct 29, 2007 | Whirlpool Duet GHW9150P Front Load Washer
GE Model WBSE2090A2WW - shut off intermittenly
Does the machine drain on its own or do you drain it manually? The drain pump may be jammed or seized. Try giving the door a light bang with your hand on the handle. The door interlock could be faulty. If the machine starts up after you hit it with your hand on the door handle, the interlock is faulty. Good Luck!!
Sep 07, 2007 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
