Question about Archos 605 Digital Media Player
Tv update won't download it starts but stills out after day 1 it also doesn't update the time or access the content portal. I have tried to reformat the hard drive but the same thing keeps happening.
  • Anonymous Apr 17, 2008
    Same here. Gives me error :
    "TV program update failes"
    -100
Good luck
Posted on Mar 23, 2008
Good Day! i have a aspire 6930. I've had it for a
The average life of a laptop is 5 years. Your model was made in 2008. Replace it.
Mar 01, 2017 | Acer Aspire 6930-6455 Notebook
How to activate gprs in bsnl in samsung galaxy
Gprs settings varied from location and operator, you may want to call support of your current network provider. then ask them about settings and activation of gprs on your phone model, this oftently come free.
Aug 18, 2010 | Cell Phones
Cannot start laptop without battery
try to flash the bios. download it to this website:
http://support.fujitsupc.com/CS/Portal/supportsearch.do
select the bios update. if it is still not working, call the fujitsu tech support. it might need repair already. number is 1-800-8FUJITS (1-800-8385487)
Feb 17, 2010 | Fujitsu LifeBookS6120 Notebook
Sansa e260 says cannpt load image switch to recovery mode
download the update software and install then.. lock your sansa, hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer... Download the sansa update software
(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe).
You may need to make sure you are connected to a 2.0 USB port if your computer is not IDing it, try a friends computer or a labtop... USB modes msc...
Start the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa hope this works.... Please rate...
Jun 06, 2009 | SanDisk Sansa e260 MP3 Player
Aspire 5610 won't go past stage 3 configuration update
If you need to reformat the system, you can usually access Acer's built-in eRecovery by pressing Alt-F10 at the splash screen. Just bear in mind that restoring the system to factory specifications will erase the contents of your hard drive, so please ensure that your important data is backed up before doing so.
The "Vista Boot Loop" is a known issue though, but does have a solution, see here
If you are unable to use the repair portion of those steps, there is another workaround, but requires the use of other bootable media, such as Ubuntu (which you can download for free here). From there, try following these steps to get the pending.xml file renamed (see Comment #12 specifically, when using Ubuntu)
If you can solve it using the latter method, then you can get back into the system without having to reformat the entire hard drive and starting over.
May 08, 2009 | Acer Aspire 5500 5570-2609 Laptop
Can't update symantac 11
please see to it that the product is genuine
When live update fails, it is most likely due one of the following reasons:
· No license file (*.slf) is installed
· The installed license file (*.slf) has expired
· The trial period has expired
· The installed license file (*.slf) has been deleted, or become damaged or corrupted
· The software is not able to able to communicate with the Symantec servers
It is necessary to have a valid license file installed into the program to authorize it for the download of the content updates using Live Update.
It is necessary to register your license(s) at the Licensing Portal (https://licensing.symantec.com/) to generate the license file if it was not included with your license certificate (*.pdf).
The license file (*.slf) has expired
It is required to have a current support contract to be authorized to have the most current content updates downloaded. If you have renewed your support contract, it is necessary to register your license(s) at the Licensing Portal (https://licensing.symantec.com/) to generate the new license file if it was not included with your license certificate (*.pdf).
This could also be the case if you have a current support contract, but had a trial license key installed in the software. It is necessary to register the support contract renewal to generate the new license file.
Many of Symantec's products offer a limited-time trial period where you can test the software in your environment. When the trial period expires, the software will typically cease to function as part of the Trialware installation agreement.
The installed license file (*.slf) has been deleted, is damaged or corrupted
If the license file that was installed in the program has been deleted or is corrupted, it is necessary to reinstall the license.
You can re-download the license file from the Licensing Portal account the license was registered in. If you registered the license into your Licensing Portal account, you can log into your account and re-download the license file. If the license was registered into the account of another person, you would need to contact that person to have them re-download a copy of the license file or provide you access to re-download the license file from their account.
The software is unable to communicate with the Symantec servers
The Symantec software must be able to establish a connection to the servers to be able to download the current content updates. If the software is unable to establish the server connection, then it will not be able to download the content updates.
You would need to check your network security settings to ensure the network traffic is not being blocked. If you believe your network's security settings might be blocking the Symantec software from communicating to the Live Update servers, contact Symantec Technical Support for assistance. You can find the phone number for your region here: http://www.symantec.com/business/support/contact_techsupp_static.jsp
One example of this occurring is when trying to install a license file into Symantec Mail Security 4.6 or later you get the following error message: "Symantec Premium AntiSpam registration failed. The product will not receive definition updates".
Here is a link to a technical support document with more information on this issue and possible resolutions: http://service1.symantec.com/support/ent-gate.nsf/854fa02b4f5013678825731a007d06af/e0395129f0bedbf4882570d2006ad1af?OpenDocument
(i took it from "http://customercare.symantec.com/app/answers/detail/a_id/81/kw/update/r_id/166" )
Apr 22, 2009 | Symantec Norton AntiVirus 2008: Windows
Archos driver and content portal
I think that the driver update that you're talking about is the firmware update, it is free to get the update through the archos website. All of the songs from itunes can't be put onto the archos. If you want the content portal you must purchase the cinema plugin. (that's the way archos designed the product) Your archos must be set on window media player first, before you can put your songs onto it, go to menu, click system and choose window media player and you can transfer your songs. Call tech support at archos 18773008879. This should help.
Apr 11, 2009 | Archos 605 WiFi Digital Media Player
Canit get BBCi player to work on my Nokia N96
"N96 features of the DVB-H TV Tuner doesn’t work in Australia because there are no DVB-H TV broadcasts and won’t be for at least a couple of years"
from -
http://www.itwire.com/content/view/21033/1168/1/2/
Dec 10, 2008 | Nokia N96 Smartphone
HDD Corrupt
I have the XS35 and the HDD drive is curropt. Can I do the following?
1. Download the Toshiba firmware update:
http://www.tacp.toshiba.com/customersupport/model_firmware.asp?model=rd-xs34
2. Burn the ISO to a CD-R disc. ImgBurn is an excellent free burner for this.
http://www.imgburn.com/
3. Insert the CD in your unit. It will auto-install the firmware. Follow onscreen instructions. Takes about 10 minutes total.
After the update, my existing HDD shows are playable again, and I can record and playback from the HDD. I bet it would be a good idea to periodically backup your shows on DVDs, and regularly reformat the HDD.
Mike
michaelz@resourceinternational.com
Oct 18, 2007 | Toshiba RD-XS34 DVD Player/HDD Recorder
Archos 605 Digital Media Player Logo
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
