Question about RCA HD52W59 HDTV Projection Television
Conversion the conversion options has been moved from the auto tuning and I have a bad picture
  • Freakfromhel Apr 30, 2008
    I have this same problem. Please HELP ME!!!!
    red blue and green lines and a bent picture. I can't find the reciept and RCA will not go good. it's 8 months old.
    slipknot0147@hotmail.com
    model number HD52w59
    serial number f254c1080d
    HELP!
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
This unit has many convergence problems but most of the time the convergence power supply is defective. That defective part sometimes opens a cp (circuit protect fuse) on the deflection/power bd. Please provide the service # from the back of your unit (found in small writing on the same tag as the model and serial #) this # will have the model and then some letter and #'s after the model. With the service # I can provide specific info. like part #'s.
Posted on Mar 17, 2008
What do i do to change from manual to auto channel set up?
It is very simple, open the tuning menu select auto search option and proceed to auto search.
Sep 10, 2014 | Televison & Video
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
LG model NR CI-14F80FS Moved the TV for an elderly person,using the remote, how do I start the automatic re-tuning avrilmiller@btconnect.com
By pressing menu botton on remote then chose setup/then channel setup before presssing auto tune or channell auto programm you may choose air or cable option then you can go for channel auto programming and your supposed to be done.
hope that will help you
have a nice day
regards alan
May 14, 2010 | Televison & Video
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
TELEVISION
Samsung tellys top level menus should have a choice of four or five sub-menus.
The one you want is that represented by a picture of a satelite dish / antenna. Dont worry if you dont get your TV via satelite, this is just the symbol they use to denote the tuning options.
Down arrow to the satelite dish sub-option and select enter. This should then give you several more options, one of which is Tuning, Select this and then select Auto Tune, then press enter and the set will completely retune itself.
If youre asking this as a result of yesterday's Freeview retune, then you may well end up with some "dummy" channels - i.e. they either have nothing at all displayed or a message telling you the channel has moved - or some of the channels have an incorrect name. I'm hoping that now the retune has happened, in the near future these dummys or errors will be fixed.
Some Samsung TV's dont have a "tuning" sub-menu but "Channel(s)". Selecting this will then give the Auto Tune option.
Oct 01, 2009 | Televison & Video
Options to auto-tune or manual re-tune are greyed
Problem solved!!
According to the Sony website I needed to get a software download in order to fix this problem. I found out how to do this from the manual and realised that the re-tune menu I was looking at was for analogue only. The pictograms onmy remote control are a blurred but the manual helpfully provided a picture showing the correct program "info" button (next to 0) which has options to look at other things, including a "detailed set up" menu on the blue tab, which provides options for software download and re-tune of digital channels.
Incidentally, I discovered that my TV model was not quite as quoted above - it is KD-28DX200U, but expect the same process works for other oldish models.
Oct 01, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Can not get menu option for retuning
If youre asking this as a result of today's Freeview retune, then you may well end up with some "dummy" channels - i.e. they either have nothing at all displayed or a message telling you the channel has moved - or some of the channels have an incorrect name. I'm hoping that now the retune has happened, in the near future these dummys or errors will be fixed.
Sep 30, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Can not get the image back on my astar hdtv when I choose the option
First check Tv menu comes on screen?
Connect DVD Player at any a-v input and confirm picture on tv. This will confirm that tv has no problem except in tuning circuit.
Now check Antenna / cable hooked up in RF input of tv properly.
Perform Auto-Search / Auto-Tuning / Auto-channel on TV menu and tune all available channels.
Still blue screen? means TV Tuner looks bad.
Sep 16, 2008 | Astar Televison & Video
Sony Trinitron TV Model # KD-28DL10U - Freeview problem since Aug 5
press the button to left of the 0 button on the the remote for digital display, then press the blue button on remote to display main menu. scroll down to auto tuning and press ok, then press red button to begin tuning.
hope this helps!!!!!
mark
Aug 16, 2008 | Televison & Video
RCA HD52W59 HDTV Projection Television Logo
49 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
