Question about Gateway FPD2275W LCD Monitor
Monitor error when i use the PC monitor setting automatically pops up, for temp fix i switch off my monitor and switch it back on again and will last about 10minutes before i will have to do it again. Please can you help ?
  • Anonymous Apr 20, 2008
    menu always occur on screen it cant be exit from switches on monitor panneel, it always appear and disapper again again problem occur from last two month all virus scan done prob. remain same
    Novelist:
  • 138 Answers
Try to do the factory reset in the pop up menu screen.
Posted on Mar 16, 2008
How to switch from analog to digital mode
Any contemporary monitor is able to switch analog/digital mode automatically if connection from signal source to monitor is set up properly.
Connect digital output from your graphic card to DVI input of the monitor. Disconnect any other signal cables from monitor and switch on both devices (PC & monitor). Wait a while. Monitor checks its inputs and a activates digital DVI, because it is only one active input on it.
If none picture excluding error message of monitor is displayed, go through these steps:
1) Check whether your monitor is set for automatic input selection. If monitor buttons have no response try to use analog input to activate screen (any picture, desktop background...) and then get monitor menu access by pressing menu button.
2) Find out what connector type has your graphics card in PC. Possibilities are: DVI, HDMI, DisplayPort and some their options. See Wikipedia for connector look if you are not sure.
Remember that blue D-SUB (VGA) connectors are analogue and you cannot activate digital mode through analog VGA cable.
3) Use appropriate cable to connect monitor to PC.
Example: Your PC has HDMI output. Use HDMi-to-DVI cable. Your monitor input is DVI and common DVI-DVI cable is not suitable in case you have PC with the HDMI.
Note that DVI-to-DVI, DisplayPort-to-DVI etc. cables are available. You must buy right one.
Be aware that "Auto" button is inactive in digital mode of monitor.
Nov 18, 2013 | Belinea 1930 S1 Monitor
We leave our computer turned on at night but we turn off the monitor. The last two weeks when we have turned on our monitor in the morning it will show the desktop but when we move the mouse the monitor...
Yes. Do not turn the monitor off by its power switch, let the computer do the work for you. Alot of times when people use the power switch to turn off the monitor, the computer sees that all of a sudden the monitor has been disconnected from the pc. when that happens the pc sees it as a device beimg unplugged and removes that certain device from the pc's list of things that should be connected, and when you turn it back on the pc sees it again and starts loading drivers for that new part(monitor)
Sep 21, 2009 | AOC LM729 17" LCD Monitor
Compaq TFT 8020 Display Problim
have you tried going to menu and setting back to factory defaults? also, disconnect power cable and leave unplugged for 1 minute. Plug back in then see if problem is still there. Otherwise, something is wrong with the monitor that will need serviced or exchanged.
Jun 24, 2009 | Compaq TFT8020 (White) 18" LCD Monitor
Monitor Resolutions Menu Pop ups
Please disable this notification from settings menu of monitor. you should find it under settings or notification menu which can be accessed via switches on monitor.
Jun 14, 2009 | E-Machines eMachines Desktop PC
The monitor on my laptop has been broken for a while so i'm using an external monitor, now all of a sudden when the laptop gets to the loggin screen it switches to the native (broken) laptop monitor and...
open the device mgr. and disable the internal and set the external as default windows should set it as default automatically when disabling the internal
Dec 21, 2008 | Computers & Internet
Audio adjust screen pop up
I contacted ViewSonic with the same problem. They told me to turn off the monitor and unplug all the cables. Then hold the power button on the monitor for 10 seconds. Turn it back on and it should be gone.
If that doesn't work, I was told to do a memory recall on the monitor by pressing the 1 button and selecting memory recall from the list. It sets the monitor back to factory settings.
I haven't tried any of these yet but hopefully they work for someone.
Dec 20, 2008 | Computers & Internet
Computer turns off and restarts again during the operation repeately.
Hi 2gerr, when you tested the board, was the board outside of the you're case?
Here is one suggestion you can try. Start the PC & press the F5 key every two seconds untill Windows Advanced Options Menu
is displayed on you're screen. You can not use you're mouse here. Use the up & down arrow keys & slide to, Disable automatic restart on system failure. Than press enter. What this should do for you is stop windows from restarting & give you time to catch what is causing windows to restart. If you receive a blue screen with an error message write it down. Press the pause key on the keyboard so you'll have time to write down the error message. It would not hurt to enter you're bios and turn off hault on all errors listed in the main menu of the bios.
Another could be the back side of the board could be touching the case. You can add a piece of a paper bag under the board.
Stopping a possible short. Lastly, enter you're bios & go the hardware monitor. Open hardware monitor & leave it there. Shut off you're monitor & walk away for about 10 minutes or so coming back from time to time & check the temp of you're CPU & mother board temp. Staying in the bios, let me know if the PC restarts.
Mike
Apr 25, 2008 | EliteGroup P4M800-M7 Motherboard
Relisys tl 766 monitor
ok i think i know how to get rid of it now, i did an ATX reset on it and it does go away HOWEVER as soon as you push the menu button again it comes back.
ATX Reset: unplug the main power lead then hold down the power button on the front of the monitor for about 10 seconds, plug the mains lead back in and then switch the monitor on.
Jan 15, 2008 | Relisys TL 766 Monitor
Problem on hp monitor
I have a Dell E171FPB monitor that had the same problem with the Main Menu coming up and I thought I would tell you what I did to fix the problem.
1. I shut down the PC.
2. I removed the power cable and video cable from the back of the monitor.
3. I removed the four screws that hold the stand for the monitor and slid the stand off.
4. I then removed the 5 screws that hold the back cover on the monitor.
5. I took two flat blade screw drivers and carefully removed the back cover.
At the bottom of the monitor case, there is a small circuit board the holds the 6 switches for controlling the display.
6. I located the button that calls up the Main Menu. It is the second switch from the left as you are looking at the monitor from the rear.
7. I used a small solder iron and heated up the four prongs in sequence while holding the switch with a pair of needle nose pliers. I had to rotate this process from one prong to the other while all the time applying slight pulling pressure on the switch pulling it away from the circuit board.
8. Once the switch was removed, I put the cover back on and tightened up the five screws.
9. Then I slid the base back in the slot it came from and tightened the four screws.
10. I connected the video and power cable and turned on the PC.
With the switch removed the Main Menu never popped up again and I am so very happy.
Dec 17, 2007 | HP vs15 15"LCD Flat Panel Monitor
The OSD Main Menu button keeps popping up every 5 seconds and whenever I exit it always takes me back. I've searched everywhere and found no solution just more people with the same problem so if I actually...
f1703 monitor >> too simple!!! Unclip the front cover that sits around the front screen. >Becareful not to break the clips.>Remove the adjustment 715L1009-1-B (MANNEQUIN KEY BOARD) it has 2 screws and unclips from opposite side of the board. >> Clip back the surrounding cover.
Job done, no more OSD MAIN MENU ON YOUR SCREEN.
And you do not need to replace the board, your monitor will work just fine.
Nov 29, 2007 | HP Pavilion F1703 17" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
57 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
