Question about Acer Veriton 7600GT PC Desktop
Motherboard settings Hello! I've took the motherboard of an Acer Vertion 7600GT into a custom pc... How shall the motherboard settings be? I can't turn on the computer :S (where shall the poweron wire be plugged in etc.)
  • 655 Answers
Axesus here is a picture of general mo ther board. Just try to study and find the port matching in this figure.
I think it will help you to fix your problem.
Posted on Mar 15, 2008
Acer Aspire M5630 Series Original Desktop Motherboard Eg31m reboots
hey there, i know that problem u need to apply a new bios u can find it here : m5630
Nov 23, 2013 | Acer Aspire M5630 Series Original Desktop...
Short circuited laptop motherboard
get a new motherboard that is simplest and most effective
May 29, 2012 | Acer Computers & Internet
How do i get my speakers to work again?
The problem is in the audio output chip located on the motherboard, it will need to be serviced. Go to contact customer support and the technical department, they help you since warranty is so close.
May 02, 2012 | Acer Aspire 7741z
How much ram does acer vertion supports?
Max Supported RAM 4 GB
Supported RAM Speeds 400 MHz • 333 MHz
Number of Memory Slots 2 x 184 Pin DIMMs
Aug 23, 2010 | Acer Veriton 7600GT PC Desktop
Acer motherboard diagram needed
hello there here is a weblink that will get you going in the right direction
i know you have the acer motherboard but the pins will generally be the same ok?
here is a pdf downloadable flile that will help you.
best regards michael
  1. [PDF] A7V133-VM3051k - Adobe PDF2.gif - View as htmlSupports Socket A-based AMD. Athlon™/Duron™ processors. North Bridge ... p.37 System Power LED Lead (3 pin) 22) RESET (PANEL) p.37 Reset Switch Lead (2 pin)
Sep 16, 2009 | Acer Computers & Internet
My motherboard is fried.
Check out or some of the other sites like it. You can get a motherboard but you will need to know what you're doing to get it all back up and running correctly. If you aren't sure have somebody do it for you. The boards are actually pretty cheap but it depends on what else you may need to go with it.
May 13, 2009 | Acer Veriton 7600GT PC Desktop
Things to consider when replacing a 5600G case
I assume this is an ATX motherboard. Most cases should work. I think most cases come with a power supply but if not make sure yours will fit. I like cases with at least three drive bays which give room for expansion. The biggest problem I see with switching cases is connecting the wires for power button, hard drive LED, re-set button etc. to the motherboard. Maybe you will get a schematic with the case. Some boards are not marked very clearly in this area. You will need a magnifying glass to read this information on the MOBO. Trace the different colored wires back to the case to see what they do.
Jan 04, 2009 | Acer Veriton 5600G PC Desktop
Compatible AGP at 16x?
After a brief check of motherboard specs, what I see is, the 7600GT card will run at 16x in the 16x slot, but if you have TWO SLI cards they both run at 8X. Makes sense. Unless there is a public outcry concerning this, I'd suspect the info you have is a bit off. ZT3000 "Beta tester of "0"s and "1's"
Aug 20, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Acer Veriton 7600GT PC Desktop Logo
202 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
