Question about Sony Handycam DCR-HC20 Mini DV Digital Camcorder
Unable to record.
Unable top see anything thru the view finder or LCD screen, when hit record button it records the sound but no image.  Can play back and view past tapes on the camera. HELP please!
    Brigadier General:
  • 6,966 Answers
To my understanding, this is a known/common issue with this particular brand/model. It would seem that the CCD is defective. Further, I believe Sony is repairing it as a settlement of some sort.
Am not sure if still covered, but you can try (866) 703-7669, or go to www.sony.com/ccdservice.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 16, 2008
  • Louie  Role
    Louie Role Mar 16, 2008
    Hi again,
    There are two other things you can try:
    1. have the CCD replaced (between 100~200 USD);
    2. "not so gently tap" the right side. This is of course a non-technical, no-guarantee, "you did not hear it from me" sort of temporary workaround.
    Cheers.
  • Louie  Role
    Louie Role Mar 20, 2008
    Hi again,
    Any developments with your concern?
  • 73 Answers
Go to sony try updating it firmware inside ok 1st
SOURCE:
I HAVE A SONY DCR TRV25E AND AM UNABLE TO RECORD THERE IS NO PICTURE APPEARING ON THE LCD SCREEN OR VIEW FINDER BUT WHEN YOU PLAY BACK TAPE U STILL GET SOUND BUT NO PICTURE
Sounds like its fried, there is probably not a fix for the problem that will not cost more than the camcorder.It could be the power converter on the device, a voltage regulator or capacitor might have gone thus cutting power the certain parts of the device like the screen and CCD.
May 02, 2011 | Sony Handycam DCR-TRV25E Mini DV Digital...
The problem i m having with my camcorder is when i want to record film screen goes blank but i can watch my previous recorded videos
Look in the view finder when recording instead of the screen. if you see the image there then the unit is probably set to look through there. Many of the new units dont' have a full view finder to lens item they actually have a small lcd screen inside the view finder. Check your options for recording.
Also if the view finder is tilted you need to close that before usign the lcd.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
Mar 02, 2011 | JVC GR-DVL820U Mini DV Digital Camcorder
My Sony DCR-HC40E has a fault with the touch screen. The touch screen is not displayed so I am unable to play/edit or even record/view anything. The screen is usable if you know where the controls are...
Hi!
The flat LCD cable which goes through the hinges has broken - a common problem with many Sony camcorders. You will have to give it to Sony for repair.
I work for Sony.
Tom
Oct 09, 2009 | Sony Handycam DCR-HC40E Mini DV Digital...
LCD problem
the flex wire of the lcd monitor is already cut ...go the service center for replacement of the flex wire...or to the other service center for fixing the flex wire...it is to difficult to fix the wire if you are not a technician cause that wire is like a strand of hair....
Feb 26, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Sound but no picture.
if you are able to playback previously recorded cassette and the picture is perfect then its not the head. then the problem is with the image grabbing section i.e. the CCD. May be its damaged and needs replacement.
Jan 19, 2008 | Video Cameras
Sanyo digital camera model- vpc5500
Playing Back Movie Clips
You can play back the recorded movie clips on the LCD monitor screen. However, the
sound recorded with movie clips can only be played back on a computer.
1. Press the button.
2. Use the four-way controller (����) to go
through the images until the movie clip you
want to play back is displayed.
�� To view the previous image, press the
four-way controller (��).
�� To view the next image, press the
3. Press the button to start playing back
the movie clips.
�� To pause or resume movie playback, press the button again.
Dec 25, 2007 | Cameras
Black LCD and view finder
you need to go to the service center for replacing the ccd image sensor...i know it is free for replacing that image sensor cause your camera is one of the recall product due to the production error of the image sensor...log on to the sony site and go the costumer service ...
Nov 13, 2007 | Sony Handycam DCR-HC30 Mini DV Digital...
Camera mode recording/displaying right
what is the model number? if it's 10 years or older you are most likely dealing with bad surface mounted capacitors.
Sep 16, 2007 | Sony Handycam DCR-TRV140E Digital...
Sony F55 Recorded Display
The filename (e.g. DSC0012.jpg) shows the image number, the filespec shows the date and time recorded. Most software will give you document info about resolution of the image. I wouldn't worry about what the battery status was when the shot was taken or how many other images were on the Mstick. I guess I'm not sure what you need.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Sony Handycam DCR-HC20 Mini DV Digital Camcorder Logo
98 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
