Question about Kenmore 42822 Front Load Washer
Is it possible to change hte direction the door opens
Just purchased a new machine and would like to change the direction the door opens from left (asa facing the machine) to right. Is this possible? and if so how is it done?
Thank you
    President:
  • 1,314 Answers
No its not possiable because of the latch assembly
Posted on Mar 15, 2008
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
I want to change the direction of the opening on my kenmore from right to left. Is this difficult?
Hello and Welcome to FixYa!
What I understand from your query is that you want to alter the door opening direction If I'm right... Altering the door such that it opens on the counter side is possible. but in most cases, it ruins the working of the device completely.. actually changing the direction causes many things to go wild from the refrigerator light switch. to the refrigerator doors gasket. Also it requires some new holes to be drilled at the other side... That turns the alteration to more complex and tricky.. In a nut shell, I would not suggest to have such changes to your equipment.
Have a nice day,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Sep 18, 2010 | Kenmore 64823 Top Freezer Refrigerator
Looking to change right hand open door to left hand?
It is not possible to switch the washer door directions, but is is possible with the dryer door.
Jun 12, 2010 | Maytag NFW7200TW Front Load Washer
The door on my dryer and washer open the wrong way
Are you planning to reverse the door swing direction on your
DUET®dryer? To do so, you will need to purchase a Door
Reversal Kit.
To order, call the dealer from whom you purchased your dryer or
refer to the "Assistance or Service" section of this manual. Ask
for Part Number 8530069 (Shield Blue), 8530070 (Shield
Platinum), 8530071 (Biscuit) or 8530072 (Pewter).
Door Reversal and Stack Combination Kit
® ® DUET dryer and stack your DUET washer and dryer? To do so,
you can purchase a Door Reversal and Stack Combination Kit.
for Part Number 8530073 (Shield Blue), 8530074 (Shield
Platinum), 8530075 (Biscuit) or 8530076 (Pewter).
From the manual, Page 4. Hope this helps
Eric
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0802161.pdf
May 24, 2009 | Whirlpool Dryers
Basket will not turn
there is also a motor controller, in hte front left corner of hte machine, chance are it too was under water, and will probably need changing
Dec 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Machine stops after wash cycle, restarts when i bang the lid.
sounds as if hte lid switch is not activating correctly, the lid actuator is actulle hte under side of left hand door hinge. if you lkift the lid and feel under the left side og the lid you fell the metal lid hinge, simply slip a hollow shafted screwdriver over the hingeitself and bend slightly back, this will make the lid come in contact with swict a little bit easier
Dec 12, 2008 | Kenmore 24032\24036 Top Load Washer
Left ge stainless steel fridge and freezer door open acciently
youll need to unplug and defrost all the ice from hte back panel, leave unplugged for a min of 24, hours, then plug back in you should be fine. way too much ice has built up behind hte inner panel ,cutting of all air flow to both compartments.you did no real harm( other then losing your food
Nov 28, 2008 | GE Refrigerators
WHITE STREAK (NO TONER APPLIED) ON LEFT SIDE OF INCOMING FAXES
You did not specify if sending or RX
open the part where you insert the papers to fax out (this is also in the troubleshooting of hte manual) look at the strip of glass is there anything on it?
Open the machine, remove toner and look at the strip on bottom of machine clean.
http://safemanuals.com/index_google.php?cx=partner-pub-1682016597802119%3Axo3rw7s1srj&cof=FORID%3A10&q=brother+2800+manual#0
Jul 16, 2008 | Brother IntelliFAX 2800 Laser Fax
Can I change the way the door opens?
no you are stuck with the fact how they were buld.unless you want to mover the doorlock and all wiring and the hinge.
also have to make a hole for the doorlock.
I would not advice this.
May 02, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 42822 Front Load Washer Logo
166 people viewed this question
Sal De
fordexpert
Robert Rankin
