Problem with Juki DNU-1541 Mechanical Sewing Machine
how to time juki dnu-1541
Posted by avatar on Apr 01, 2010
Solutions (1)
Best Solution
Go to http://www.dixiesewingmachine.tzo.com/SERVICE%20MANUAL.htm they have a copy of the engineer manual for this machine in a pdf file and all the info you want on timing is in it.
Suggested Solution (1)
Might I be so bold as to disagree with Allmakes.
Why would a manufacturer build different models of industrial. They are designed for differnt jobs. The 8300 is a high speed garment machine, the 1541 is a compund feed upholstery machine. The motor is the same HP and does not affect the ability to sew heavy. The garment machine will sew garment weight leather just fine but you will have problems getting the fabric to feed properly particularly over seams. The other issure you may find with a garment machine is it's ability to handle heavier threads. I suggest that the 1541 would be a better choice for making bags and purses.
  • by Author image Guest Over a year ago
Source: question==>JUKI dnu 1541 or ddl 8300n
Was this solution helpful?
No
Yes
Add Your Solution
See all Juki DNU-1541 Mechanical Sewing Machine Problems
