Question about Refrigerators
FRS6L7EES1 I have a side by side that when I go to fill water in the dispensor, it comes out slow and then the excess runs into the ice tray and comes out the Ice dispensor. I also get a lot of water running down the front of the fridge that comes from the underside of the tray area. My thoughts are that there might be a blockage of sorts in the door or in a line somewhere. I have replaced the water valve already so I know that is not the problem and I have plenty of pressure comming to the valve itself. HELP!!!
  • 93 Answers
I am service tech. Try and replace the diode in the water valve connection. Part number 5303918287. This is a diode kit for the Frigidaire ref., instructions are in the package. This part regulates the water valve to make sure that water comes out the specific port in the valve.
Posted on Jul 10, 2008
I have the gwl 207 flqk side by side, no water feeding ice machine but is feeding the water dispensor
there is a thin bar that has to be down in order for it to make ice, is it in the up position?
Nov 09, 2012 | Refrigerators
I PURCHASED A WHIRLPOOL GS5VHAXWY FRIDGE AND THE ICE IS NOT COMING OUT OF THE DISPENSOR WHAT IS WRONG WITH THE ITEM
first thing to check is that you have water going on the inside of the ice maker tray simply stick your finger inside and see if there is water if there is no water you would then look at the water valve or the line in the back of your fridge if there is water or rather there is ice inside the tray you would want to remove the ice maker and run the tray under hot water then reinstall to test if this does not work then replace the ice maker hope this helps
Jul 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice tray filler tube freezes up and clogs up so no water goes into tray
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
May 22, 2010 | Amana SXD524VW Side by Side Refrigerator
Not making ice
Sep 24, 2009 | GALAXY Microsystems 25.4 cu. ft....
Ice maker works, fills door but doesn't come out
You have a bad dispensor flap solenoid . Frost due to flap not closing completely and ice will catch in the shoot .
Jul 25, 2009 | Whirlpool GS6SHAXLS Side by Side...
Ice tray will not fill with water
you have a bad mixing valve on the back of frig your model should have a duel valve one side for ice maker one side for water replace this valve you will be good to go
Jan 28, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
The tube freezes over where water comes in to fill the ice tray
You may have a related problem. If the freezer compartment isn't sealing off it will have excess moisture inside eventually making excess ice build up on the water inlet tube on the ice maker. Otherwise the water inlet valve is not closing completely and a little bit of water is building up and freezing.
Dec 26, 2007 | GE GSS20IEP Side by Side Refrigerator
The water continues to drip after the ice cube maker is full.
Sounds like the water fill solenoid valve is leaking by. You will have to change that solenoid valve if the water continues to drip into the ice maker tray after a normal fill cycle. http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=JCD2295HES&mfgModelNum=JCD2295HES&fkMfgID=1
Dec 05, 2006 | Jenn-Air JCD2295HES Side by Side...
No ice or water from dispensers
Womers, make sure there is not a lock-out on the dispensor panel. If there is, hold it in for 5 seconds and see if the dispensors come alive. Because both water and ice are not working, I would think you have a dispenser board issue. Catriver..post back.
Sep 26, 2006 | Whirlpool GS5SHAXN Side by Side...
Refrigerators Logo
176 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
