Question about Medion MD-1704 PC Desktop
Medion pc keeps rebooting just as starting to load win xp home
Hi added some new Ram to my pc was 256mb x 2 & added 2x1gb 184 pin 3200 ddr double sided. Tried various combinations & pc wouldn't boot, so put original back in only & booted ok. Stubborn me tried again & also removed bios battery to reset (per website) then it lost the hdd, got it back by checking cables & removing 2 new rams & fiddling with bios but at windows xp screen it turns off & reboots every time. Even did xp repair, at 2nd chance screen not 1st,I don't have disc backups of my stuff & no floppy drive. going mental.
Medion MD 8383xl about 3-4 yrs old. Help Please !!!!!!!
  • 91 Answers
Sorry, my computer just hanged, we can continue the chat in skype, my username is : ronenfe.
or in messenger : [email protected] (this is also my email)
or in icq: 18300905.
Posted on Mar 15, 2008
    Sergeant:
    Champion:
  • 256 Answers
Hi
before it was fine with your old 256mb ram right...
i need to know which is your Processer, speed and mother (845,865 or 915….)
e-mail - [email protected]
  • 76 Answers
Sir your useing windows xp os ok your Probalm finaly turns off & reboot some .dll fils are missing so your install new software for your pc ok by .
SOURCE:
Tried to upgrade my ram modules from 512 to 2gb. also installed a new video card (for a moment... but then removed it when the problem occured). now when i power up, i get a steady...
what type of ram did you upgrade with it should have been DDR and keep the same brand/type of ram modules the same check the ram sockets make sure they are clean and the ram is securely seated The ram modules should have either of these 2 the same 1 GB 184-pin DIMM DDR PC 2700 memory module 1 GB 184-pin DIMM DDR PC 3200 memory module
Jul 01, 2011 | EliteGroup 661FX-M7 (661FXM7V11)...
Can i upgrade my packard bell 4340 imedia pc,it has an athlon xp 3000+ barton cpu,768mb ram in 2 slots,graphics-radeon 9200 series
You can upgrade the memory to maximium of 2gb of ram 1gb stick of ram in each slot. The memory you will need DDR PC 3200 184 pin.
You can also upgrade the hard drive for more space or buy an external drive to store files.
Jul 20, 2010 | Acer Computers & Internet
Do this model supporsts win xp service pack 2
Hi.
This unit has a Pentium 4 2GHz single core processor, and does support Windows XP SP2.
The standard memory installed on this unit was 256KB RAM, in order to run XP efficently you will need to upgrade the RAM. I suggest upgrading RAM to the maximum amount allowed of 2 GB RAM.
To upgrade the RAM to 2 GB you will need 2 modules of 1GB PC2100 184 pin DIMM ECC each.
Micron 1GB DDR RAM PC-2100 ECC
May 25, 2010 | IBM eserver xSeries 205 8480
Pc5300 on pc3200 slot to upgrade msi 845gvm-v
PC5300 or more correctly "PC2-5300" and can work in a system that has "PC2-3200" RAM, and if mixed, they will operate at the speed of the slowest module. "PC-3200" RAM, however, is not compatible. PC-3200 is DDR SDRAM, having 184 pins. PC2-3200, and PC2-5300 are DDR2 SDRAM, having 240 pins. DDR and DDR2 modules are the same length,
but the pins on DDR2 are smaller and the keying notch is in a slightly different position.
You need to get the replacement ram all the same type ie - DDR or DDR2
And yes your motherboard should accept 2GB max
Jun 15, 2009 | MSI 845GVM-V (MS-7057-010) Motherboard
Upgrade of RAM
184 pin DDR DIMM is the correct information :) The bus speed of the ram would range from PC 2100 - PC 3200. I assume the Max amount of ram will probably be 2gb though unless your motherboard specifies a higher amount.
Mar 22, 2009 | Computers & Internet
Ram upgrade problem
Are ou adding them along with the 256MB memory? That could be the problem
Mar 09, 2009 | Dell Dimension 2400 PC Desktop
PC Motherboard Memory upgrade
From Asus tech: Memory 3 184-pin DIMM slots for PC1600/PC2100 DDR SDRAM
Supports up to 2GB memory
No ECC supportThis is only compatible RAM so make sure your new chip is PC1600 or PC2100. If you mis the 2 it the faster RAM will run at the slower chip speed. Hope this helps.
Feb 20, 2009 | ASUS P4B266 Motherboard
RAM compatibility with MK79G motherboard
Hi, I am assuming that the original piece of memory was a 256mb ddr pc2700/333mhz ?
i have looked at your board on the product maker website and it supports memory to 2gb of pc2100,pc2700/pc3200 type memory. Be certain however that the new piece added is the same clock speed as the original that you are trying to use with it. You cannot mix clock speeds, either pc will not boot or it will only recognise the compatible piece. Have you tried booting with just the new piece 9 leaving out the older piece)if yes what was the result. Need more help ?? [email protected]
Jan 03, 2009 | AOpen MK79G-N (91.8B110.101) Motherboard
Want to buy more RAM..
Your dell dimension takes DDR ram. These are the specs:
Supported pin types: 184 pin DIMM (regular desktop DDR ram)
Supported memory types: DDR PC2700 or DDR PC3200
Supported speeds: 333mhz or 400mhz
Supported stick sizes: 128mb, 256mb, 512mb or 1gb.
MAXIMUM MEMORY ALLOWED: 2gb (2 x 1gb sticks)
If you buy two of these you will max out for ram and give you the best performance::
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1558844&CatId=1600
Dec 24, 2008 | Dell Dimension 3000 PC Desktop
SAMSUNG 1GB RAM 400MHZ PC3200
RAM has to be
Four 184-pin DDR DIMM sockets
Supports PC3200 (400 MHz) /PC2700 (333 MHz) / PC2100 (266 MHz) DDR DIMM type
Maximum HP/Compaq approved memory module is 1 GB
Maximum HP/Compaq approved memory is 4 GB
It has to be the same.
• If you are replacing a memory module, put the
new memory module in the same memory slot
from which the old memory was removed.
Or
• If you are adding a memory module, install the
new module into the socket nearest the
preinstalled module, and install additional
modules in the next available sockets
Jan 14, 2008 | Computers & Internet
Medion MD-1704 PC Desktop Logo
476 people viewed this question
Top Medion Computers & Internet Experts
Ekse
Robert Karst
Robert Karst
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
