Question about Sony Ericsson W200i Cellular Phone
How to remove the sim card from w200i?
It's hard to remove the sim card from its slot... the design of the slot is not user friendly i'm afraid that it will damaged my sim card..
    Problem Solver:
  • 6 Answers
Hi There,
As suggested the sims are pretty robust so should easily withstand you taking them in and out but try not to go all guns blazin just in case.
On the w200i you should find the the bottom (the end without the bezel edge) of the sim is held in place by two small metal slides.
To remove the sim, place fingernail under the top most edge (the end with the bezel edge) and pull it gently away from the phone - this will cause the sim to bend but if you only do it a small amount no damage will be caused. It only need be enough to clear the recess that the sim is sat in. Once pulled back use another finger placed on the back on the sim to push the card up towards the top of the phone. This should then let the sim slide freely out.
Hope this helps.
Posted on Mar 15, 2008
  • 88 Answers
Sim cards are pretty hardy and it's unlikely you will damage it. Most sims now fit into a slide slot which means you need to bend the card slightly by lifting up the edge to slide it out.
Hope this helps,
erch.
Where is sim card on a utstarcom mobile phone
Depends on the phone but most likely it's under the battery. If not there, then look for a slot on the side of the phone, covered with either a small rectangular piece of rubber or an easily removed piece of hard plastic.
That being said, some models won't have a sim card. It depends on the carrier and the phone. Sprint, Verizon, & others that use their networks (such as Virgin) only started using sim cards when 4G LTE was launched. If the phone isnt designed for LTE and the phone is a CDMA phone (the technology that Sprint & Verizon use) then it wont have a sim card unless it the phone was also designed for use abroad (E.g. Europe).
Oct 17, 2017 | UTStarcom Cell Phones
How do you know what slot to put sim card in slot 1 or slot 2
You either have a dual SIM card phone (it can use two SIMs with two different phone numbers) or you're confusing the MicroSD memory card slot with the SIM card slot.
If you truly have a dual SIM card phone, just put the SIM card in slot 1. Your phone's user manual should be able to offer further info.
May 19, 2017 | Cell Phones
Were do u insert a sim card in a sprint palm pixi
Remove the pixi's battery and youll see the Simcard designated slot.Here's a free User Guide for your Palm Pixi for more.
Check out these videos on your Palm Pixi too.
Hope this helps.Thanks!
Dec 18, 2011 | Cell Phones
How to insert an SD card in a HTC wildfire
I'm afraid your phone operates in the CDMA technology, instead of GSM, and, as such, it lacks a SIM card slot. Please, refer to its user guide, which you can download from this location, for further details.
Regards, Carlos
May 26, 2011 | HTC Wildfire Cell Phone
W200i insert sim
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Sep 19, 2010 | Sony Ericsson W200i Cellular Phone
Where to put the sim card
Open the back cover of the phone, remove the battery,slip the sim card into the slot designed for the sim card. Later, install the battery,put back cover. Turn power on. That's it.
Dec 31, 2009 | LG HD4000
How to insert a sim card in nokia7100 .tere is no slot .what can i do? I pushed the sim in, but it was really hard. the cut off corner was in the right place. Still does not say that there is a sim there...
Extract from nokia 7100 user guide:
Always switch the device off and disconnect the charger
before removing the battery.
The SIM card and its contacts can be easily damaged by
scratches or bending, so be careful when handling,
inserting, or removing the card.
1. Slide the release button (1), and remove the back cover
(2).
2. Remove the battery (3), and insert the SIM card (4).
3. Insert the battery (5), and replace the back cover (6).
May 29, 2009 | Nokia 7100 Cellular Phone
How to remove the sim card from my w200i?
You need to tunr your phone off. Take off the battery cover and take the battery out and you will see the sim card slot.
Mar 13, 2008 | Sony Ericsson W200i Cellular Phone
Sony Ericsson W200i Cellular Phone Logo
241 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
