Question about Hayden Industries SuperVac 6000 Central System Vacuum
Spare part - filter
A need a bottom plate. The one that hold the filter in place. Where can ifind it?
  • Swede100 Mar 15, 2008
    Well, thanks Guru, I already though of that possibility. BUT, the agent (& store) in Stockholm, Sweden is 'not on the track' anymore... So I had an idea of buy it direct from abroad...
    Kindly
    gunnaR
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Please feel free to call the customer service @ Hayden Manufacturer @ the phone number listed below:
http://www.haydenvac.com/company/contact.html
1-800-461-5300 Hayden Factory Manufacturer
and also check the owners manuel for troubleshooting and if you don't have the owners' manuel -- call the factory
Posted on Apr 10, 2008
    President:
  • 1,673 Answers
You will have to find a Hayden store that sells and installs Hayden systems.
Posted on Mar 15, 2008
  • Lauren Junge
    Lauren Junge Mar 15, 2008
    I don't have their email addy, but search the web and see if you can buy it direct.
SOURCE:
How to remove the belt
Most vaccumeing have 4 to 5 screws holding the bottom plate remove plate pull out roller . Slide it off the roller and motor replace with new belt by first slide belt around motor arm then roller pull roller into place then roll the roller 3-4 times to insure it's in the right spot. Replace bottom plate
Apr 11, 2015 | Vacuums
Replace brush head cover
Three slotted plastic fasteners hold the bottom plate in place. Turn. Them all to remove the bottom plate to gain access to the brush roll.
Aug 01, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do I change the belt on my bissell 6594c vacuum?
If yours looks like this one: http://www.bissell.com/ProductDetail.aspx?id=9778
lay the vacuum upside down, remove the screws that hold the plate over the brush roll, or some models just have tabs. Remove the plate and then take the brush roll out of the body. Place the new belt on the metal motor shaft and loop the brush roll pulley thru. Pull forward and place the roller into the housing, turn by hand a few rotations to make sure the belt is tracking straight. Replace the bottom plate and secure with either screws or click tabs in place. Flip vacuum over and it's ready for use. Make sure to keep your filters as clean as possible otherwise you will lose suction. You can wash any foam filters in the sink, but let them completely dry before re installing them; do not wash pleated heap filters, see owners manual for care and replacement.
Nov 03, 2013 | Vacuums
Bottom plate screws
they don't unscrew they only turn 1/4 of a turn then pull open watch this video
Mar 22, 2013 | Dyson DC26 Bagless Canister Cyclonic...
How do you change the belt
on the bottom of the vacume you should see about 4 screws ( philips ) that hold the plate in place, remove the screws and plate and this will expose the motor shaft,belt and roller ( you should also see the broken belt there two ) -- pop out the roller ( pull straight up ). put new belt onto the motorspindle and then onto the roller, snap roller back into place ( note: on the edges of the roller it is somewhat keyed to only fit into the vacume a certain way ), replace the the plate and screws and you are good to go. also while you are getting dirty -- clean the air filter and examine the hose between the floor roller and the suction hose for dirt build up and debris.
c...
Jan 01, 2011 | Dirt Devil M086700 Vision Bagless Upright...
Dyson animal is giving me fits
Try this quick repair and see if this fixes your Dyson in terms of not going in the upright position: This is a frequent problem that we see come in on Dysons. If this doesn't fix it, please feel free to just use the clarification request and let me know this didn't fix it. The suction problem is happening because when the machine is put in the upright position it diverts the suction from the floor to the hose automatically, and it's probably stuck in between the lower part and the hose part.
Step 1.
Turn power off and unplug the machine.
Tilt the machine backward to a 45° angle.
Step 2.
  • Hold the section under the airway inspection pipe.
  • The black forward lock button must be held down simultaneously, otherwise the valve carriage will not move.
  • Pivot this section upwards until it clicks into place.
  • Release the black button once the valve pipe carriage is moved up into place.
    Step 3.
    • Tilt the machine forward.
    • The cleaner head should now slide underneath the part you have just clicked into place.
    • The machine should now stand upright.
    In terms of the machine not picking up, this could be caused by a few things.
    The first thing you should check is the filter. The DC14 has a motor filter that is recommended to be washed every 90 days. Here's how to access this filter:
    • To remove the washable filter: Remove the clear bin; and cyclone top from your machine by pressing the cyclone release button.
    • Lift clip to remove the filter from the machine.*
    *The post-motor filter located under the clear bin should last the lifetime of the machine and does not need to be washed.
    There are two different types of filters that were used on the Dyson DC14, and One part filter, and a two part filter. Here's instructions on how to clean both of them:
    ONE PART FILTER:
    • Wash the filter in cold water only. (Please do not use detergent, do not wash in a dishwasher or washing machine).
    • Repeat the steps shown below until the water runs clear.
    • Leave to dry in a warm place for 24 hours. DO NOT dry the filter inside a clothing dryer, hair dryer, microwave the filter, place the filter in an oven, or near a naked flame.
    • Please ensure the filter and filter case are completely dry before refitting into the machine.
    1_part_filter_drying.jpg TWO PART FILTER:
    • Wash the filter in cold water only. Please DO NOT use detergent on the filter, or wash the filter in a dishwasher or in a washing machine.
    • Leave the filter to dry in a warm place for 12 hours, until completely dry.
    • DO NOT dry the filter inside a clothing dryer, hair dryer, microwave the filter, place the filter in an oven, or near a naked flame.
    The filter should be washed at least once every 6 months.
    Also, since you have removed the bottom plate, a common problem on the Dyson's is when this plate is reinstalled. It is very easy to put the plate on incorrectly, which prevents the brushes from hitting the carpeting. This can seriously decrease the pick up on carpets. Check the bottom plate to make sure that it was put back on properly. Here's pictures of both the correct, and incorrect way to reinstall the bottom plate:
    Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
    Here's another picture, that is the RIGHT way to install the soleplate:
    I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
    I hope that this was helpful to you. Please feel free to use the Clarification Request form here on Fixya if you have any questions.
    Thank you,
    Chris J.
    GoVacuum.com
    May 01, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
    Water flowing out bottom of steamcleaner
    It sounds like one of the internal tubes is loose or has a leak. You'll need to open up the black plate (the plate where you place the water tank on top of). Inside there, you'll be able to see all the tubes and hopefully track down which one is leaking or loose. Some of the tubes have clips to hold them in place. Perhaps one of those came loose.
    Jan 26, 2010 | Bissell 9200 Upright Vacuum
    How do I repalce the belt on Dirt Devil Swivel Glide upright vac?
    Four screws hold the bottom plate in place. Turn the vac upside down and remove the screws that hold the cover(bottom plate) over the brush roll in place. Remove the plate and you are there.
    Oct 22, 2009 | Dirt Devil M088910 Swivel Glide Vision...
    Need to replace red clips that hold rolling brush on 7901 Proheat
    On the bottom of the machine, near the belt access area,
    is a red retainer plate that holds the black brush arm and
    brush in place. Using a Phillips head screwdriver remove the
    screw that holds the red retainer plate in place. p/n 5559113
    Jul 12, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
    I have a Hoover TurboPOWER 7300 Windtunnel V2-belt change
    1. Remove the 4 screws holding the bottom plate.
    2. remove roller and old belt
    3. install new belt on motor spindle first and then on roller.
    4. pull roller, stretching belt, set into roller cavity.
    5. turn roller by hand to center belt.
    6. reinstall bottom plate.& screws
    I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
    Feb 26, 2009 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
    Hayden Industries SuperVac 6000 Central System Vacuum Logo
    218 people viewed this question
    Top Hayden Industries Vacuums Experts
    Marvin
    Marvin
    JoeVacs
    Are you a Hayden Industries Vacuum Expert? Answer questions, earn points and help others
