I had what you described as a "blow out". Water line dangling from the back, causing flooding and frozen fill tube. I hooked up the water line and unfroze the water fill tube (with a hair dryer). The ice maker worked fine, but the fill tube froze again immediately (before the Ice maker could dump a load of ice into the bin).
I'm still getting water through the door, just fine.
I have a Kitchen-Aid, side by side, Superba series
Model # KSCS25FJSS01. Manf. date 11-00.
Please help appliance GURU....
(BTW, this occurred overnight, so my hardwood floors may be ruined)
Mark, your water valve has screwed the pooch. Replace it. The part number is 2199838.
What's happening is this... the valve that fills your ice maker is by-passing a small amount of water. This water has to flow through that tube, right? When very small amounts (drop by drop) go through the IM fill tube, they flash freeze. Eventually they (the frozen drops of water) form a big block of ice inside the fill tube. This ice creates a blockage which creates back-pressure whenever the IM "calls" for water. The back pressure eventually blows the tube off of the connection behind the fridge.
You say that this happened over night... no way. If you look closely at the ice cubes that you IM has been making, you'll see that they are hollow. Hollow cubes means that your IM isn't getting enough water... (because the fill tube is blocked).
Tracy
Andyack,
Yep, bad valve.
The only other time I've seen this (and the cause was NOT the valve) was when a customer had the fridge hooked up to a reverse osmosis water filtration system. RO systems will drop the water pressure below that necessary to keep the valve shut completely, thereby allowing water to "seep" through the valve.
So, if you are hooked up to an RO system, look there first. If not and your fridges water line connects straight up to the household water supply, it's a bad valve.
My Kitchen Aid freezer is doing the same thing....water freezes in the fill tube leading to the icemaker then subsequently leads to an overflow with water all over the place.
My model is KSRS25FGSS13...am I correct in assuming my water valve is defective also?
The solution worked great. I replaced the valve, installed it in about 20 mins, due to the tight spaces. Once I thawed the water-in line and tube going into the ice tray it all worked again.
Thanks for the solution and parts recommendation.
I have the same problem with the ice maker not working, the tube that fills the ice tray was frozen, but the line was not leaking (no water on the floor or anywhere). There is also a knocking sound coming from the ice maker. My refridgerator is a kitchen aid model kscs25fkss01.
Thanks in advance for any advice you have.
