Question about Logitech R-20 Computer Speakers
My computer no device audio for this speaker
The speakers are installed perfectly, but my computer audio device is not and can not hear anything I need to have my computer audio
  • 1 more comment
  • Anonymous May 11, 2008
    The speakers are installed but the is no sound. All the programs say tat it is working properly.
  • KRISJAS May 31, 2008
    I have accidentally cancelled the audio device program in my computer and now I have no sound in my computer, and the speakers are installed perfectly.
  • desiderio Oct 11, 2008
    i have the speakers pluged in perfectly, but i cant hear anything. i went to my Audio devices and it says that i dont have a Audio deice. what do i do to install a audio device. i have a hp
I cannot hear sound from my system speakers
Posted on Nov 26, 2008
When i plug in the speakers no sound is coming out it doesn't work correctly i cant hear anything i'm playing.
Hi taceeg06,
Have you check all the Volume setting on you computer?
On the lower right side look for the computer Icon check if there is a red X on the speaker Icon, if there is then it can be that here is something wrong with the speaker driver or it does not detect the speakers.
If you do not see the speaker Icon then the Driver for the Audio card is not installed on the computer and you may need to re install that Audio Card Driver to be able to regain the audio from your Speakers.
Also the speakers should connect to the Green Audio Jack behind the computer, if it is then still no Audio you can try the Audio Jack in front of the computer as well to check the Audio Card in the Machine, if the front and back audio jacks do not detect nor produce sound when the speakers are connected then re installing the driver for the Audio card may work, unless during the installation an error shows that the there is no audio device detected then it means the Audio Card is busted.
Let us hope not since it is very seldom an Audio Card could go busted.
I hope this helps.
Have nice day,
mvincentc
Jun 12, 2011 | Insignia 2.0 Speaker System (2-Piece)
I cannot hear ANYTHING. The speakers are plugged in and properly inserted into the computer but i still cannot hear anything
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 11, 2011 | Kinyo PS-107 Computer Speakers
I cant hear anything out of my speakers how do i fix this problem?
the drivers might have been corrupted by something or you might have got a virus run your antivrus program and test for a virus then
you might have to uninstall then reinstall either the sound drivers or the sound card make sure you have both of these devices baked up to a disc before uninstalling
a yellow? question mark means you need to install/update driver right click to install driver
as for the sound
control panel sounds and audio,volume you can adjust the volume or
advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 14, 2010 | Logitech Z313
My computer keeps saying there is something wrong with my sound card or audio device does that mean that it is something internal. I've tried the troubleshooting and even tried the control pannel settings.
if you cant hear anything coming out of your computer speakers there is something wrong here what to do
if your computer came with a disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control
panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 01, 2010 | HP (400745-001) Sound Card
I have a hp2010i monitor but can not get any sound. The system shows that is running properly but I can not hear anything. Please help
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 05, 2010 | Audio Players & Recorders
My speakers used to work and suddenlly stop then beganto where somtimes when i longed on they worked and other they would all i hear when i turn them up is static and now my compouter is saying the are no...
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Oct 13, 2010 | Altec Lansing 2100 Computer Speakers
I can not hear sounds on laptop sometimes i hear it at the starting
hope this helps
Oct 03, 2010 | Dell 5650 Computer Speakers
I have a dell computer and the speakers are attacked to it but i cant hear anything. i checked if the cables were in the right place but they are and i still cant hear anything. i went to control panel and...
If everything is grayed out in the audio devices property in the control panel, that means there's a problem with your audio driver, first step I would take is to reboot your machine, hopefully it will come back.
If that fails, most Dell computers come with a Application CD, put the CD in the CD rom drive and have it reload the audio drivers back in.
Also make sure your speakers are plugged into the green port on back of your computer
Feb 17, 2010 | Dell Audio Players & Recorders
Sound
did u install sound card drivers
if u install correctly go to control panel and sound
check there whether audio device is showing or not. if not u didnt install ur audio otherwise u installed correctly but the problem is in ur speaker.
Feb 23, 2008 | Logitech Z-3e Computer Speakers
Can't hear anything
go to start ->control panel->sound and audio devices. and click on the audio tab. under sund play back is c if your sound card is displayed in default devices if this area is grayed out, it means there is a problem with your audio device drivers. if this is the case, let me know and I'll tel you how to install the drivers.
Jun 18, 2007 | Labtec LCS 2412 Computer Speakers
Logitech R-20 Computer Speakers Logo
112 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
