Question about Refrigerators
My westinghouse freestyle freezer model number FJ3830-L*13 stops working now and then. On the back down the bottom left corner is a box. On this box is a small dial I turned this 1 click and the freezer started again. Now have I turned something I shouldn,t have. Could you please explain what the dial is for and why my freezer stops working. thank you Trevor
  • jetmason Mar 16, 2008
    thank you for your prompt reply.
    I have noticed that sometimes some of the frozen veg eg. peas corn feel like they are thawing. Maybe It might have something to do with 16 days of 35c and above, Adelaide weather really sucks lol. Anyway that info has helped me a lot. So I do not need to turn the dial as the freezer will turn back on by itself, is this correct. Have I changed the cut off time now that I have turned the dial and if yes how do I correct this.
    Again thank you very much, looking forward to hearing from you again.
    Trevor.
    PS: I did not know that people like yourself existed, free help is hard to get with these sorts of problems. Experts always want money just for verbal help.
Hi i have a fj383, red light comes on and the fan doesnt circulate the cold air, only the bottom half stays cold, have tested the fan and does work, have put a new defrost timer in but no different, what activates the fan ? is it the timer or the t/stat or the element, hope you can help, thanks wayne.
Posted on Apr 11, 2011
    President:
  • 1,314 Answers
That's the defrost timer it should cut off for thirty minutes for every eight hours of compressor time for self defrost now compressor time is not regular time as the thermostat shuts the compressor off every now and the when the freezer reaches proper temputure it works off accumulated run time and no you didn't turn anything that will hurt are you having problems with it cooling or you just noticed it was off
Posted on Mar 15, 2008
Hi I have Westinghouse freestyle 450 my problem is that no matter how low I have temp the begs freeze in crisper other wise been very happy I have had this fridge for 20years
fridge settings work in reverse to freezer settings
1 for a fridge is almost freezing where it should be around 4
cold air sits at the bottom of the fridge so the setting will be colder in the crisper draw that at the top shelf
May 26, 2017 | Westinghouse Refrigerators
Westinghouse fridge freezer fridge not working
What is the model number?
Do you see any ice buildup on the back wall of the freezer or behind it?
Oct 20, 2012 | Westinghouse Refrigerators
Have replaced broken hinge but am stuck getting both fridge and freezer door back on. can do one or the other but not both. westinghouse freestyle fridge/freezer
srack from bottom up- bottom hinge - bottom door- tape door with duck tape- middle hinge- top door- tape top door- top hinge- remove tape- done
May 25, 2011 | Refrigerators
Freezer icing up on roof and door corner.
yes, sealing problem. take a hair dryer and see if can smooth out corners. do not hold stationary on gasket. move slowly back and forth. make sure not gaps around gasket. warm air is the problem
Mar 04, 2010 | Refrigerators
My westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Nov 08, 2009 | Westinghouse Refrigerators
Freezer not working
Your refrigerator has a Control-defrost,adaptive timer ,PC board part number 241508001
This is providing your model is the one listed above your post WRS3R3EW. The model you listed in post does not come up. Until we can determine that the freezer is not defrosting you need to unplug and remove the back panel of freezer compartment to see if the evaporator coils are frozen or clear. If frozen this alone will cause a chain reaction that keeps vents to fresh food compartment open and cause freezing in that area. Go to link below and enter model number WRS3R3EW0 Then you will see a list of diagrams on left side, chose #11 this will show the control parts. Click link below Thanks, Sea Breeze
We offer free help and assistance also.
http://servicepartstec.blogspot.com/
Apr 27, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Westinghouse Freestyle 668 oven not doing anything , just blinkin
Yes I can help.Hold down the buttoms on the far left at the same and then set the time using the + and - buttons.Cheers
Apr 20, 2009 | Ovens
Fridge freezer not cooling
(bad news) Repair man came today and said the compressor has died ;- (
(good news) Westinghouse will replace compressors less than 5 years old with a new one, just ring them with your serial number (inside front door) or supply a receipt and you only have to pay for the labour ;-)
Apr 12, 2009 | Westinghouse Refrigerators
Top half fridge not cold freezer department fine
I had the same problem; the top fridge compartment was warming up to 14C while the freezer compartment was starting to defrost (frozen stuff was starting to become soft. I took the rear wall off the freezer compartment and found it all iced up. I defrosted it with a blower heater then powered it back up. It all worked fine for a month when the same thing happened. I figured that the defrost cycle wasn't working. I located the defrost timer on the rear right-side of the fridge. I rotated it several times and found that the fridge was turning on and off. I rotated it until the fridge turned off. I waited 5 minutes then stuck my head into the freezer compartment and felt the rear wall at the bottom where he drain is; it felt warm so I guessed the defrost heater element was ok. I ordered a defrost timer and installed it. I haven't had a problem since.
Nov 09, 2008 | Westinghouse Refrigerators
Refrigerators Logo
996 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
