Question about Whirlpool 24 in. DU920PW Built-In Dishwasher
Low or no spray pressure
Intermittent water pressure during wash cycle. Motor is running but water is not being pumped up thru lower spray arm or has very low pressure. Plenty of water in the unit. Filters are clean. Does it need a new impeller kit? Can I change this myself?
Thanks for the help...
    Sergeant:
  • 288 Answers
You sound like you diagnosed it pretty good, so I think you can change the impeller. The biggest problem is making sure everything is lined up so it wont leak after its re-installed. I've never had much luck removing the old impeller without breaking it into pieces. just be careful not to mess up the shaft. If its an older machine, some Whirlpool/Kenmore can have the whole thing changed in one part. Its a little more $$ but it has the motor and all. And its easier and faster!! Also, your pressure problem may be related to the motor.
Posted on Mar 15, 2008
SOURCE:
Defy dishwasher does not wash or spray the water but is filled with water and goes through it cycles, what can be wrong?
The motor that pumps the water out of the machine is the same motor that pumps thru the spray arms. The motor runs in one direction to pump the spray bar and in the opposite direction to drain the water out. look at the cycle timer. It switches the direction. If it proves good then the motor is bad.
Aug 18, 2014 | Dishwashers
Dirty dishes
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher.
The motor (and pump) located beneath the dishwasher.
Check if motor spins. In case it spins, the problem is with the pump ,in case it doesn't spin it could be a motor problem or a motor and pump problem.
First of all: filter plate clean? Clean any locked hole.
1) Can you remove the upper spray-arm and verify if holes inside are locked by any residus. Clean the holes , and check if pure water come out when you fill the center hole with some water.
2) Switch on the dishwasher , coldest wash cycle dish-washer empty and without the upper spraying arm. Once you hear water streaming in, open the door and look if a little water fountain comes out from the center hole where the upper spraying arm was fixed. If not, this canalisation is blocked and should be cleaned. Try to continue the wash cycle, often the water pressure will clean itself this canal. Check also lower spray arm: it should be rotating a while and ejecting water thru its holes. If not, verify this canalisation as well.
3) Put the spraying arm again on its place, verify also the sealing else water pressure is going down and spraying will not turn and spray water.
4) Again, continu a wash cycle, open the door and look; upper arm should be rotating and some rays trown out.
Hopefully, this helps .
If not, pump pressure may be low; have a repair verify, can be that only brushes in the motor must be replaced, can be the pump worn out and to be replaced at all.
Aug 12, 2008 | Asko D1776 Built-in Dishwasher
My mother-in-law called and her dishwasher is making a loud noise when the motor runs. sounds like a bad bearing somewhere? the noise stops when it drains (motor not running?). does that sound like the...
There is only one motor -- it runs a water pump for recirculating the water when it's washing and runs a water pump when it's draining.
It sounds like the spray arm is making the noise -- this is the part thru which the motor / pump forces the water during the wash cycle -- the pumped water causes the arm to rotate -- a warn or loose spray arm or mount is likely the problem.
Or, it could be just some utensil stuck in the bottom of the dishwasher which the spray arm is rubbing.
More info, let me know.
Charlie
Jul 16, 2011 | Kenmore Dishwashers
I have a GSD2800P35, about 1992 vintage. It keeps stopping on washer arm blockage fault every 2 or 3 minutes during the wash cycle but they are clear and clean inside. what else may be wrong and how can it...
The sensor responds to the lower ( main ) wash arm. If the spray holes in it are clear, and there are no objects sticking down through the rack which might block it, check to see how much water is in the tub. Low water level would cause the spray arm to become stationary or move too slowly. Some models have a small rubber flap which covers a drainage hole near the base of the main spray arm also, which closes with pressure of the water. Check if it is missing. Check the inlet screen to the pump motor to see if it is blocked with anything (seeds, plastic wrappers, etc.) which would starve the pump of water.
Mar 18, 2011 | GE Dishwashers
Both spray arms of my DU943PWKQ0 do not turn or spray. The motor is moving and the it drains without problem. During the wash and rinse cycle I can hear the sound of water, however it doesn't clean at...
Try rotating the spray arms by hand. It should rotate freely. If possible clean the arm rotating place by removing them.
Arms rotate by by pump pressure only. finally check the water pump also.
May 18, 2010 | Whirlpool DU943PWK - Multiple Color...
If the lower and upper spray arms do not turn what could be the problem? I have a MDB4100AWB and I of course have hard water in our area and wondering what is causing the spray arms to turn.
could be the plastic shaft extension that screws onto the motor shaft to drive the pump. The threads on the plastic extension would sometimes get stripped out so that even though the motor is running, it isn't driving the pump mechanism. Assuming the dishwasher is filling with water and motor is running during the wash cycle. also check spray arm openings to make sure they aren't plugged up.
Jan 24, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
Motor making loud noise. checked filter and rotating arm - no problems. seems to wash dishes or at least have water in during cycle . . .
Hi
Seems the noise is from foriegn debris( ie.chicken bone of pistachio shell, toothpicks) getting into macerator/chopper assembly, wouldnt panic just yet, give it a fewloads to try to clear itself, a few screws leading down through the top of motor assembly (under lower spray arm should give you access to assembly if needed.
OR
there is a filter in the pump area that is probably plugged which is affecting your pressure during wash and rinse. It needs to be cleaned. It is located below the lower spray arm ,you need a torx screw driver to get at it.
Thanks for contacting fixya.com
Oct 22, 2009 | Fisher and Paykel Dishwashers
LG LDS5811WW Low pressure out of spray arms
On the LG LDF xxxx dishwasher family, the Vario feature uses a motor/check valve to switch between "full power" cleaning from _either_ the lower or the upper spray arms, never at the same time. So, not seeing the upper arm spin during the lower arm spinning is standard operating procedure.
But back to your problem. Step one would be to remove the filter assembly again and make certain that there is nothing (debris, broken glass) blocking the white areas where the check valve rotates to switch between upper/lower spray arms. A blockage there ~could~ cause impotent spraying/cleaning.
If there is no blockage and the impeller remains in good shape, suspect a failing wash pump motor. Try to isolate the noise to that motor.
Watch for error codes on the display and report back what you find, OK?
Good Luck!
May 14, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Machine runs through cycle but does not wash dishes
It sound like a pump issue. The pump is attached to the motor and forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. Look if the pump's impeller (a round plastic fan blade-type of device) spins around. In case it doesn't spin, look if it doesn't blocked or stuck from any other reason. Good luck
Aug 21, 2007 | GE 24 in. GSD3400G Built-in Dishwasher
No pressure to drive swing arm.
Check first that no debris is blocking the holes in the spray arm where the water comes out, and clean out the holes. In case it will not solve your problem, it's look like a pump problem (the pump has two functions : drive water to the spray arms and to drain water out the washer). Open the rear panel and listen if the pump works during the wash cycle. In case it doesn't work, it should be replaced. Good luck !
Jun 20, 2006 | Danby 22 in. DDW399 Free-standing...
Whirlpool 24 in. DU920PW Built-In Dishwasher Logo
103 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
