Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Mar 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool Duet Front end Washer
When we went to load the washer this morning, we found about an inch and a half at the bottom of the tub of the machine. This si the first time that we notice this. We have been using this machine for the past 4 years. I checked the taps on they are not leaking.
  • 2 more comments
  • Coldlake Mar 24, 2008
    Since the time I posted this problem, it did not happen. What the wife said is that she used the hand wash cycle with the low spin. If it would be the inlet valve, we would always have water trickling in.
  • Anonymous Apr 06, 2008
    went to do a wash in our whirlpool duet, and found 3 inches in the bottom of machine. what going on??
  • Duet1234 Apr 06, 2008
    I too have had standing water periodically in my washer. I am wondering if it is the result of too much detergent/suds being used. I have a water softener and I wonder if using the amount of detergent recommended is too much. Any ideas?
  • Anonymous May 11, 2010
    was the last load you did spun out properly i mean normal when you put it in the drier
Ron Coons
Level 3:
President:
  • Whirlpool Master 2,651 Answers
  • Posted on Mar 15, 2008
Ron Coons
Whirlpool Master
Level 3:
President:
Answers
2651
Questions
Helped
1547466
Points
7824
You have a bad water inlet valve. its not seating properly allowing water to trickle in when not in use. youll need to replae the water valve. in mean time turn water off between uses.
My whirlpool duet front load washer has loose fins in the tub. how do i tighten them??
You're not gonna like this:
Pull the washer tub (see elsewhere on FixYa for step-by-steps), split the tub by removing the screws holding the two halves together, and remove the inner tub. Bend any tabs tighter that hold the fins on, and tighten any screws. While you have it apart, check for grease stains or other leakage on either side of the outer tub, and ensure the inner tub bearing is tight so that the inner tub shaft rotates smoothly and without oscillation. If there are stains or if the bearing is showing wear, replace that (back) half of the outer tub to replace the bearing (unless this is one of the few machines that allow you to replace only the bearing). You don't want to put all this back together, only to have to take it all apart again when the inner tub starts hammering on the inner tub because the bearing went south.
tip
My washer threw the F H code, it ended up I had caused the problem earlier in...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “FH” error code.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Flowmeter and Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It’s a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
I hope this helpful. Please post back if you can't find the tech sheet and/or need further assistance.
1helpful
We have a Whirlpool Duet WFW9400SW02 that is making loud noise during the high speed spin cycles. It is only 13 mos old. Whirlpool will not even stand behind the parts. The repair person estimates over...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Whirlpool duet steam washer knocking noise when in spin cycle.
Washer Problems
heatman101
Front load duet whirlpool makes loud roar when it spins - no error code. Machine is only about 1 year old and just started making this noise recently
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Hard plastics pieces found on bottom of washer look like shell around tub is breaking
sounds as tho it is your tub.you should have a 10 yr warranty on that tub.you just pay the labor
3helpful
How do I get change out of the washer? It went
I think you are talking about the three tub baffles that are attached to the inner tub. You can remove the baffles, usually one or two screws hold these into the tub. If it only has one screw then the opposite end is clipped into the tub. Most coins however get flushed down into the drain pump filter. We call this a coin catcher as that is what it is designed to do. Remove the front bottom panel, 3 to 4 screws on the bottom. Put a towel down under the pump to catch about a half gallon of water. There is a large round plastic screw that you unscrew from the pump assembly. The screw is three to 4 inches in diameter and almost dead center on the bottom front of the washer. Once you have unscrewed the unit, pull it out and clean out everything you see. Look inside and make sure there is nothing in the hose or the pump inlet hole. Reinstall and test for leaks before you put the panel back on. I recommend you clean this out every 6 months. Good Luck,
Appliance Specialists
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
