Question about Pioneer AVIC-X1R CD Player
Avic X1r will not read navi disks
I've just had my flexi ribbon (free) and, laser replaced (£120) at Northolt Car Radio Repairs because of low output. I got this done as my head unit would not read my copy Sat Nav disks (which I bought off ebay) properly with the Sat Nav not giving me directions on time.
However despite this replacement laser, my unit still can't seem to read the 70vnm copy disks and I don't have any other disks . I find this really strange as my Dad also has an Avic X1R and the disks work fine on that unit !
All my copied audio CD's and MP3 CD's work/ed fine both before and after the laser replacement. Hope someone can help I really could do without spending £200 on original Pioneer disks!
  • Delinquent Mar 17, 2008
    Thanks for that, but I don't think that's the case as I am running the CDM-70 disks which are the latest, it's a puzzling problem !
    Champion:
  • 227 Answers
Your laser eye need to be re-align. Nothing wrong with the disc, but after you have someone who really know how to do it and if you keep using the copied discs(any format) your laser eye would be out of wack again. Because copied discs cause the laser eye to work harder specially the copied dvd and navi disc. I service countless number of unit just by re-align the laser not replace it. I do not think your lase ever get replace because Pioneer do not sell jut the laser eye but hte whole disc drive itself. The best solution is to buy a used original version and reset you flashdrive to the factory setting to reload it if you do not want to spend the money for the new original article. You can find the info on how to reset your flashdrive on avic411.com or get back with me if you can not find it. Goodluck.
Posted on Mar 18, 2008
  • hogan doan
    hogan doan Mar 22, 2008
    Have your laser eye re-align. I service countless unit like that.
  • 78 Answers
I have had quite a few problems with copied discs not reading and it is usually the disc's but however in your case if you know the discs work on another unit then perhaps a later version of the discs were tested when the unit was repaired and therefore your earlier discs would not be recognised by the unit, and therefore your unit needs to be reset and i'm afraid this is not something you can do yourself, speak to northolt and see if this is the case.
Posted on Mar 17, 2008
  • Anonymous Mar 18, 2008
    Pioneer will supply a laser, it's part number is CXX1915 also I would not recomment that you reset the unit yourself as you may cause more damage if you clear the wrong setting and to be honest I don't see what the problem is here as the unit has been repaired and should therefore be under warranty, northolt are a reputable authorised pioneer service centre
SOURCE:
My avic x1r will read dvd,s but not the
does your headunit have a usb if so try and put the cd on a flash drive and try it that way
Jan 09, 2010 | Pioneer AVIC-X1R CD Player
The screen on my pioneer AVIC-X1 doesn't work any more. I can remember where to touch to change radio channels so I can use that. How much would it cost to get it repaired and how much? Can anyone help?
Hi there mate i hade the same problem with mine its a common problem with these its normaly the flexy cable.
I got mine fixed by NORTHOLT CAR RADIO REPAIRS 02088451525 And if your unit is under 4 years old Poineer pay for it if not it will cost you £100.00
Feb 22, 2009 | Pioneer GPS AVIC-X1 car radio
Avic X1R Radio Only
ribbon gone, common problem cost £120 to fix (don't know why cos ribbon only cost £35), just got mine fixed
Aug 13, 2008 | Pioneer AVIC-X1R CD Player
Aidas
yra mazas mygtukas ant mazo snukelio, paspaudi ir palaikai, resetas padarytas
vat is kur lempa screenui gaut ???
Jul 28, 2008 | Pioneer GPS AVIC-X1 car radio
Avic-x1
hi sounds like the flexi, you can order a flexi kit from: http://carradiospares.co.uk/avicx1rn2-flexi-repair-gxx1257-p-172.html
mark
Mar 28, 2008 | Pioneer GPS AVIC-X1 car radio
Avic-n2 won't read the navigation disks...
If it play cd's but not not dvd's or navi disc then your laser is "tired" or out of alignment. If it does not play any type of disc then it needs a new laser pick unit. A capable tech should be able to re-align or replace the laser pick up unit for about $75 to $150. Contact me if you need it perfome. My number is 801-414-4566.
Jan 22, 2008 | Pioneer AVIC-N2 Car DVD Player
Pioneer avic-x1 r
OK on the nav side it's not the vss wire the is to just tell the avic you seep for off road use to nav track your rout. in the nav menu it should say gps ant or sum thing like that it will tell you how Meany sat it sees that should tell you if the ant is broke or not
Dec 29, 2007 | Pioneer AVIC-X1R CD Player
Avic x1r fault
It's the flexible PCB ribbon that goes to the screen. According to Pioneer, they no longer offer replacement pieces.
Dec 05, 2007 | Pioneer AVIC-N2 Car DVD Player
My AVIC-N2 will turn on but nothing will happen?
hi
sounds like the flexi cable is faulty
part you need is gxx1257
www.carradiospares.co.uk
its not to hard to change as long as you take your time .
Mark
www.blueice-electronics.co.uk
Aug 13, 2007 | Pioneer AVIC-N2 DVD Navi Rcvr with 6.5"...
Pioneer AVIC-X1R CD Player Logo
1,500 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
