Question about InFocus ScreenPlay 5700 Multimedia Projector
Fuzzy images I use my projector to reflect on the Smartboard in my classroom. It is now projecting some fuzzy colors in the bottom left corner. The colors seem to somewhat jump and move. Is the projector bulb going out or does something need cleaning? Thanks so much. Linda Ashley
  • ryan_lauer Jan 27, 2009
    I know that a layer of dust is coating the interior of the lens and perhaps the peice of galss inside the unit that reflects the image (the swivel part). i tried using canned air, and it got the dust off the parts it could reach, but i would like some help as to how to take apart the projector to reach those parts i cant get to. i know once this is done the picture quality will be much more clean and sharp.
  • Anonymous Jan 29, 2009
    having a light blue tripe on screen. tic-tic sound sometime and sometime have to unplug so it will stay on. have only 1145 hrs on it.
  • 22 Answers
Your projector is it in the UK if so ring me i can try to help you, i doubt it is a DLP projector (they where not very good and now largley dropped) so it may need a service or it may be an LCD fault with more info i can help you if in the UK, 0871 597 0097
Do not try to clean this yourself the high UV from these units can damage your eyesight
Marc Engineer
Posted on Jun 18, 2009
    Problem Solver:
  • 17 Answers
Could be a bit of dust or fuzz inside of the lens element or by the DLP chip. The first order of business is to remove the lamp and look at the condition inside the projector. If it is, as I suspect, very dusty as no doubt the classroom is a very common "dusty" environment, then you may have some cleaning to do. Be careful not to try and blow out the unit too forcefully as this can damage some of the internal components and could force the dust further into the unit. It is always better to gently swab out the interior or use an electronics vac instead of a blower.
Posted on Mar 18, 2008
Sharp PGD2710X Projector. The image displaying on my smartboard is constantly flashing
you need a new color wheel
USD60
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Aug 01, 2013 | Sharp PGD2710X Projector Lamp
Green line on left side of an image and a red line on right. Such as around a face. Colors just don't line up and picture is very fuzzy. Had another old rear projection and it had a way to align it. Can...
Your other model was more than likely a CRT projector where you coulod manually align the Red/Green/Blue guns. The one you have now is more than likely an LCD projector which can't be readily aligned. Sounds like the panel is failing.
Mar 13, 2011 | Zenith R57W46 57" Rear Projection...
No colour in bottom right corner
I believ you have an issue with the optical block on your set. Light produced by a high-intensity projection lamp enters the optical block and is split into three paths (one each for red, green, and blue) by a series of lenses, condensers, mirrors, filters, and/or beam splitters. Each color has an LCD assembly with polarizing filters and a liquid crystal microdisplay panel (approximately 1" across). On Sony's "3LCD" models, the light is transmitted through each LCD panel, and, on their "SXRD" (Silicon X-tal Reflective Display) models, the light is reflected off each SXRD panel. Finally, the three separately colored images are combined with a special prism into the final full-color image, which is then projected/enlarged onto the back of the screen by a projection lens.
The following annotated photo shows various parts on the optical block of a 2004 3LCD model KDF-55WF655 (note that the LCD panel cover has been removed):
dcramer531_82.jpg3
Either the block is starting to wear out or you have something blocking the lens, such a dirt or something has fallen and is blocking the lens
Feb 20, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
The projector is an NEC model VT590 and is connected to my computer for use with a SMARTBoard. In the bottom left hand corner a pink colour is starting to grow inwards. In the upper left hand corner, there...
It is not the smartboard, lamp or the computer as well know, it's the projector itself. This may not work but you at least need to try press the auto adjust button on the projector and then adjust the clock/phase in the menu. If not you will need to send in to NEC it could by the color wheel. Usually they have a warranty for a couple of years.
Jun 05, 2010 | NEC MultiSync VT590 LCD Projector
The image from my cp x251 is uneven the top and right side are angled but the bottom and left side are straight and perfect on the screen.
this is a common problem with projection systems this is the reason that most screens are lined with black felt its non-reflective and works great to hide uneven edges also try balancing out the difference with the keystone adjustment
HitachiTech
Feb 08, 2010 | Hitachi CP-X251 LCD Projector
Bottom right corner has a tint projector bulb is good
the colorwheel is collapsing and needs replacing. it's under a metal brace between the colorwheel and the lens. it's a 4-sided mirror tube that is glued together, and the glue wears out after a while.
Jun 18, 2009 | InFocus ScreenPlay 4805 Multimedia...
Upside down image!
Hi there
I just drew the users manual and you should do the following:
Go into the setup menu and choose mirror - then just scroll left or right on the mirror and your image will change as you do this.
Apr 01, 2008 | Hitachi ED-X3450 ED-X3450 PROJECTOR...
Projected image is not the same as computer monitor
as long as nobody has physically changed the lens poition, you can go into the menu on the projector and do a factory reset. this should default the settings back to where the installer put them.
Feb 05, 2008 | Mitsubishi ES100U Multimedia Projector
Blue color
Bad contact on cables probably
Apr 03, 2017 | Sony VPL-ES2 Multimedia Projector
InFocus ScreenPlay 5700 Multimedia Projector Logo
277 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Juan Carlos Pacheco
Level 1 Expert
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
